Shopping List for a Scimega
Been thanked: 581 times
Post by philhoward » Mon Sep 10, 2018 9:23 pm
They’re 2 days’ drive when you have to change the clutch half way there... :mrgreen:
Has thanked: 222 times
Post by MikeyBikey » Mon Sep 10, 2018 9:43 pm
Stripped the engine of lots of gubbins.
Waterworks:
Maybe @Phil / Lozz: There's a lot of pipes that seem to go around in circles. Water pipe out from the back of the block that seems to feed everything. I know I need to trim the metal one into a tighter output to stop fouling the bulkhead, but do I really need all those smaller pipes. EG to the throttle bodies ? and a load into the metal bit below the plenium, again at the back of the engine.
Crank case breather:
i've removed that elaborate emissions thing at the back of the engine. Did you just blank the remaining holes orf, and did you have a take off going back into the inlet plenium?
And what are those two identical sensors, one either side of the block, midway along.
Next time I'll take a camera.... :oops:
Post by philhoward » Mon Sep 10, 2018 10:18 pm
If I remember right it ends up as 2 stubs at the back of the engine which is heater in/out, block off the one half way along the long stainless pipe as it originally goes to the header tank leaving the hose connections to/from the throttle bodies which becomes the small bore pipe to the OE Scim header tank. As for the breather pipes, I left them all original Omega. I think Loz did a bit of carving on his?
superleggo
Post by superleggo » Mon Sep 10, 2018 10:46 pm
Mikey
I think I spotted your car driving through the the Dobwalls roundabout a couple of weeks ago. You are more than welcome to drop in and see my Omega conversion if you are passing by this way again. I think you have got my mobile number. If not PM me and I am happy to advise you
Hugh
fightingtorque
Post by fightingtorque » Tue Sep 11, 2018 8:57 am
Might be knock sensors? (Guess).
If you are going for an aftermarket ECU, probably won't use them. But if you use original ECU, it will be looking for them.
