E150 UOL rebuild - End of project :-)
td99
Has thanked: 17 times
Been thanked: 34 times
Re: E150 UOL rebuild - nice and shiny!
Post by td99 » Fri Sep 23, 2016 8:18 am
Thanks guys, I'll be looking for some LH drill bits then. Sound like a good investment.
td99
Post by td99 » Sat Sep 24, 2016 7:36 pm
After ordering aforesaid LH drill set, I realized that a real stud wasn't necessary for my purposes - just to maintain flatness of flange while re welding ex manifold.
So, patience being my middle name :P , I decided to drill a hole in teh stud to accommodate an 8 mm stud.
So I centre-punched the broken bit, and started to drill a small (too small!) 2.5 mm hole at the centre, this by using column drill on (too loosely mounted) cyl head. So some vibration came along and I think relative movement/vibration between column drill and cyl head resulted in broken drill :cry:
Bigger drill did not want to remove its smaller brother!
So I got out the TIG and built up a bubble of hot iron on top of the recessed stud, then welded an 8 mm bolt to that bubble.
allowed it to cool off a bit but while still quite hot tried it with spanner. Could move stud in but not out.
Repeated "caressing" back and fro with longer spanner finally had pleasant result and it's out!
2016-09-24 19.53.43 (Mobile).jpg (59.85 KiB) Viewed 1333 times
td99
Post by td99 » Wed Dec 28, 2016 6:24 pm
Decided to have another go at exhaust manifold a couple of days ago. From the second manifold I have, I cut the piping from the flange using the plasma cutter and then cleaned it up with the grinder. Quite amazing how the openings in the flange mismatch the ports of the cylinder head. I have a spare cylinder head to which I can bolt the flange to make sure that it remains flat while welding. I used rings cut from copper water pipe around the studs to ensure good centering. However, while manually positioning the rest of the exhaust manifold against the flange, I realized that I was creating another Ba**tard nut. One even worse than the original ET version. Tilting of the pipework relative to the flange can possibly alleviate this situation, maybe also using small diameter nuts and a shortened stud. I'll have to measure under-bonnet dimensions to see how this all fits with the turbo attached. The photo makes it look beter than the situation is in reality!!! Oh how the camera lies!
I would appreciate input from anybody who's actually done this to a DET manifold.
2016-12-28 19.13.52 (Custom).jpg (45.01 KiB) Viewed 1232 times
Has thanked: 452 times
Been thanked: 392 times
Post by CNHSS1 » Wed Dec 28, 2016 6:34 pm
Nissan nuts are smaller diameter Trevor, gives a tad more clearance if it helps
Has thanked: 309 times
Been thanked: 233 times
Post by Corky » Wed Dec 28, 2016 7:28 pm
It was the same on my (now team Oakes) DET. It is the new b'stard nut :lol:
I used a flange nut that took a 12mm spanner, which made it a tad easier to get an open ended spanner on. But IIRC the last time I stripped it down I lost that nut :oops: and used a 13mm flange nut. The trick was to fit that one first, as when the manifold is against the head you can't get the nut onto the stud (as your photo shows). TBF it's not a problem when it's all fitted and working. And it was a lot easier to fit than the notorious 8v manifold.
Has thanked: 86 times
Been thanked: 733 times
Post by philhoward » Wed Dec 28, 2016 8:46 pm
Crazy question but..
If the stud was another 50-60mm longer, would it miss the tubing? If so, then I've an idea.
td99
Post by td99 » Wed Dec 28, 2016 9:17 pm
philhoward wrote:Crazy question but..
I fear not, but will have a good look tomorrow. I guess you are thinking of the tubular fixings of taps to draining boardds etc - good idea Phil!
td99
Post by td99 » Wed Dec 28, 2016 9:18 pm
Another idea I had was a stepped stud, so using an 8mm thread/nut to fix, as it's at bottopm, thus only to crimp gasket. not to take load of manifold+ Turbo
td99
Post by td99 » Wed Dec 28, 2016 9:21 pm
CNHSS1 wrote:Nissan nuts are smaller diameter Trevor, gives a tad more clearance if it helps
Have some of them but as I said, camera lies, even the small Nissan nut would be difficult, although probably possible with Corky's approach to fit first.
td99
Post by td99 » Wed Dec 28, 2016 10:30 pm
Went to Garage and checked it out: an extended stud will hit the manifold so that is a "no-go".
Has thanked: 158 times
Been thanked: 1088 times
Post by scimjim » Wed Dec 28, 2016 10:34 pm
Will a socket screw fit?
Post by scimjim » Wed Dec 28, 2016 10:48 pm
td99 wrote:Quite amazing how the openings in the flange mismatch the ports of the cylinder head..... I used rings cut from copper water pipe around the studs to ensure good centering.
If the ports are that misaligned and the bolt holes that oversize, could you not offset the manifold to give maximum clearance on that stud?
Or in extreme, can you cutout and scallop the exhaust?
Post by CNHSS1 » Wed Dec 28, 2016 10:54 pm
Ideally the manifold ports should be oversize compared to the head ports, so some offsetting won't be an issue.
Been thanked: 49 times
Post by nickkeyser » Wed Dec 28, 2016 11:17 pm
You want to dowel the manifold to the head in the optimum position if there's much 'adjustment' on the bolt holes.
SSSC Champion 2019
SS1 CVH 1600Ti
Post by CNHSS1 » Thu Dec 29, 2016 11:03 am
The manifold stud holes are usually 2mm oversixe as 5heres a lot of expansion. The heads ally,steel studs and stainless manifold which will be orange at full chat so you cant dowel multiple times like a NA manifold or it'll fail. One dowel would be ok I guess
