G130 YCF sprint car
Dcrosby13
Has thanked: 34 times
Been thanked: 103 times
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 2:22 pm
Yeah it was like having a pint of petrol thrown straight in my face lol, not nice.
I break stuff...... :w
Tinker man
Been thanked: 22 times
G130 YCF sprint car
Post by Tinker man » Thu Mar 12, 2020 3:18 pm
Keep going guys.. i read this thread as a source of inspiration and to remind myself how lazy i am once i get home from work. I am sure you will forget these "one step forward two steps back" moments once completed.
a short story to hopefully make you smile...
the petrol in the face i sympathise with... a few weeks ago I was under the 6a replacing fuel lines. it was that long ago that i removed them that i forgot which pipe went to what connector on the tank. put small pieces of pipe on each connector. blew down one of them thinking i may hear bubbles therefore finding the "out" pipe. all that happened was petrol poured out of the other pipe as i was blowing down the return. and it poured straight into my ear. couldn't have been a better shot. so ear burning and petrol still flowing i had to try to stem the flow and race to the sink.. then a trip to local walk in center for a good flush out. dont try it at home. it stings and you smell for ages...
sorry for the digression...
good luck with the task in hand. Ian.
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 3:25 pm
Cheers Ian, it's nice to know that you are enjoying our escapades and yes as soon as we hear it run all will be forgotten.
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 5:45 pm
So we decided to pull the fuel rail and take a look at what was going on with cylinder number four injector, it turns out that the ECU was telling it to fire full bore whilst priming the fuel pump then full on when cranking which as you can see in this video is enough to keep a fleet of taxis running for a fortnight :lol: I called Omex and they acknowledged that they had sent me a configuration that deviated from the standard wiring diagram which is great as it means we hadnt done anything wrong and the injector is infact perfectly fine. was does bother me is that the engine has hydraulic locked a few times which we thought was ignition timing grrrr. anyway its sorted now, we need to put the induction side back together before trying to run it but atleast we got to the bottom of the problem.
https://youtu.be/P3EE0QCle-M
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 5:58 pm
We now 60psi compression on cylinder 4 because of this, really not happy with omex
Has thanked: 86 times
Been thanked: 725 times
G130 YCF sprint car
Post by philhoward » Thu Mar 12, 2020 5:58 pm
Naughty Omex...
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 6:11 pm
Getting close to throwing the towel in
G130 YCF sprint car
Post by philhoward » Thu Mar 12, 2020 7:02 pm
Got a Megasquirt and loom ready to go here. Doesn’t do sequential or launch or boost control but makes an engine work..
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 7:20 pm
Cheers man, it's not the ecu that's the problem now we are down to 60psi on cylinder 4
Has thanked: 211 times
Been thanked: 113 times
G130 YCF sprint car
Post by efi_sprintgte » Thu Mar 12, 2020 7:20 pm
Clear head and a fresh start and you will get there.
G130 YCF sprint car
Post by philhoward » Thu Mar 12, 2020 7:22 pm
Bugger - just seen your FB post..
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 7:25 pm
We are leak testing at the moment
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 7:32 pm
Been thanked: 78 times
G130 YCF sprint car
Post by Old and Slow » Thu Mar 12, 2020 7:38 pm
You've got loads of supporters out here on the Forum, waiting for a positive outcome of all your trials and tribulations.
Fingers crossed you'll get there soon.
Keep the faith.
Philip
Dcrosby13
G130 YCF sprint car
Post by Dcrosby13 » Thu Mar 12, 2020 8:10 pm
Cheers man, the support is greatly appreciated.
