Advice where rear Seatbelt mounting brackets fit SE5
1969SE5
Post by 1969SE5 » Thu Mar 29, 2018 1:16 pm
reckon i've something missing if thats the case :(
Geraint SabreGTCse5
Been thanked: 35 times
Post by Geraint SabreGTCse5 » Thu Mar 29, 2018 1:30 pm
this is how they are fitted to one on my C's which is the same as my 5. short ones near to tunnel long one to outside of each box. The plate Jim mentioned has been made of stainless on this one
Last edited by Geraint SabreGTCse5 on Thu Mar 29, 2018 1:39 pm, edited 1 time in total.
Geraint
Sabre ti, se5, GTC, 6b.......
Been thanked: 534 times
Post by philhoward » Thu Mar 29, 2018 1:33 pm
I just found something similar albeit on a 6b:
It appears I was wrong in my assumption, 1969SE5 :oops:
I highly suspect the 5 series are mounted in the same way.
1969SE5
Post by 1969SE5 » Thu Mar 29, 2018 1:35 pm
thats what i thought, so one through floor one through side
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Thu Mar 29, 2018 1:40 pm
yes but should not have a twist as in Phils picture
Geraint
Post by philhoward » Thu Mar 29, 2018 1:42 pm
It was the mounting points I was looking for (one on side, one in the base) rather than the shape of the straps.
1969SE5
Post by 1969SE5 » Thu Mar 29, 2018 1:47 pm
perfect, i can get the holes drilled !! thanks chaps, thought i must be right, but best to check 1st , been there before ................... !! :w
Stephenl
Post by Stephenl » Thu Mar 29, 2018 6:22 pm
I've bought some straps from Geraint too and these pictures are gold. Thanks to everyone.
Once more from me, not that it adds a great deal, but I had already uploaded it so it can't do any harm :D
'69 SE5
Stephenl
Post by Stephenl » Thu Mar 29, 2018 6:24 pm
this is how they are fitted to one on my C's which is the same as my 5. short ones near to tunnel long one to outside of each box. The plat Jim mentioned has been made of stainless on this one
Is that stainless spreader plate attached anywhere else, or just from that one same bolt that we can see?
'69 SE5
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Thu Mar 29, 2018 6:36 pm
the original plate on the GTC had a pop rivet above the nut to keep it in place, I made stainless plates but used the same adhesive that holds the bumper rubbers on, I had some spare to keep it in place. I have not seen a spreader plate on an se5, although I put one on the last 5 I did.
Geraint
gordini5
Post by gordini5 » Fri Mar 30, 2018 9:28 pm
Maybe a bit late to be of any help here :) I have 3 technical drawings for each of the brackets, ie the 2 slightly different outer ones and the two identical inner ones.
Each is A3 size but can copy and bung them in the post for anyone who needs them.
They were made a fitted before I took ownership of the 5a.
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Sat Mar 31, 2018 6:44 pm
the inner ones are handed
Geraint
Been thanked: 840 times
Post by scimjim » Sat Mar 31, 2018 8:05 pm
The parts list says it’s the outers that are handed?
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Sat Mar 31, 2018 8:19 pm
the picture of the actual items I added the other day shows the difference, the outers are the same , its the inners that are handed
Geraint
Post by scimjim » Sun Apr 01, 2018 12:07 am
Edited my earlier post :oops:
