wanted se6a standard soft boring suspension
Locked
michael1703
Post by michael1703 » Thu Jul 12, 2018 11:55 pm
I want to use my se6A more often
My faithful longterm partner* doesn't like my stiff suspension and is reluctant to get in and isn't very relaxed when chauffeured in it
So I'm looking for some standard shocks if anyone has any
*(I'm talking about my Labrador)
Has thanked: 147 times
Been thanked: 155 times
Post by Corky » Fri Jul 13, 2018 5:44 am
Are you sure it's shocks you want and not just softer springs ?
Been thanked: 326 times
Post by peter freeman » Fri Jul 13, 2018 8:26 am
I doubt if the original shocks are available but you can always adjust "modern" ones for a soft ride - as for the springs uprated ones are the way to go - the originals will not last for more than a couple of years at best.
Been thanked: 115 times
Post by ScimmyMike » Fri Jul 13, 2018 8:34 am
Are you sure it's a damper / spring issue and not a seizing trunnion/wishbone connection issue though, I've had my 5a up in the air for 6 months whilst working on it and now sits like a preying mantis with zero suspension movement and I'm sure it's down to seizing trunnion connections so a rebuild is on the way
Locked
