SS1 1800 CVH Project Starter
Clueless1
SS1 1800 CVH Project Steering rack oil or grease
Post by Clueless1 » Wed Feb 26, 2020 8:30 pm
Hi Peter, I have just rebuilt mine and about half a pint of stinky, sludge came out of the old gaiters! Friendly folk on here suggested to put grease in. I coated the rack, liberally with general purpose grease. It now feels much smoother.
Been thanked: 176 times
Post by gtcse8 » Wed Feb 26, 2020 9:51 pm
Peter I use CV grease as it contains stuff such as graphite, and it`s slightly more water resistant then generic general purpose stuff.
Use a paintbrush and cover everything with it.
Peter S
SS1 1800 CVH Project Vacuum pipes + more electrics
Post by Peter S » Wed Mar 11, 2020 10:44 am
Next series of dumb questions :?
Seem to have a lot of vacuum pipes and odd outlets around carb and manifold, see below.
Can anybody advice what goes where :?:
Moving onto electricals, are the 2 large relays standard :?: And has anybody a clue what the black switch under the dash on the left hand side is for :?: The other switch is I think to do with the alarm as is the led light and probably goes in the hole in the dash but too small :!:
Is the red button the headlight reset if so what's the white button?
Peter S
Geraint SabreGTCse5
Been thanked: 54 times
Post by Geraint SabreGTCse5 » Wed Mar 11, 2020 10:57 am
yes the red button next to the interior light is the "headlight reset" the white button, led and rocker switch aren't standard.
Geraint
Has thanked: 86 times
Been thanked: 733 times
Post by philhoward » Wed Mar 11, 2020 11:15 am
Vacuum hoses - the black canister port is labelled "CARB" at a guess - in which case is the vacuum takeoff on the carb base IIRC. The takeoff on the manifold is for the return (bottom pipe) on the breather separator (sits at the front of the rocker cover and plugs into the bottom of the air filter) - usually. -
Post by philhoward » Wed Mar 11, 2020 11:18 am
Yellow and Red relays are the low fuel and low coolant warning modules from memory - they have labels on them (on the underside the way they're mounted) which tell you which is which. I think there's a third black one for low oil too?
Has thanked: 158 times
Been thanked: 1093 times
Post by scimjim » Wed Mar 11, 2020 11:19 am
Red and yellow Relays are standard low fuel and low coolant.
Edit - beaten to it by Phil. Low oil is a larger unit and on early models with electric dipsticks only.
Empty hole looks in the right place to be choke cable?
Post by philhoward » Wed Mar 11, 2020 11:22 am
Empty hole looks to be the right size for a holder for that LED (carryover from the alarm unit?).
Peter S
Post by Peter S » Wed Mar 18, 2020 7:40 pm
Alternator wiring questions
Does the white red wire go into the centre of the connector plug? Does the choke heater wire go onto the lower bolt?
Does anything to onto the LHS bolt with 2 nuts. Any ideas what the black rubber connector with 2 small black wires is for.
Peter S
Peter S
Post by Peter S » Wed Mar 18, 2020 7:53 pm
Coil wiring next. Any idea where black wire ( earth?) from coil goes :?: Or another bodge feed :?:
Any idea what the connector with green/white wire is and where it goes :?:
Peter S
SS1 1800 CVH Project Alternator & Coil wiring
Post by scimjim » Wed Mar 18, 2020 7:57 pm
Connector is your rad fan sensor (on the back of the stat housing).
Post by philhoward » Wed Mar 18, 2020 8:56 pm
White/red wire sounds like starter solenoid wire?
Dcrosby13
Has thanked: 34 times
Been thanked: 103 times
Post by Dcrosby13 » Wed Mar 18, 2020 10:46 pm
White green is driver's side indicators
I break stuff...... :w
Dcrosby13
Post by Dcrosby13 » Wed Mar 18, 2020 10:47 pm
And yes white red goes to the starter like this
Dcrosby13
Post by Dcrosby13 » Wed Mar 18, 2020 10:49 pm
