Rat Rod (progress)
Gillsfan
Been thanked: 25 times
Rat Rod (dizzy drama)
Post by Gillsfan » Wed May 16, 2018 1:38 pm
The rotor arm is turning. I've checked the wiring and I can't see anything wrong, I turned the engine over by hand and lined up the timing mark. A small adjustment to line up number one. I'm confused what could be wrong, I am right that the spark plug earthed via a jump lead should spark? It's currently a new plug from my spares connected to a ht lead, clamped in a jump lead and placed in front of the windscreen so I cam see it.
1969 SE 5 Manual O/D Rat Rod
Gillsfan
Post by Gillsfan » Wed May 16, 2018 1:43 pm
Other info in case it helps. I'm getting oil pressure when it turns over. I've put the old cap back on and checked I've got the leads in the right order. I've also swapped the rotor arm. Still no spark :evil:
Has thanked: 158 times
Been thanked: 1093 times
Post by scimjim » Wed May 16, 2018 2:23 pm
Where is your 12v supply from - is it still live when the engine’s cranking?
Gillsfan
Post by Gillsfan » Wed May 16, 2018 2:41 pm
I've tried from 2 places both live when cranking. It's currently connected to the ballast resistor as per the auto spark instructions (12V side). Just double checked and it drops nearer 10 when cranking.
Has thanked: 86 times
Been thanked: 733 times
Post by philhoward » Wed May 16, 2018 2:51 pm
As long as the other end of the jump lead is connected to a good earth, then you should see a spark.
Gillsfan
Post by Gillsfan » Wed May 16, 2018 2:53 pm
Yep direct to the battery.
Why can't I get a spark ahhhhhhhhh :evil: :evil: :evil: :evil:
Post by philhoward » Wed May 16, 2018 2:57 pm
Think it might be picture time - where your wires are, and what the ignition says it's supposed to be connected to..
Gillsfan
Post by Gillsfan » Wed May 16, 2018 3:08 pm
Black wire connected to negative side of coil
Red wire connected to ballast resistor
Both wires connect to electronic ignition
Now even if the timing is mile out, which I'm pretty sure it isn't. There should still be a spark.
Post by philhoward » Wed May 16, 2018 3:15 pm
Is the black ring that fits on the dizzy hexagon pushed down enough (or too much)? If it doesn't line up correctly with the sensor block (with the wires) then it won't trigger. Wiring looks OK - assuming the white (?) wire coming off the coil is off the bypass terminal on the starter motor, of course.
Gillsfan
Post by Gillsfan » Wed May 16, 2018 3:41 pm
Ring as far down as it will go, which is where it has been until now.
Move up slightly
And again now as far it will go up.
Still no spark
Post by scimjim » Wed May 16, 2018 3:45 pm
Accuspark is u/s
Gillsfan
Post by Gillsfan » Wed May 16, 2018 3:46 pm
I'm going to have to put the old dizzy aren't I.
Post by scimjim » Wed May 16, 2018 3:47 pm
Just fit points to that dizzy?
Gillsfan
Post by Gillsfan » Wed May 16, 2018 4:08 pm
I've swapped the dizzys the electronic ignition is bonded in. I now have a spark, ffs. :evil: :evil:
GeoffTE
Been thanked: 32 times
Post by GeoffTE » Wed May 16, 2018 5:02 pm
Steve, Here's a pic of my Accuspark fitment, hope it helps
Did you notice the white adhesive insulation under the baseplate? Can't see that under yours unles it's a different colour. It is essential
Geoff. (5324)
