The Doctors Coupe - SRE 353G
Has thanked: 86 times
Been thanked: 733 times
Post by philhoward » Sat Aug 25, 2018 12:34 pm
Ah...
Been thanked: 137 times
Post by BigBobPilot » Tue Oct 09, 2018 6:03 pm
Well, my coupe was 1st registered 50 years ago today.
Its odometer is on 116458 (having been round once), so only 2329 miles per year! I've only manged about 1000 miles in my 6 months ownership, so I'm a little off average, bearing in mind it will get less use over the winter.
SS1 CA18DET race car
Has thanked: 158 times
Been thanked: 1093 times
Post by scimjim » Mon Oct 29, 2018 9:39 am
Spotted in the car park at work :D
http://forum.retro-rides.org/post/2457094/thread
Post by BigBobPilot » Mon Oct 29, 2018 11:45 pm
:wink:
There was a tastey Rover SD1 Vitesse in the car park last week.
The Honda Prelude must be a daily driver, it's always around.
Has thanked: 339 times
Been thanked: 162 times
Post by MikeyBikey » Tue Oct 30, 2018 6:57 am
Do you two work at the same site then ?? :D
Post by BigBobPilot » Tue Oct 30, 2018 7:46 am
Me & who?
Post by MikeyBikey » Tue Oct 30, 2018 7:50 am
you and Jim ?
Post by scimjim » Tue Oct 30, 2018 9:48 am
No, the link I posted was taken by someone on retro-rides who works in the same place as Ben :)
Post by BigBobPilot » Sat Nov 03, 2018 5:34 pm
The nights are starting to get chilly and my coupe didn't have antifreeze in it, as I'd done some flushing & topping up a few times and the heater matrix started leaking (currently by-passed). I know it's needed for anti-corrosion, but I wanted to change a couple of pipes first, and just hadn'tgot round to it.
Although I changed most of the coolant pipes pretty soon after buying the car, there were 2 left to do, the water pump to bottom hose & the water pump to heater valve. With these whipped off, the block & rad were flushed with a hose again. The old pipes were ok really, but it doesn't hurt to have new ones.
Old & new:
Heater pipe:
Next it was filled up with antifreeze, then off for a spin to mix it all up & check there were no leaks.
I also changed the boot lid seal, as there was a little dampness in the boot. I got a length of seal from Woolies to do the SS1 door seals & the coupe boot. Having done the boot & 1 SS1 door, I'm thinking I've not ordered quite enough though.
I need to do something with the wing mirrors too. The passenger side bezel has looked a bit iffy for a while, but the glass looked like it was about to drop out, so I thought it would be best to remove it.
Does anyone recognise what these are?
The coupe isn't really being used at the moment and will be tucked away for the winter. I've got some jobs planned over the winter, going delving in to the heater matrix being one of them.
roymck
Has thanked: 15 times
Been thanked: 27 times
Post by roymck » Sat Nov 03, 2018 5:57 pm
Have you got 2 anti roll bars on there ?
Also no little switch that pops up the boot when you unlock it,they seem so random as some Coupes have them and some don’t.
Also did you replace the heater hose on the floor with a straight hose or did you make one up with 90dg bends at both ends ?
Post by BigBobPilot » Sat Nov 03, 2018 6:16 pm
Yes, doubled up anti roll bars. It was a period mod for a stiffening up the front roll.
The heater hose was replaced with straight silicone hose. Fine at the water pump, a little tight to the rocker cover at the top.
Been thanked: 65 times
Post by Nick » Sun Nov 04, 2018 10:04 am
Ben,
As I assume you realise the bottom rad hose is non standard with the ally rad.
I always felt the car handled very well, better than my old white one. Even with the extra roll bar felt pretty balanced.
Post by BigBobPilot » Sun Nov 04, 2018 3:46 pm
Hi Nick, yes I know the pipe to the rad is none standard. It was the hard pipe to the back of the water pump that I changed.
stewb
Post by stewb » Wed Nov 07, 2018 6:54 pm
Liking the coupe Ben, always really liked that car & discussed a few times with Nick about his long term plans for it. All that being said it appears you're very much making it your own & actually using it! Something which I seem to be unable to do at present....must try harder!
Not sure if the heater matrix is a one off or not but I've had a few (the last one I had made was MGB with 5/8" stubs rather than 1/2") by Motorads in Redditch. They're very good & even have a proper old school trade counter. They can make / repair what you have.
I have to say that all the talk of points, condensers & jets was a bit of a blast from the past! There is something quite nice about them though I guess, at least if something does fail you have a faint chance of getting it going at the roadside.
Is the SS1 totally in the shade now?
Stew.
Ex Owner of MK2 Scimitar Sabre CA18DET
'69 Tuscan V8 project which wasn't meant to be a project....
Capri 2.8 Injection Special
'09 GTM Libra - Honda K20 VTEC
"if you do something to be impressive rather than good, you're doomed" - Spen King
Post by BigBobPilot » Wed Nov 07, 2018 10:14 pm
Hi Stew,
The SS1 is close, I was having a push on it. However, having recently got myself a workshop; I've diverted to fixing the car that the coupe was supposed to replace... My Jag XJR 6 has been sitting with no MOT since the end of May. I was undecided whether to sell it for spares or repairs, or fix it. For some reason I've gone for the fix it route. Steel cars will never catch on though, they do seem to rust. It's in more than one piece at the mo. But once it's back together, the SS1 will go to the workshop and I'll get back on with that & the coupe will get tucked away in my garage, where the SS1 is currently residing.
Thanks for the tip on the heater matrix, I'm going to get it out before deciding what to do, there may be some heater improvements on the cards, along with a few other tweaks to the car, but the SS1 is back to the top of the list once the Jag is sorted.
