Mikey Bikey's Scimega
Has thanked: 216 times
Been thanked: 116 times
Post by efi_sprintgte » Tue Mar 24, 2020 9:06 pm
efi_sprintgte wrote:
Fri Sep 13, 2019 9:48 pm
I imagine the clutch cover doesn’t have enough pressure
Glad your fitting a stronger clutch. I hope it’s the cure for you.
Has thanked: 339 times
Been thanked: 162 times
Post by MikeyBikey » Tue Mar 24, 2020 9:15 pm
Hi James, so much for trying to get the car to Richard !
Fingers crossed. Well see how this works
Dcrosby13
Has thanked: 34 times
Been thanked: 103 times
Post by Dcrosby13 » Tue Mar 24, 2020 9:29 pm
we had a paddle clutch, did 15 miles with it in and pulled the engine and box it was that bad. hope you like it more than we did.
I break stuff...... :w
Has thanked: 158 times
Been thanked: 1093 times
Post by scimjim » Tue Mar 24, 2020 9:34 pm
MikeyBikey wrote:
Tue Mar 24, 2020 8:58 pm
scimjim wrote:
Sun Mar 22, 2020 7:44 pm
It must still be partially engaged with your foot completely off the peal then?
Thought long and hard about this Jim, and took measurements but I’ve got the other scenario. The clutch is only engaging on full depress so it’s disengaging fully, I hope. Hence ordered the 6paddle
I don't follow - the clutch doesn’t engage when you press the pedal :D
Post by efi_sprintgte » Tue Mar 24, 2020 9:49 pm
Paddle material can make a big difference to driveability, also spec it with springs otherwise it’s like a switch
Been thanked: 137 times
Post by BigBobPilot » Wed Mar 25, 2020 7:34 am
Yep, I'm with James, not all paddle clutches are the same. A sprung centre for road applications.
SS1 CA18DET race car
Dcrosby13
Post by Dcrosby13 » Wed Mar 25, 2020 8:07 am
Ours was sprung, im hoping Mikey has a better experience.
Post by MikeyBikey » Wed Mar 25, 2020 10:40 am
Clutch slip at full beans, acceleration wise, not actual speed
Post by MikeyBikey » Wed Mar 25, 2020 10:43 am
Ah well, I drive like an excited idiot anyway so the car lurching around whilst pootling around in Falmouth isn’t going to be new to anyone
Dcrosby13
Post by Dcrosby13 » Wed Mar 25, 2020 11:46 am
:lol:
Post by MikeyBikey » Wed Mar 25, 2020 3:42 pm
Has thanked: 193 times
Been thanked: 166 times
Post by b.c.flat hat » Wed Mar 25, 2020 3:52 pm
Roight, take the bleddy rappin' paper off this time!😎😁
Dcrosby13
Post by Dcrosby13 » Wed Mar 25, 2020 4:14 pm
Thought you bought one with six paddles?
Post by MikeyBikey » Wed Mar 25, 2020 7:50 pm
Must admit I thought it was 6 but it was all verbal, then this turned up. Is there a significant difference between 6 and 4 paddles.
Just got dressed to go down the garage then changed my mind. Think I’ll read a book.its dark and cold down there, warm and cosy in here. :wink:
Post by MikeyBikey » Sat Apr 04, 2020 10:21 pm
New paddle clutch plate seems to have done the trick. After a 50 ish gentle miles to allow everything to bed in, she’s performing well. Managed 0-60 in 8s without any drama.
The brakes are good, but the back is a tad quick to lock up. Not daft braking, just pressing the pedal progressively harder and quickly.
