The Golden Coupe
Been thanked: 319 times
Goldie the Coupe
Post by peter freeman » Fri Oct 19, 2018 1:34 pm
063 same as fitted to the SS1 fits perfectly
roymck
Been thanked: 14 times
Goldie the Coupe
Post by roymck » Sat Oct 20, 2018 12:24 pm
So what do we prefer , V6 shouldn’t have spoke wheels should they ? I prefer the Knock on Alloys
scim_rebel
Goldie the Coupe
Post by scim_rebel » Sat Oct 20, 2018 12:47 pm
Wire wheels every time for me on a Coupe of either engine flavour - finishes the car off perfectly.
Even though mine has minilites..... :roll:
Carl
1968 SE4a & 1971 SE5
1972 Fairthorpe TX-GT
Previous: 1968(x2), 1969, 1970 & 1971 SE5s, a brace of Rebels plus a 1970 Trident Clipper. Does a 2004 MG-ZTT count too?
A pessimist is never disappointed...
*JP*
Goldie the Coupe
Post by *JP* » Sat Oct 20, 2018 12:54 pm
Both types look good,just make sure the wheel and hub splines are in good condition!
...and if I ever get a car again with knock on wheels (which is very unlikely now,sadly) I would get one of those big spanner devices.
Even with the correct type of soft faced hammer the chrome gets damaged,as well as other things if you miss. :)
Goldie the Coupe
Post by peter freeman » Sat Oct 20, 2018 1:21 pm
Wire wheels are a pain to clean - I have MB wheels fitted which to me arethe best of both worlds - MB wheels are hard to come by now though
Goldie the Coupe
Post by Roger Pennington » Sat Oct 20, 2018 3:18 pm
Judging by your photo you've got a choice? If so I'd make sure the wires were nice and clean, then keep them for shows, and have the alloys for everyday practicality - best of both worlds! :D (or am I just greedy? :lol: )
David Tew
Been thanked: 24 times
Goldie the Coupe
Post by David Tew » Sat Oct 20, 2018 5:10 pm
I prefer the alloys. I think Minilite-style wheels really suit the Coupe.
You could recoup a fair bit of moolah by moving the wires on but Roger's suggestion is a very sensible option. :)
I see you have the usual close-fitting Coupe front bumper! :wink:
RSSOC member since 1978. 😲
roymck
Goldie the Coupe
Post by roymck » Thu Oct 25, 2018 4:01 pm
Well work progresses , everything I touch needs work . Re rear brakes are shocking , drums split , linings cracked and all hydraulics siezed , so looks like it will need everything done . Can anybody tell me how the handbrake cable should be run , look at the picture and it’s forcing itself against the brake flexi hose it’s definitely routed wrong .So how should they run they look to long ?
Also the state of the watts linkage is suspect , if anybody has a bettter set that will clean up that would help me out . Just worry that if I get it blasted there won’t be anything left , that’s assuming I could get this old one off to be blasted and rebushed.
Been thanked: 840 times
Goldie the Coupe
Post by scimjim » Thu Oct 25, 2018 4:33 pm
IIRC the 7HA has a diffrent sized (and NLA) centre bush to the 4HA?
Goldie the Coupe
Post by Roger Pennington » Thu Oct 25, 2018 4:43 pm
I might be wrong, but I vaguely remember that there is or has been, a supply issue with coupe handbrake cables, so some people use Se5/a ones, which are, of course, too long, so I think some people cross them over (right to left) to take up some of the slack??????
guybetts
Has thanked: 24 times
Goldie the Coupe
Post by guybetts » Thu Oct 25, 2018 5:10 pm
Roger, I think you are correct. I bought my handbrake cable nearly 30 years ago from Don, and even then he said these might be the last ones he could get.
Guy
GTC Registrar
Goldie the Coupe
Post by peter freeman » Thu Oct 25, 2018 5:17 pm
Any Use - the cable clamp orientation should give guide as to the fact that the cable runs along the top of the axle.
IC handbrakee.jpg (83.18 KiB) Viewed 456 times
roymck
Goldie the Coupe
Post by roymck » Thu Oct 25, 2018 5:21 pm
If that’s true then that’s a bit of a problem , would I be correct in thinking that outer bushes are available , I think I remember seeing a limited quantity had been made , what about Polybushes ?
David Tew
Goldie the Coupe
Post by David Tew » Thu Oct 25, 2018 5:32 pm
Jim's absolutely correct. However, I think I have a complete 7HA Watts linkage centre unit in my spares box, if that would help. I refurbished it before I fitted the 4HA. I'll have a look tomorrow and see if I can find it. :wink:
roymck
Goldie the Coupe
Post by roymck » Thu Oct 25, 2018 5:49 pm
Yes please David .
