SST H993WGF
Has thanked: 285 times
Been thanked: 235 times
SST H993WGF
Post by CNHSS1 » Tue Aug 28, 2018 9:58 am
No issue with running the bluebird engine, its the same engine barring the dizzy position and the crackle finish rocker cover ( a few factory Tis had the black rocker cover).
Dizzy extraction and accurate 're fitting is a PITA though.
The Walkers Sabre racer used the bluebird head btw
scimmy ben
SST H993WGF
Post by scimmy ben » Tue Aug 28, 2018 11:30 am
Bluebird head is great for top mounting a massive turbo though!
Has thanked: 80 times
Been thanked: 123 times
SST H993WGF
Post by reliant-reviver » Tue Aug 28, 2018 11:45 am
Great minds think alike Ben. I refer to my earlier comments yet again -
reliant-reviver wrote:
Tue Jul 17, 2018 3:56 pm
Still. That bluebird turbo engine is begging for a big top mount turbo.
Would make a fantastic track car....
Been thanked: 562 times
SST H993WGF
Post by philhoward » Tue Aug 28, 2018 11:48 am
I think that's probably why the Walker Sabre used one..but it wasn't exactly standard!
As to why twin spark engines seem to be around - back in the 90's, there were a glut of "low mileage" Japanese engines flooding the market (Heathrow Engines being one name I recall) - you got a CA18ET engine, but no clue what it came from hence some from the S12, some from the Bluebird, and possibly some other JDM only creations. I've seen twinspark ones with plugs fitted (and no leads) or brass blanks (the yellow ex-Reliant factory hack Sabre had these) but I think the base casting was the same so has the space for the plugs, but maybe not machined (I don't recall if the combustion chamber differed though).
SST H993WGF
Post by CNHSS1 » Tue Aug 28, 2018 12:35 pm
Chambers the same visually, I think the twin spark was listed as a lower comp ratio but give the head chamber is the same and the pistons are the same it's either a misprint or the blanking plugs/second set of spark plugs reduced the CR a Gnats gooley...
SST H993WGF
Post by philhoward » Tue Aug 28, 2018 12:46 pm
There might be a couple of cc's liberated by the gap between the electrode and body, I suppose?
Has thanked: 120 times
Been thanked: 891 times
SST H993WGF
Post by scimjim » Tue Aug 28, 2018 12:47 pm
Single spark have the bosses for the second set of plugs (does it have a boss for the “rear” mounted dizzy?) - I’m surprised they made more than one casting and this one doesn’t have the dizzy side mount (even an undrilled boss)
SST H993WGF
Post by CNHSS1 » Tue Aug 28, 2018 1:11 pm
Haven't got one to hand, but yes the bosses for the 4 secondary plugs are there on the 4 plug heads, so a spark plug would add to head volume a whisker
SST H993WGF
're the rear mount dizzy, there's a blanking plate at the rear of the head iirc, but not sure the std cam has a dizzy drive?
SST H993WGF
Post by scimjim » Tue Aug 28, 2018 1:24 pm
I don’t think the blank is dizzy hole shaped though is it?
Has thanked: 155 times
Been thanked: 163 times
SST H993WGF
Post by Corky » Tue Aug 28, 2018 1:43 pm
For a simple access hole to the cam retaining bolt, it’s a bit over thought if you ask me :lol: Maybe it’s designed to take a mount for a dizzy perhaps?
If you get chance Mark, I’d like to see some more photos of the engine and maybe the cam. It’d be interesting to see if the RWD dizzy mount exists and if the cam has an unused drive gear on it.
Been thanked: 98 times
SST H993WGF
Post by gtcse8 » Tue Aug 28, 2018 7:14 pm
Ok Steve
Will be on Sat tho.
There is no evidence of a dizzy mounting casting on the side of the head.
Will get the cover off and see if the cam has other gears cut into it at the front.
RE a bigger turbo, one of the lads was suggesting that on Sunday, but I don`t think it will happen if its gonna cost money for a new casting and all the plumbing alterations involved.
SST H993WGF
Post by CNHSS1 » Tue Aug 28, 2018 8:49 pm
Walkers Sabre
SST H993WGF
Post by gtcse8 » Tue Aug 28, 2018 9:11 pm
Rather large turbo methinks.
SST H993WGF
Post by CNHSS1 » Tue Aug 28, 2018 9:37 pm
That was relatively small by what they tried, a T34 (essentially escort cosworth sort of turbo) rather than the rs500 T4 'Dinner Plates' that kept blowing up engines
