And so it begins
Has thanked: 199 times
Been thanked: 42 times
And so it begins
Post by willholderogri » Wed Mar 11, 2020 6:23 am
Old and Slow wrote:
Tue Mar 10, 2020 2:04 pm
Thanks, that sounds OK; the Missus has lots of bicarb in the cupboard - will work twice as good!! :?
I find it's alright as long as she does not catch me or ask where it's gone
manny
Has thanked: 41 times
Been thanked: 22 times
And so it begins
Post by manny » Wed Mar 11, 2020 6:35 am
Old and Slow wrote:
Sat Mar 07, 2020 10:03 pm
Yes, please tell us about the acid, and how you used it (immersing parts? / brush it on?)
Looks like good stuff, waste disposal might be an issue?
Good day
Just to add..I use white vinegar which gives similar results..with the added bonus it can be fed to the plants in the garden..
Ta
Manny
Steve_S
And so it begins
Post by Steve_S » Fri Mar 13, 2020 8:25 pm
So iv got the repaired parts fitted bolted ATM in the summer ill strip out the carpets and weld them but they have got to be 100% better than before.
The return end of the seat belt was trapped behind the inertia reel is this correct ? or should it be where iv put it in the picture ?
Also the rear seat wont fit correctly the reel covers are holding the seat off, I made the spacer but not having a pattern i guessed so it could be Iv made them to tall anybody got some dimensions ? and are they bolted through the carpets if that the correct positon
