SCIMITAR V8 LEXUS
Been thanked: 560 times
Re: SCIMITAR V8 LEXUS
Post by Roger Pennington » Tue Oct 26, 2010 6:36 pm
I suspect perspective plays a part in the photo, but there's no doubt that it is pretty beefy. The photos show that the handling is better than it was, though it's still perhaps a bit soft, the dampers seemed to be a bit limp and I believe new ones are on the agenda next.
Nickandkarren
Post by Nickandkarren » Sun May 04, 2014 5:41 pm
Cracking car, great build. Was the original lexus diff not a better option to mate to the engine and hence solve the gearing issues or would this have cause a real head ache with custom drive and prop shafts?
Supercharger and some piggy back management might do the trick, funny I have some drop in 550cc injectors for this engine.
Removing the Maf sensor also aids performance by getting rid of the huge restriction on the engine, although that does require piggy, however I see you mention lextream so I will say no more.
Great build and I hope ours can be even remotely similar
RobHoward
Post by RobHoward » Sun Aug 30, 2015 9:13 pm
Hi Ben,
love the conversion! did you use the ecu and loom from the donor car? or are you using an aftermarket ecu?
Rob
Lotus Esprit 4.5 V8 on Air Ride build
http://retrorides.proboards.com/thread/ ... =undefined
BodgerBen
1UZFE V8 SE6A
Post by BodgerBen » Sun Sep 17, 2017 9:53 am
Just saying hi as we've been a bit busy with other projects, trying to go 200+ within a mile, we've not done that yet, 193 is the best so far with a 25mph head wind, so there's still hope. That's been in Caroline's 911 Turbo. Pretty much a new engine and gearbox for that cars been a tad expensive. You need a lot of power to break 200 in a short(ish) distance so blowing the head gaskets, cracking the block and breaking the gearbox have been learning experiences. Whilst we had the block changed lots of other stuff has been done along with the normal rods, pistons, injectors, turbos, intercolers, fuel pumps. I suppose it is all to be expected, it's running around 750bhp at the mo, the engine has been built to take 1000bhp but that would mean silly size turbos and a bit more lag than Caroline wants to live with. It's her everyday car, the boost controler has a few settings, low, which is normal(ish) power (420) for winter (yes she puts winter tyres and uses it all year) then some setiings for track and runway days where the boost can be set to come in low or higher up the revs. It's an old auto box and she changes into top just gone 175 when you have the throttle nailed down. 7mpg on track days is not too bad, I think it's less than that on the runway days - six injectors flowing 800cc every min = empty tank very quickly.
And my Dolly Sprint - she's all wide arched and looking rather posh, although I did have her booked in with Dad and James for a LS3 engine - James has persuaded me to start with shell rather than ruining POE (she's on ebay at the mo, if she doesn't sell, stuff it, we'll put the LS3 in there).
So what's happened to the Lexus Scimitar - I've been using it as an everyday car, the bodywork is tatty, I had it blown over in celly just after the engine change, she really needs doing properly. I've had a bit of fun with the remote oil filter/heat exchanger - but then found a place in the states that makes a lovely billet gizmo that uses the original O ring rather than a gasket - fingers cossed that's sorted now.
The Jag XJS four pots have been replaced with a spiffing set of Fossway alloy 4 pots. Good god I didn't realise how heavy those Jag four pots were until I removed them.
Some tidying here and there and she's been great - that's why I need V8 power for the Dolly, but there's less room in the Dolly for a DOHC V8 - so going old school pushrod.
Anyway, I've just rejoined the club and noticed there may be a SE6 heated screen available - that would be great and I can use the Scim all through the year, I parked her up last winter.
I'll post up some pics when I've taken some.
Dad's been using his original SE4 quite a lot and James has completed the Daimler V8 into his SE4 - he's used the Daimler's dials - so it looks like a E-Type in there, we had all three at the Cranleigh Show earlier in the year. Nope, I didn't take any pics.
Has thanked: 154 times
Been thanked: 1051 times
SCIMITAR V8 LEXUS
Post by scimjim » Sun Sep 17, 2017 5:36 pm
Welcome back - I've merged this post with the existing thread for your car :D
Heated screens available through the Club - details here.
BodgerBen
SCIMITAR V8 LEXUS
Post by BodgerBen » Wed Oct 25, 2017 9:25 pm
Thanks Jim,
Caroline did see 204 on the speedo of her 911 at VMax in September so that's now done. Albeit only a 196 through the beams, on the plus side no Astons got anywhere near that (Aston subsidised the day with plenty of cars to test) and the fastest McLaren, a 675LT was 195! No more runway days, a chap we know blew his new engine on a 207mph run, ouch! Oh, and a silly bugger in his new(ish) turbo M6 decided not to brake and launched the car over the grass bank, into the trees, he took out a few trees, thankfully him and his Mrs walked away. The car, was not so lucky.
Anyway, I've continued to hoon around in the SE6A. But there is so much I need to do!
Caroline is about to pick up her new i3, I get the Forester XT for winter and I'll probably take the Scim off the road for a year whilst I sort out rattles and bits, hopefully get those heated screens fitted, sort out the power steering, maybe put the original seats back in....etc.
