Mikey Bikey's Scimega
Has thanked: 86 times
Been thanked: 725 times
Post by philhoward » Sat Feb 22, 2020 1:49 pm
MikeyBikey wrote:
Sat Feb 22, 2020 1:24 pm
So when doing an efi swirlpot, is the pump supplying the pot a normal pressure one, whilst obviously the one taking to the injectors is high pressure
Yep.
Has thanked: 309 times
Been thanked: 233 times
Post by Corky » Sat Feb 22, 2020 2:33 pm
Yes
Has thanked: 336 times
Been thanked: 161 times
Post by MikeyBikey » Sat Feb 22, 2020 6:58 pm
So I've been busy but a bit challenging. Time is at a premium as I'm commuting a lot, wife is living 150 miles away and in staying home to look after my rabbit. :!:
Also I'm trying to get the car to Richard to do various significant bits but the autosolo threw up two things, which was the whole idea but delayed things somewhat. The clutch slipped on the way home, and smoked slightly during g the event 8) . This was a bit to resolve as I know my setup is different to oem and had never quite been right. Secondly under power she swapped ends at will. I have a 40 litre donut lpg tank the wrong side of the axle so of course when full of lpg it weighs a lot and simply acts as a pendulum.
Post by MikeyBikey » Sat Feb 22, 2020 6:59 pm
So I decided to put in an lpg torpedo tank where the back seats were...
Post by MikeyBikey » Sat Feb 22, 2020 7:03 pm
I've also dropped the gearbox and dismantled other stuff,
Has thanked: 210 times
Been thanked: 111 times
Post by efi_sprintgte » Sat Feb 22, 2020 7:07 pm
What got hurt on the clutch?
Post by MikeyBikey » Sat Feb 22, 2020 7:11 pm
Your dad actually pointed something out.
So these are the measurements
So my flywheel setup is 25mm shallower, but my bearing attached to the concentric clutch is 19mm taller
Post by MikeyBikey » Sat Feb 22, 2020 7:15 pm
I took the box etc out
The pressure plate is blue, hence overheating, but the clutch plate is fine. However the clutch fluid pipes in the bellhousing have tiny holes. A while back Your dad has said oem pipes sometimes don’t allow the fluid to release quick enough.
Post by MikeyBikey » Sat Feb 22, 2020 7:21 pm
The delay has been , I hurt my back a couple of weeks ago training...
And even though it’s a really clean installation, one of the gearbox bolts os sooo weelll hidden, because of the sore back, I needed to remove everything to minimise stupid yoga positions trying to do it on the least effort.
Post by MikeyBikey » Sat Feb 22, 2020 7:23 pm
Donut tank was here
But replaced with torpedo tank right side of axle
So I think I needed to do this before getting the suspension sorted, aka richard
Post by efi_sprintgte » Sat Feb 22, 2020 7:33 pm
MikeyBikey wrote:
Thu Oct 10, 2019 9:50 pm
ok, so another attempt.
New concentric slave, interestingly came with a note with "DO NOT COMPRESS". which is of course, the exact opposite to what i did before.
So the bearing slides off no problem.
Then a slight bit of filing to the housing the make an interference fit :-
can someone please check my logic.
As you can see the bearing I've fitted is a classic style, with a 13mm deeper housing than one fitted when purchased.
So that means my concentric slave setup is now 13mm taller the the original oem one, which should negate the 18mm shallower flywheel.
Ie the clutch pressure plate fingers are 18mm further away. But my concentric bearing is now 13mm closer.
Is that how it works ? Is that enough of a take up ?
The bore of my master cylinder is the same as oem, 3/4" but the travel is slightly further.
This has come up before.. :w
Post by efi_sprintgte » Sat Feb 22, 2020 7:34 pm
Post by MikeyBikey » Sat Feb 22, 2020 8:40 pm
Sorry James, the order of the posts was based on pictures etc from my iPad or phone rather than common sense. You dad highlighted the small holes in oem bellhousing piping as a cause for not releasing,
I think by the measurements, my problem isn’t overcompressing the pressureplate, but if anything undercompresiing. If anything the bearing could do with being a bit taller.
And I think. The tiny holes in the pipe work, don5 allow the fluid to release quickly enough, hence plate slipping when changing gear
Post by MikeyBikey » Sat Feb 22, 2020 8:45 pm
So what’s the best method to deglaze a pressure plate
Post by efi_sprintgte » Sat Feb 22, 2020 8:59 pm
Do the OEM pipes have a pressure limiting valve? My Beamer had one and the clutch was so lazy with it fitted that I bypassed it.
