660XYB Engine fix
Been thanked: 70 times
660XYB Engine fix
Post by Old and Slow » Sun Dec 02, 2018 10:27 pm
Sabre Six with the 2.6 straight six Zodiac engine, rebuilt approx 20 years ago by Iain Daniels for Richard Prosser.
The problem is the crankshaft rear oil seal leaking; I've tried changing just the bottom half from under the car, but without success, so it is time to lift the engine out and change both halves of the seal.
I'll replace the timing chain too, but I don't want to disturb the RM head if I don't need to.
Progress with photographs to follow; currently getting all the bits together ready to start.
chrisgallacher
Been thanked: 41 times
660XYB Engine fix
Post by chrisgallacher » Sun Dec 02, 2018 11:03 pm
Re the core plugs Philip - I don't recall seeing a set for the S6 engine, but I've collected individual plugs from auto jumbles over the years. I suggest not worrying about measuring yours - just give Kevin Dipchon at Zodiac Motors in Erith a call and he'll pop the correct sizes in the post to you and you'll know they'll fit. Unless Nigel at QRG has any in stock?
Chris Gallacher
RSSOC Rally Secretary
rally.secretary@rssoc.co.uk
MrGoldtop1960
Has thanked: 28 times
Been thanked: 26 times
660XYB Engine fix
Post by MrGoldtop1960 » Mon Dec 03, 2018 8:12 pm
Hi Philip/Chris,
Whilst at a car show earlier this year, I was parked up next to a really fantastic Zodiac which had a RM head fitted. After talking with the owner throughout the day he gave me a business card of the place he gets all his spares from etc.
It’s a small world!
Kev O
Kev Osborne
Solent Noggin NogSec.
Member No.2104
chrisgallacher
660XYB Engine fix
Post by chrisgallacher » Mon Dec 03, 2018 8:39 pm
There aren't that many options for S6 engine spares, so when I rebuilt my engine I bought all the parts from Kev at ZMS. Fair prices and nice guy to deal with.
The other Zephyr/Zodiac specialist is Newford Parts Centre at Chorley, but I don't have any direct experience of using them. But they are well thought of too I think.
Chris Gallacher
660XYB Engine fix
Post by Old and Slow » Tue Dec 04, 2018 6:02 pm
Hi Kev,
That's who I'm using for all my bits, but thanks for the tip.
Philip
660XYB Engine fix
Post by Old and Slow » Wed Dec 05, 2018 6:46 pm
Just ordered the timing chain, front crank seal and gasket, picture to follow when they arrive.
chrisgallacher
660XYB Engine fix
Post by chrisgallacher » Wed Dec 05, 2018 7:19 pm
Degrease and re-paint the block whilst the engine's out??
Chris Gallacher
660XYB Engine fix
Post by Old and Slow » Fri Dec 07, 2018 10:28 am
Hi Chris;
Great minds think alike! :)
And here's a picture of the old bottom oil seal alongside the new ones waiting to be fitted; ZMS recommend soaking in oil for 24 hours, although my Autopress Workshop Manual says not to. :shock:
Hope to get started next week.
Has thanked: 77 times
Been thanked: 706 times
660XYB Engine fix
Post by philhoward » Fri Dec 07, 2018 11:20 am
If it’s a fabric (rope) or leather seal I’d soak it myself.
chrisgallacher
660XYB Engine fix
Post by chrisgallacher » Fri Dec 07, 2018 11:30 am
I'm pretty sure I soaked mine when fitted a few years ago - and it's been oil-tight (well, ish :) ) since.
Btw do you know what the original colour of the engine block was? I did mine green as I was under the impression that's how they left the factory, but I think now I was wrong and they were in fact blue. Anybody know for sure?
Chris Gallacher
660XYB Engine fix
Post by Old and Slow » Sat Dec 08, 2018 8:45 pm
Mine's currently black, but that might be all the grease and grime... :)
Chris, will your engine stand bolt on when the flywheel and clutch are still in place? You seem to have bolted the plate up against the block directly, I think I'd need spacers?
chrisgallacher
660XYB Engine fix
Post by chrisgallacher » Sat Dec 08, 2018 9:43 pm
The stand comes with spacer arms, but I didn't use them. I used the bellhousing fixing holes to mount the engine to the stand, but can't really recall why I didn't use the arms - possibly I didn't have long enough UNC bolts to go through them into the block?? They're 20mm square section I think. I used some thick steel plates I had kicking around, using the bellhousing bolts themselves:
I think there's room for the flywheel to stay on the engine, particularly if you use the proper spacer arms. Not sure about the clutch assembly, but you'll be removing this presumably to change the clutch?
Chris Gallacher
chrisgallacher
660XYB Engine fix
Post by chrisgallacher » Sat Dec 08, 2018 10:08 pm
But in any case, you'll have the flywheel off if you're taking the crank out to replace that oil seal?
Anyway, I have all the fixings which came with the stand, plus my own adapter brackets I think - you're welcome to borrow it all.
Chris Gallacher
guybetts
660XYB Engine fix
Post by guybetts » Sun Dec 09, 2018 12:24 am
I mounted mine on the side, using the engine and dynamo mountings.
GTC Registrar
660XYB Engine fix
Post by Old and Slow » Sun Dec 16, 2018 1:47 pm
Making some progress: draining fluids, and I've removed the starter. I think it is a later type as it is pre-engage (I assume '60's Fords weren't?)
Here's a couple of pictures, what do you think of the teeth on the starter pinion? Suggestions welcome!
Pre-engage Starter
Pinion teeth