The minds willing...
SCIMITAR V8 LEXUS
Post by Roger Pennington » Wed Oct 25, 2017 10:14 pm
Hi Ben, good to hear from you again, sorry I missed your first post, 204 or 196 is pretty impressive, well done! :D Good to hear the Se6a is continuing to perform well, also. You mentioned two Se4s - would one of them be the "barn find" one? If so, it's great that that's back on the road again :D The Daimler engined one is really going back to it's roots!
BusaPhill
SCIMITAR V8 LEXUS
Post by BusaPhill » Thu Oct 26, 2017 11:52 am
Hi Ben.
Good to hear the Scimitar is still around.
Can you give us the low down of the suspension and brake upgrades in detail please.
And lastly the mods to the Fuel system to go Injection.
Phill.
1979 Scimitar SE6A V6 3.1 4speed Auto
2005 Mercedes C320 V6 3.0 7speed Auto (Diesel Daily Driver).
BodgerBen
SCIMITAR V8 LEXUS
Post by BodgerBen » Fri Apr 19, 2019 9:55 pm
Well, all those good intentions didn’t come to much, I didn’t use the car at all last year, a slight misfire and too much DIY at home. Anyway, the misfire was a duff coil, so easily sorted, she’s back running lovely.
I need to get her MOTD as my mates daughter wants the car for her school prom (what’s that all about)
I’ve only just bought the heated screens and she’s booked in for a proper 150hr Respray in July so they can fit the screens whilst they are out.
Sorry for no reply about the suspension and brakes, it’s been a very long time since they were done and I’ve forgotten, I had the TrackSpax rebuilt last year but I kept the rose joints, I softened the ride a bit but it’s still a bit too much track based and as The Mrs uses the Pork for track days, it could do with being softened up a bit more.
As for fuel mods, the Lexus pump was inserted into the tank with it’s built in swirl pot, then plumbed as per a normal FI system.
I’ll take some pics of suspension and brakes when I’ve got the wheels off for a clean.
BodgerBen
SCIMITAR V8 LEXUS
Post by BodgerBen » Sat May 11, 2019 1:28 pm
She just went through the MOT with no advisories, which is slightly odd as the windscreen still has the chip and I did nothing with the last MOT's slight play in steering, I probably will have to do the column bushes during the year.
I got her good and warm running back and forth on the mile long straight between Whitehill and Greatham with the odd blat up the A3 - all on the way to the MOT station :) She does go rather well but I'm not planning of doing any track days after the respray.
Front and rear screens will arrive at the end of the month, I've purchased a set of XJS door mirrors and also plan on changing from manual to power windows as the BMW sports seats make the winders a bit close to the seat. I now have a second hand set to have a play with.
I also need to get all the window rubbers, weather strips and need to have a search about the rear hatch handle as my one looks naff.
So does the fuel filler - so need to see if there's anything that can be done with that.
And I also need to slacken the handbrake pads off, I adjusted the handbrake up 4 clicks, but now the pads are driving me mad, even on the short run back from the MOT (she uses disk on the rear with AP racing 4 pots and separate hi-spec handbrake calipers).
I'll use her for a bit on nice days (and the school prom) - but only have seven weeks before she goes into surgery.
BodgerBen
SCIMITAR V8 LEXUS
Post by BodgerBen » Sat Oct 19, 2019 5:37 pm
I popped down to the local noggin to collect a rear hatch handle and had a nice natter to a few friendly people, expecting to have been able to show off a nicely resprayed car well before now. What happened?
I dropped the car off for its respray on the last weekend in June, then promptly had a heart attack on the first weekend in July, ambulance, cardiac care unit, stent fitted to right coronary artery, lovely jubly. Left hospital with a heart murmur and have a dodgy mitral and aortic valve, both will need replacing at some stage, but, due to having three different types of cancer I’ve been nuked too many times and the old ticker is covered in scar tissue. Where does this leave the poor old car, still up at C&S coach works as I’ve told Chris that I’m not in any rush to get it back, once the old ticker has either given up the ghost, then I definitely don’t care, or hopefully some skilful surgeon wields the chainsaw and axe nicely to replace said dodgy valves I’ll give chris a bit of a gee up, in the mean time, there’s beer to be drunk.
Has thanked: 191 times
Been thanked: 102 times
SCIMITAR V8 LEXUS
Post by efi_sprintgte » Sat Oct 19, 2019 5:42 pm
Blimey, gutted to hear about the health issue. Maybe the Scim will be a welcome distraction? Good luck
Been thanked: 96 times
SCIMITAR V8 LEXUS
Post by DARK STAR » Sat Oct 19, 2019 6:05 pm
Ouf, that is not nice, glad you're keeping cheerful anyway.
I look forward to further (good) news.
SCIMITAR V8 LEXUS
Post by Roger Pennington » Sat Oct 19, 2019 6:21 pm
Really sorry to hear that, Ben, hope it all works out ok for you and there's better news ahead.
Has thanked: 324 times
Been thanked: 156 times
SCIMITAR V8 LEXUS
Post by MikeyBikey » Sat Oct 19, 2019 7:07 pm
Agreed, truly hope things have turned the corner for you, and the scim :D
