71 GTE SE5A my rolling restoration and now Tdi conversion
Has thanked: 189 times
Been thanked: 37 times
Post by willholderogri » Fri Sep 06, 2019 9:32 pm
I found as you did it touches your legs im using vw b6 seats electric adjust so I will shunt it down eventually .I can't see the clocks with the small wheel though .
CarlosVanDango
Post by CarlosVanDango » Fri Sep 06, 2019 10:00 pm
ah yeah there is that, i was thinking i could swap them over so you'd be able to see the low mph's and high rpm's
when i swap the engine i'll probably need a gps speedo anyway and different rev counter
Post by willholderogri » Fri Sep 06, 2019 10:44 pm
I'm using an electronic Speedo from India £30 and a ford escort sensor
CarlosVanDango
Post by CarlosVanDango » Sat Sep 07, 2019 6:09 pm
speedo wise i was thinking one of these https://www.ebay.co.uk/itm/85mm-Black-G ... 1438.l2649
is the scimitar standard one 85mm?
Has thanked: 155 times
Been thanked: 1051 times
Post by scimjim » Sat Sep 07, 2019 6:19 pm
No, they’re 4” / 100mm.
CarlosVanDango
Post by CarlosVanDango » Sat Sep 07, 2019 6:24 pm
thats a shame they are a lot more expensive :lol:
Has thanked: 78 times
Been thanked: 706 times
Post by philhoward » Sat Sep 07, 2019 6:33 pm
Yep :D
After going round the houses multiple times you either get something cheap that looks totally out of place (digital and looks like it belongs on a quad bike) or spend the cash - VDO do a nice one for under £200 that will work with a £10 sensor suitably aimed at a prop shaft bolt and doesn’t look out of place. You’ll be staring at it all the time and if it’s going to be something out of place, you might as well use a Speedo app on your phone attached to the screen with a mount. At least you can remove it..
Post by willholderogri » Sat Sep 07, 2019 7:16 pm
My 100 mm Indian electronic Speedo Was £30 it says kph but I have it calibrated for mph
CarlosVanDango
Post by CarlosVanDango » Sat Sep 07, 2019 8:36 pm
have you got a link to where to buy it Will?
i can put up with kph my import gsxr has been that way for years
Post by willholderogri » Mon Sep 09, 2019 6:42 am
I will look tonight remind me if I haven't done it by Tues
Post by willholderogri » Mon Sep 09, 2019 6:26 pm
This is it I can't find the link at the mo it was an eBay item though
Post by willholderogri » Mon Sep 09, 2019 6:27 pm
It's an Indian tractor item I think
CarlosVanDango
Post by CarlosVanDango » Mon Sep 09, 2019 6:47 pm
cheers i could live with that - how does it pick up the speed?
i did think about getting the 85mm and mounting it in a bezel to make it up to 100mm - not sure how it will look tho
Post by willholderogri » Tue Sep 10, 2019 6:19 am
The ford escort sensor screws onto the gearbox where the cable used to fit. If it's an auto you need an adaptor first .
CarlosVanDango
Post by CarlosVanDango » Tue Sep 10, 2019 6:07 pm
Ah i'm planning on using an RX8 gearbox so i might have a problem there
