SE6a USM 99T
Tinker man
Been thanked: 21 times
SE6a USM 99T
Post by Tinker man » Tue Jun 05, 2018 9:01 am
small updates for the record.
new quick release battery terminal fitted to help me sleep at night with the car being in an integral garage. probably silly, but you never know.
multi earth terminal fitted on the battery Negative post too rather than one mass of connections. easy jobs, but needed doing. then found bonnet wouldn't shut.. doh! small bolt trim did the trick.
temperature sender lash up/fan thingy installed. separate post on this... just for your delight.
visit to GW carried out and new gearbox mount, exhaust rubbers and speedo cable purchased so these are next.
thanks, Ian.
Battery connections.jpg (147.29 KiB) Viewed 2340 times
temp switch thingy 2.jpg (145.63 KiB) Viewed 2340 times
Tinker man
SE6a USM 99T
Post by Tinker man » Mon Jun 18, 2018 11:43 am
gearbox cross member removed and new mount fixed in place. needed doing!
as with other posts on here the part supplied from GW was different to the one fitted but it all went together OK on the gearbox "stub" so was fitted. the metal channel profile was the same width just slightly shallower. not worried and has to be better than the one that came off. cross member was slightly bent from being in contact with the road at some point preventing the removal of one bolt. straightened, cleaned in parts washer and fresh POR15 applied.
old insert remained on the gearbox after cross member removal
gearbox mount 2.jpg (156.65 KiB) Viewed 2286 times
ready to be changed!
gearbox mount 3.jpg (168.4 KiB) Viewed 2286 times
Steel insert profile
gearbox mount.jpg (160.43 KiB) Viewed 2286 times
gearbox crossmember 1.jpg (91.95 KiB) Viewed 2286 times
speedo cable changed! after much confusion the right cable was ordered and fitted. they are different for manual and auto... needed child hands and 3 wrist joints to connect to the head unit, but got there.
check you have the right one next time!!
speedo cable gearbox end.jpg (105.93 KiB) Viewed 2286 times
exhaust clamps changed.
spot the old one for 5 bonus points...
spot the difference?
exhaust clamps.jpg (129.96 KiB) Viewed 2286 times
other jobs reversing lights... the switch appears broken after various tests and its part of the inhibitor. so probably just goint to wire in a toggle switch as its hard to remove and pretty expensive...
that's it for now, Ian.
Tinker man
SE6a USM 99T
Post by Tinker man » Mon Jun 18, 2018 11:48 am
oh, and the auto box filter changed and sump pan cleaned and covered in POR15.... new gasket fitted. hair full of ATF when the sump pan came off. no drain plug!?
auto box sump.jpg (131.53 KiB) Viewed 2286 times
thanks, Ian.
Tinker man
SE6a USM 99T
Post by Tinker man » Fri Jun 22, 2018 9:38 am
Just a quick note..
dropped the car off its ramps in the garage last night and had a quick check round before test run after the few jobs done.
after filling the auto box with new fluid (via the dipstick tube with an oil syringe (200ml each squirt!) off i went.
great news. I have a speedometer that works, a gearbox that doesnt jump around, no more fuel leaks at the tank, smoother changing gearbox, exhausts that dont rattle and a working reversing light albeit on a manual switch.
happy man, and able to do some motoring again.
hurrah! :D
Has thanked: 78 times
Been thanked: 707 times
SE6a USM 99T
Post by philhoward » Fri Jun 22, 2018 10:15 am
Nice work, Ian :D
Tinker man
SE6a USM 99T
Post by Tinker man » Sun Jul 01, 2018 4:14 pm
Afternoon all,
My first experiences of fuel vaporising this afternoon. Went for short run of about 3 miles. Parked up for 20 minutes and when came to leave car wouldn’t start. Fortunately I had my small mobile garage in the rear compartment. :D Air filter off, open throttle few times and no fuel.
Fuel line off from pump and suck. No fuel. Watering can on fuel line and mechanical pump. Suck suck suck . . Yuk, fuel! Pipe back on. Few cranks and fired up. Drove couple of miles home but soon as slowing down fueling issue again.
So driving with left foot braking and keeping 2000 rpm. (Auto). Home bonnet up. Blimey hot under there.
So reroute fuel line perhaps and maybe electric pump at tank. I assume that’s what it was as never had fuel problem since carb replacement and the mechanical pump looks almost new.
Good news it was fixed easily enough roadside, though could have done without it. It is very hot again today though.
Ian.
Has thanked: 155 times
Been thanked: 1052 times
SE6a USM 99T
Post by scimjim » Mon Jul 02, 2018 9:00 am
i doubt its vaporisation - to evaporate a float bowl full of fuel and all of the fuel lines would take hours. I’d suspect the pump first?
