'74 SE5a rolling resto
frodo_monkey
Post by frodo_monkey » Fri Oct 27, 2017 12:04 pm
A nice working area now. Have a free day Sunday so hoping to get engine/box off the chassis, then axle and suspension off. Then deliver a big pile to my friendly local shotblaster! Also picked up a 3.54:1 PowrLok LSD.
frodo_monkey
Post by frodo_monkey » Sun Oct 29, 2017 9:48 pm
Engine and gearbox out, and the front suspension off. One trunnion bolt to ‘persuade’ out (I reckon a subtle blend of heat and violence will do it), and then I’ll drop the axle etc off and we’re there :)
Anyone know what size bit you need for the flywheel bolts?
Been thanked: 534 times
Post by philhoward » Sun Oct 29, 2017 10:06 pm
It’s just a normal bi-hex socket - only did this a week ago and can’t remember if it’s 9/16” or 5/8”!
frodo_monkey
Post by frodo_monkey » Mon Oct 30, 2017 9:26 pm
Thanks again - 9/16” it turns out. Lucky I didn’t have a proper purge when I changed all my 12pt sockets for 6pt a while ago...
Post by philhoward » Mon Oct 30, 2017 9:31 pm
:D
frodo_monkey
Post by frodo_monkey » Sun Nov 05, 2017 1:59 pm
No pictures (sorry!) but the chassis is now totally stripped. Looks good apart from the front of both outriggers! The metric ton on Waxoyl on it seems to have helped, although it is a pain to scrape off!
I’ve stripped the diff and CWP out of the donor axle; they look good, so those along with the standard 4HA will go off to my friendly local axle man this week. Have ordered a load of UNF bolts for reassembly, and Luke kindly helped me press out most of my bushes - just some rubber ones to burn out, then some of the inner races to cut out and the suspension is ready to go to the blasters.
frodo_monkey
Post by frodo_monkey » Sun Nov 05, 2017 4:15 pm
Pictures! Chassis:
Axle waiting to be farmed out (and scrap pile!):
And finally LSD (with cleaned up ‘P-L’ and ‘3.54’ tags):
frodo_monkey
Post by frodo_monkey » Fri Nov 17, 2017 7:53 pm
Axle and LSD off with Simon Constable, and the chassis/suspension off being blasted/primed. Should get it back next weekend, then suspension to paint and rebush before delivering the lot to Iain Daniels in Dec... pics to follow!
Lukeyboy46
Has thanked: 90 times
Been thanked: 37 times
Post by Lukeyboy46 » Sun Nov 19, 2017 9:47 pm
Nice work mate ;)
Luke Garratt
RSSOC Forum Moderator
74' Se5a - Daily driver!
frodo_monkey
Post by frodo_monkey » Sat Nov 25, 2017 12:11 pm
Cheers Luke :)
Chassis & suspension back - a few frills but nothing outrageous... booked in to drop it all with Danny next month:
Been thanked: 840 times
Post by scimjim » Sat Nov 25, 2017 12:43 pm
Good grief :shock:
I don’t see the rear bumper bar - are you going for the smooth back end?
Post by philhoward » Sat Nov 25, 2017 1:46 pm
That’s some top quality guano there..
That (and the outriggers) are standard issue rot spots; aside from the frilly bit by the seatbelt mount then there’s nothing out of the ordinary.
MadMax
Post by MadMax » Sat Nov 25, 2017 2:52 pm
Nothing nicer than a good ol' bit of shotblasting. Looks like you've got a fairly healthy starting point there :D
Max Benton
Reading, Berks
'Zeus' - Yellow Se5a
frodo_monkey
Post by frodo_monkey » Sat Nov 25, 2017 6:19 pm
Seatbelt mounts won’t be an issue with 6pt harnesses and a roll cage :) but will be sorted nonetheless.
I’m not planning on having bumpers, hence the lack of bumper bar. The back end of the chassis might get cut off and replaced with something lighter anyway! :wink:
Post by philhoward » Sat Nov 25, 2017 9:47 pm
Unless there’s a very good reason, I wouldn’t as it would immediately need (and probably fail) an IVA..
