SST 1.4 & ti
Has thanked: 86 times
Been thanked: 733 times
SST 1.4
Post by philhoward » Fri Sep 20, 2019 8:31 am
Yes to clearance issues with bottle tops and GW vented. Depending on the age (batch) of discs you may find they don't sit correctly (central) in the calipers. Unfortunately the adjustment required means you need to space the discs off the hub, not space the caliper away from the stud axle. Or fettle the calipers instead...
Dcrosby13
Has thanked: 34 times
Been thanked: 103 times
SST 1.4
Post by Dcrosby13 » Fri Sep 20, 2019 8:41 am
Heres one we made earlier......
I break stuff...... :w
Geraint SabreGTCse5
Been thanked: 54 times
SST 1.4
Post by Geraint SabreGTCse5 » Fri Sep 20, 2019 6:46 pm
cheers guys
having spent hours trying to fit the exhaust which would not fit with out touching somewhere, in the end I needed the bends altering to get it right.... I may have a rethink about the vented discs.... :roll:
so any one have the chevette part number for front drop links and the lower wish bones bushes I believe there are several types... I would like to start collecting bits for a suspension refurb during the winter. thanks
Geraint
Has thanked: 158 times
Been thanked: 1093 times
SST 1.4
Post by scimjim » Fri Sep 20, 2019 6:48 pm
There are definitely two sizes for chevette arb bushes - if you look at the poly thread, the part number is the size in mm. There’s also two sizes of lower balljoint but I think the lower bushes are one size fits all.
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Fri Dec 13, 2019 6:47 pm
and a ssti for company, has an mot but needs some work esp cosmetics....
Geraint
SST 1.4 & ti
Post by philhoward » Fri Dec 13, 2019 7:36 pm
There may a full OS wing with some of the front nose floating around if needed - speak to scimjim..
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Fri Dec 13, 2019 7:51 pm
thanks Phil, its the nearside that has some damage around the headlight and I have a new nearside corner/wing if I need it. it will be a while before I get anything done on it though. Got it home went to let the dog out before I unloaded, promptly slipped fell and broke my shoulder :roll: ....
Geraint
SST 1.4 & ti
Post by scimjim » Fri Dec 13, 2019 8:12 pm
Would that be Marks old car?
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Sat Dec 14, 2019 8:30 am
yes and belonged to Chris
Geraint
Has thanked: 216 times
Been thanked: 116 times
SST 1.4 & ti
Post by efi_sprintgte » Sat Dec 14, 2019 8:54 am
Ouch!! :oops: :shock:
Good luck with your recovery
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Sat Dec 14, 2019 9:16 am
thanks, it has slowed me down a little.
Geraint
Has thanked: 452 times
Been thanked: 392 times
SST 1.4 & ti
Post by CNHSS1 » Sat Dec 14, 2019 9:37 am
Craig, but close... :wink:
Geraint SabreGTCse5
SST 1.4 & ti
Post by Geraint SabreGTCse5 » Sat Dec 14, 2019 10:24 am
sorry Craig ... codeine, left hand typing and predictive text are not a good combination.... I dread to think what I have ordered on line over the last few days :D
Geraint
SST 1.4 & ti
Post by CNHSS1 » Sat Dec 14, 2019 10:53 am
Im sure youll be fine Geraint, every man can find a use for a parrot, Tutu and left handed scissors... :lol:
Has thanked: 33 times
Been thanked: 51 times
SST 1.4 & ti
Post by Alan SS1 » Mon Dec 16, 2019 12:44 pm
like trim the tutu to fit the parrot ? :wink:
hope shoulder injury doesn't put you oot o action for too long, speedy recovery. . . .
