G130 YCF sprint car
Dcrosby13
Been thanked: 137 times
G130 YCF my first sprint car
Post by Dcrosby13 » Mon Jul 23, 2018 10:47 am
Cheers, my T2 is currently away being rebuilt, is there a preferred supplier for fuel pumps?
I break stuff...... :w
Post by swoakes » Mon Jul 23, 2018 10:56 am
Ebay specials are on most sprint cars
https://www.ebay.co.uk/itm/Universal-Ex ... SwofxUfQ7r
At that cost buy a spare and move the pump to an easier to reach location for quick change at an event if it fails (ask me how I know :roll: )
Has thanked: 129 times
Been thanked: 870 times
Post by philhoward » Mon Jul 23, 2018 10:59 am
All EFi fuel systems use a fuel pressure regulator, virtually all are mounted on the fuel rail.
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 11:02 am
Sorry I meant adjustable pressure regulator, thanks Steve I have ordered two of those. where are they mounted as standard?
Post by swoakes » Mon Jul 23, 2018 11:10 am
Pump is mounted on the inside of the chassis rail NS under the tank over the rear axle. A bit of a pain to get to in a hurry.
I've just moved ours to the rear of the tank but we don't have a lining in as we are Mod prod. I think Corky his moved his pump :?:
Oh and the "input" on the pump is bigger than the output so get yourself an in-line reducer for the connection to the tank
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 11:19 am
Thanks, I dont suppose you know what size the standard outlet is? also whilst the engine is out would it be worth dropping the sump and cleaning the oil strainer?
Post by swoakes » Mon Jul 23, 2018 11:26 am
5/16 hose will happily go on the pump output to the engine. The input pipe on the pump is 12mm I think and the output from the tank is 8mm I think. I bought a 12mm to 8mm reducer. Not fitted yet but plan to use a short section of 3/8 pipe onto the 12mm input of pump reducing to 5/16 for the tank connection. You damage a 5/16 pipe if you attempt to push onto the 12mm pump input :cry:
Oil strainer; if you have time do it....much easier off the car and you know its all good :)
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 11:31 am
Awesome, thanks again!
Has thanked: 113 times
Been thanked: 164 times
Post by reliant-reviver » Mon Jul 23, 2018 12:12 pm
As a G reg car you may well have the fuel feed from the tank underneath on a seperate lock ring insert. If so it will be a 12mm pipe
Post by swoakes » Mon Jul 23, 2018 12:32 pm
Your such an Anorak Mr R :wink:
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 3:42 pm
I will check this when I get home, thanks guys.
Has thanked: 589 times
Been thanked: 515 times
Post by CNHSS1 » Mon Jul 23, 2018 3:47 pm
If you drop the strainer, ensure the gasket to the pump is replaced or in perfect nick
Has thanked: 375 times
Been thanked: 265 times
Post by Corky » Mon Jul 23, 2018 3:48 pm
My Sabre was like that. 12mm pipe from underneath.
Be careful with boost until you've had it on the rolling road. There's a good chance you'll be under fueling without a fuel pressure increase and maybe a tweak to the AFM (You need to drill out the anti tamper blank to access the adjuster). I'm keeping mine at around 10psi, as it's still on a standard cam and pressure regulator. Good for 160BHP though, which seems to be reasonable on handicap.
Dcrosby13
Post by Dcrosby13 » Mon Jul 23, 2018 3:50 pm
Luckily I bought a full set of gaskets from Corky, I wont be touching the boost until it has been on the rolling road, what adjustments are required at the AFM end?
Post by Corky » Mon Jul 23, 2018 3:55 pm
It’s just a rich/lean adjustment screw.
