8 Ball
Been thanked: 876 times
8 Ball
Post by scimjim » Tue Apr 03, 2018 9:32 pm
A little side project for 8 ball has been going on over the past few weeks - a replacement for the 2 rod inhibit/reverse switch.
The normal constraints apply - overdrive mustn’t be able to be engaged in first or reverse and reverse lights must work (new MOT requirement).
New requirements are - overdrive must be able to be engaged in second gear, must be engaged by a “momentary” switch (not like the original “latching” switch) and most importantly, must disengage as soon as you change gear.
Firstly then, we need some micro switches to ascertain where the selector levers are. Phil decided that we wouldn’t use a single switch to determine lever position but we’d have positive switching. That means twice as many switches :D
So, some CAD:
Add something to activate the switches
And cut some metal
Add lightness
And paint
Then basically repeat for the side lever
Now to decide if relays/DPDT will suffice, or start playing with ardueno :D
Has thanked: 82 times
Been thanked: 58 times
8 Ball
Post by efi_sprintgte » Tue Apr 03, 2018 9:39 pm
That looks like a fantastic idea, i used to hate doing the flat in 3rd OD go straight 4th gearchange... being able to keep more then a finger and thumb on the steering wheel seems like a good idea 8)
Been thanked: 550 times
8 Ball
Post by philhoward » Tue Apr 03, 2018 9:42 pm
Gives us a 7 speed gearbox too :mrgreen:
Could come in handy chasing down a Merc SLC 4.5 driven by a local with no idea of the word “fear”...
Been thanked: 216 times
8 Ball
Post by AJL Electronics » Wed Apr 04, 2018 10:48 am
How about going magnetic switches? Got to be more reliable than with all that crud being thrown about. You could use some simple logic using gates or diodes, but with the price of Arduino boards, there is little contest.
Has thanked: 63 times
Been thanked: 87 times
8 Ball
Post by b.c.flat hat » Wed Apr 04, 2018 11:49 am
Looks like a rash of ladybirds!
Martin Rowe
8 Ball
Post by Martin Rowe » Wed Apr 04, 2018 12:33 pm
Reverse lights wont need to come on, your cars too old.
8 Ball
Post by scimjim » Wed Apr 04, 2018 2:14 pm
only tested on post 2009 vehicles - but 8Ball will be MOT exempt anyway :D
MarkHawkins
8 Ball
Post by MarkHawkins » Wed Apr 04, 2018 2:57 pm
So, some CAD:
Is that an acronym for 'Cardboard Aided Design?' :)
Custodian of :
1968 '4b Coupe HBL 725G
ex 1974 '5a auto - VLN 826M
8 Ball
Post by scimjim » Wed Apr 04, 2018 4:40 pm
So, some CAD:
Yep :P
8 Ball
Post by scimjim » Sat Jun 23, 2018 10:51 pm
I left the box of seat bits at home today, so didn’t get them finished, so I fired up 8 Ball and got it outside in the daylight.
Greased everything, checked axle and gearbox oils, cleaned it, swapped a tyre onto a different wheel and balanced all 4 wheels. Also played around with the rear bumper - they all need to come off again because I’m not happy with the GRP bumpers, the fronts don’t line up and the rear is a bit too wide.
8 Ball
Post by scimjim » Sun Jun 24, 2018 10:07 pm
Checked all of the lights and brakes etc, Taxed and MOTd it online last night (I will probably take it in for an MOT later in the year), fitted the seats today and drove it home tonight. Has a slight misfire, the digital temp gauge is a bit erratic, the fuel gauge wasn’t working (but seems fine now :roll: )
Definitely an electrical problem somewhere though, when the fan comes on the digital voltmeter drops from 13+ to 11 ish and the Engine struggles - either the fan, wiring or alternator? I’ll get the AVO out tomorrow.
8 Ball
Post by scimjim » Tue Jun 26, 2018 12:03 am
Misfire sorted - another FIA kill switch causing problems :twisted:
Fuel gauge is still erratic and if I get time I’ll refit the original temp and volt meters as the digital ones are pants :D
Rev Light
Been thanked: 24 times
8 Ball
Post by Rev Light » Tue Jun 26, 2018 5:40 am
Nice to see it without a load of stuff piled on top of it! Great looking car.
Steve.
SE5a 'Fancier'
Gillsfan
8 Ball
Post by Gillsfan » Tue Jun 26, 2018 11:17 am
Looking good shippers, I'm liking the all black look.
1969 SE 5 Manual O/D Rat Rod
8 Ball
Post by scimjim » Tue Jun 26, 2018 12:10 pm
Roundels will have to go back on Steve - they took some paint off when I removed them :D
Bumpers will possibly get carbon wrapped?
I still need the chrome door trims/seals (at the base of the window).
