Mikey Bikeys LPG, Fully Disked up, Se5a
Has thanked: 32 times
Been thanked: 134 times
Post by Coupe Racing » Wed May 30, 2018 11:05 am
its oh so easy even when using a spare input shaft to allow some droop
Do you tighten the pressure plate uniformly all around a few turns at a time to keep the friction plate in its correct place and not under tension on the input shaft
Has thanked: 385 times
Been thanked: 195 times
Post by MikeyBikey » Wed May 30, 2018 1:36 pm
Yes. :D
Post by MikeyBikey » Tue Jun 05, 2018 10:33 pm
So just dropped the type 5 gearbox again and sure enough, the spigot bearing has come off the end off the crank and is loose on the gearbox input shaft. This is twice in a year. Two different brands but new spigot bearings. Both tapped home with a socket.
Last year the flywheel was lightened. But nothing was subsequently balanced. The current engine, whilst strong and reliable, feels coarse, probably even more so since the flywheel has been lightened. The bgh gearbox has had little use, albeit I’m a hamfisted idjut, but had replacement bearings throughout last spring. I did 4 events, no real driving otherwise. :?:
Has thanked: 132 times
Been thanked: 875 times
Post by philhoward » Tue Jun 05, 2018 10:35 pm
..and that’s probably why you’re killing gearboxes.
And rattling the bearing loose.
Post by MikeyBikey » Wed Jun 06, 2018 7:14 am
Ok. Makes sense. Something for later in the year me thinks. Not going to dismantle everything just yet
Has thanked: 227 times
Been thanked: 52 times
Post by willholderogri » Wed Jun 06, 2018 7:37 am
Why not try having a phosphor bronze bush machined as suggested by another poster. then Loctite bearing seal the outer to the flywheel.
will
Post by MikeyBikey » Wed Jun 06, 2018 8:02 am
Hi will, Must have missed that post re bush. Also Do you mean loctite the bearing outer face to the crank, not flywheel
Been thanked: 74 times
Post by Nick » Wed Jun 06, 2018 9:30 am
I'm afraid you will have upset the engine balance by lightening the flywheel.
Post by philhoward » Wed Jun 06, 2018 10:10 am
..and probably lost power as a result. Energy that would be used turning the crank is now being used up making the vibration.
Post by willholderogri » Wed Jun 06, 2018 12:06 pm
yes you are right mikey outer to crank
Has thanked: 311 times
Been thanked: 167 times
Post by efi_sprintgte » Wed Jun 06, 2018 1:03 pm
I agree with all the above comments..but.. your gbox destruction issues predate that, don’t they??
Post by MikeyBikey » Wed Jun 06, 2018 1:30 pm
Agreed with all the above but yes, as James pointed out, at least two spigot bearings physically failed big time before the crank was lightened, (only a year or two ago). Now they just fall out before falling apart :roll:
Post by Coupe Racing » Wed Jun 06, 2018 5:15 pm
might be time to measure the hole in the crank where the spiggot bearing lives accurately , and compare with a known good crank
geoff corderoy
Post by geoff corderoy » Mon Jun 18, 2018 11:07 am
have not heard of this problem before but one thought, do you put grease in the bearing after fitting it to the flywheel? This should be dry otherwise the grease forms a seal and fitting the gearbox will hydraulically force the bearing out of the crank and along the shaft.
Probably not the fault but who knows with such a strange problem.
Post by MikeyBikey » Sun Jun 24, 2018 8:24 pm
Hi All,
dropped the gear box, checked everything, new spigot bearing, different make this time and refitted. And I made sure she eased in.
So the result is....sounds like a bucket of nails when driving along
heh hoh.
