G130 YCF sprint car
Dcrosby13
Been thanked: 138 times
G130 YCF my first sprint car
Post by Dcrosby13 » Mon Jul 23, 2018 3:56 pm
ah ok have you got any pictures of the bit that needs drilling?
I break stuff...... :w
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 3:57 pm
I take it the rolling road dude will be doing the afm, timing and boost adjustment? im going to try and book it into the place in middlewhich.
Post by swoakes » Mon Jul 23, 2018 3:58 pm
Don't remember touching the AFM on the Sabre when we fitted the bleed valve :?
Has thanked: 594 times
Been thanked: 519 times
Post by CNHSS1 » Mon Jul 23, 2018 4:08 pm
AFM can be adjusted to offer a little more fuelling
Has thanked: 378 times
Been thanked: 266 times
Post by Corky » Mon Jul 23, 2018 4:13 pm
It’s not a necessity, just another tool if it’s found to be lean.
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 4:15 pm
Thanks guys, I might aswell remove the cover just incase the rolling road dude wants to fiddle with it.
Post by Corky » Mon Jul 23, 2018 4:18 pm
You need to drill out the blanking plug too. Needs to be done carefully on the bench.
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 4:19 pm
I have a spare afm so I will trial it on that first.
Post by CNHSS1 » Mon Jul 23, 2018 4:23 pm
The fuelling is the limiting factor to how much "Grin" pressure you can run :wink:
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 4:26 pm
righto, I will grab an adjustable fuel regulator too, I take it the old one will need to be removed in order for this new one to work?
Post by Corky » Mon Jul 23, 2018 4:38 pm
Needs cutting out and new one plumbing in with some R9 hose.
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 4:42 pm
sounds scary lol my cutting usually involves taking waaaaay too much off.
Post by Corky » Mon Jul 23, 2018 5:20 pm
If you’re looking for 160-170 BHP. I wouldn’t go to too much trouble. You can easily get that with a tweak of boost (10psi ish) and an intercooler. There’s always a risk it could go bang, but if you’ve only got a standard HG then that will probably act as a fuse.
If you’re looking for more. ie 180-200. Then you need to start looking at fueling, a performance cam etc. But if you just want to get out and enjoy it, save your pennies and run a safe 160bhp. This will still be a competitive spec.
The biggest gains in your first year are from seat time, not an extra 30bhp.
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 5:23 pm
I agree, the budget has already spiraled out of control :lol: I take it the maf and adjustable regulator are not required for 160? I have fitted cooler plugs and will be fitting the intercooler we have bought.
Post by Corky » Mon Jul 23, 2018 5:40 pm
Nice to have, but not essential for 160 BHP at around 8psi.
Get a good boost gauge and controller. The Turbosmart one is very good indeed. I don’t get any spikes with mine. Set it up for about 8 psi (about 10-15 clicks). Should be a good start point for the rolling road.
Don’t forget to add in a dump valve, as without one you could find the pressure can affect the throttle butterfly opening and closing in line with throttle.