I was in Brighton over the weekend in 8 ball and it had a misfire which turned into lack of power and eventually cutting out (long story) but as part of the fault finding I whipped the top off the carb and the float bowl was full - after going up a long hill in first at 5000rpm I couldn’t touch the coil, thermostat housing or even the spare wheel tray as they were too hot and it was 31 degrees outside.
SE6a USM 99T
Post by philhoward » Mon Jul 02, 2018 9:11 am
Have you replaced ALL the rubber fuel hoses (including the one from the tank)? Only takes a hairline crack for the pump to suck air, not fuel (and not leak fuel out) which is more likely in hot weather.
Does the pump have sufficient gaskets fitted between it and the front cover? Should be quite a thick gasket (around 5mm from memory?) there which serves 2 purposes - provides some heat insulation and also sets the stroke of the pump correctly.
Tinker man
SE6a USM 99T
Post by Tinker man » Mon Jul 02, 2018 9:21 am
aah, i see....
thank you guys. i go on holiday today for 2 weeks so will investigate on my return the pump and its gasket situation. its a new pump (not installed by myself, so not sure).
lines dont leak and the rubbers look new, but again i didnt do them, so another relatively cheap fix even if it isnt broken... if you follow.
will also put on new fuel line clips at the same time. and then see what happens. at least i got it going again and home, without the lift of shame... :D
thanks again, Ian.
Tinker man
SE6a USM 99T
Post by Tinker man » Fri Nov 23, 2018 12:54 pm
its been a while but i have been using the car a little over the last few months with a few niggles one of which was the fact that the auto box sump was leaking after my filter and fluid change.
i couldn't find a torque setting for the gearbox sump bolts (is there one?) so just nipped up to 8ft/lb. it leaked... so checked levels (according to the documented process on here) and all was reasonably well and nipped up a little more. thought it was fixed but it wasn't.
so i have taken the sump off again and got a new gasket. i got covered in ATF both times so get fed up with that and have put in a sump drain plug now. pics below.... cut a little slot in the plug on the inside of the sump to allow some drainage. i have checked the mating surfaces and all seem reasonable (though the holes in the sump suggest some over tightening in the past). i will fit new gasket with some sealant and try again.
other than that the car is behaving OK with just the odd misfire after about 40 minutes running when at junctions/stationary... to be investigated, but feels like shortage of fuel (its a nuisance as with an auto its hard to rev at a junction without moving! or thumping it into gear! whereas a clutch you can at least rev the engine and slip the clutch).. maybe float height or something (its a new carb and i didn't check to be honest).
otter switch and new second hand radiator to fit. that's about all really on the urgentish list.
thanks, Ian.
sump plug 2.jpg (141.57 KiB) Viewed 1450 times
sump plug 1.jpg (156.34 KiB) Viewed 1450 times
Has thanked: 50 times
Been thanked: 259 times
SE6a USM 99T
Post by AJL Electronics » Fri Nov 23, 2018 1:15 pm
The sump gasket will settle, so you need to go around them a few times until it seals. I just use hand pressure rather than a specific torque, but 8Lbs sounds far too low to me. I would expect at least twice that.
SE6a USM 99T
Post by AJL Electronics » Fri Nov 23, 2018 1:19 pm
As suspected, the book says 12 to 16 Lbs ft.
Tinker man
SE6a USM 99T
Post by Tinker man » Fri Nov 23, 2018 1:56 pm
Brilliant AJL,
thanks very much for the assistance. hopefully have more luck this time round.
cheers :pint
Tinker man
SE6a USM 99T
Post by Tinker man » Sat Nov 02, 2019 4:32 pm
so with my 5a project started again at work my attention has turned to the 6a. sadly neglected on its ramps for a while now i have once again turned my attention to the fuel pump. after taking advice from above i realise that the fuel lines need some attention so i will get to those and i am still going to fit my electric pump. i have one at hand and a fuel filter and regulator. step one was to remove the old pump which was very new so suspect issues in its recent past. pump hasnt fixed it so very probably lines. whilst the pump was out i thought check the timing gears. very awkward to see what they are made of, so some pictures here. they are a bit rubbish but appreciate any thoughts on type. i dont know how the old style composite ones "look" in situ or how they "feel" when scratching at with a screw driver. this feels and scratches as if metallic. so is it steel do you think? also picture of the pump as new. hope they post. thanks, Ian.
https://photos.google.com/photo/AF1QipM ... uXBWF4Flyo
https://photos.google.com/photo/AF1QipP ... 5VYedB1OKu
https://photos.google.com/photo/AF1QipN ... _eSPs7Poz3
Tinker man
SE6a USM 99T
Post by Tinker man » Sat Nov 02, 2019 4:37 pm
hmm links not pictures? try again
fuel pump 6a.jpg (119.23 KiB) Viewed 424 times
timing gear 1.jpg (41.88 KiB) Viewed 424 times
timing gear 2.jpg (46.35 KiB) Viewed 424 times
timing gear 3.jpg (69.39 KiB) Viewed 424 times
