71 GTE SE5A my rolling restoration and now Tdi conversion
Has thanked: 189 times
Been thanked: 37 times
Post by willholderogri » Tue Sep 10, 2019 7:34 pm
Thats still ok just use a JAP one it's very versatile
CarlosVanDango
Post by CarlosVanDango » Sun Sep 22, 2019 9:55 pm
bit more progress :)
i'm using an RX8 gearbox coupled to the VW engine, I can't find an adapter plate made for this so i've got to make my own. Also after talking to some of the suppliers of these plates i'd be a bit concerned about the manufacturing tolerances, it's ok saying its CAD drawn CNC machined and laser cut if the initial measurements are out.
to make my plate i've copied a VW plate for the engine holes - that is the easy part to get the bellhousing accurate i've stripped off the bellhousing made a brace to bolt the dti onto the crank, made a stand for the engine then rotated the crank round to true up the bellhousing i've then centred the holes i need using a mag drill, swapped the bit out to the correct size, unbolted the bellhousing then drilled the plate, i've repeated this for every hole - very time consuming but guarantees accuracy
the manufacturers tolerance on the centre of the gearbox input shaft to the crank is +/- 0.12mm this way i can get it within that
setting up.JPG (186.07 KiB) Viewed 756 times
CarlosVanDango
Post by CarlosVanDango » Fri Oct 18, 2019 8:51 pm
engines out
bay looks quite big now
Has thanked: 191 times
Been thanked: 102 times
Post by efi_sprintgte » Sat Oct 19, 2019 9:31 am
Running by Sunday?? :lol:
CarlosVanDango
Post by CarlosVanDango » Sat Oct 19, 2019 11:50 am
:lol: :lol:
i'm under no illusion this will take a while - especially this time of the year, i'm quite fancying going to the retro rides gathering at shelsley walsh next year - i've never been before but looked good this year, so my target is to get this done by then and drive it there under diesel power :D
Has thanked: 77 times
Been thanked: 706 times
Post by philhoward » Sat Oct 19, 2019 4:02 pm
Ooh - that’ll be the one traditionally the same weekend as Scimfest... :w
