Coupe/ SAAB/ SE5 thing...
DarrylWebb
Has thanked: 70 times
Post by DarrylWebb » Wed Apr 25, 2018 6:38 pm
A bold plan with lots of shiny. Nice.
stevecrosby63
Been thanked: 14 times
Post by stevecrosby63 » Wed Apr 25, 2018 7:35 pm
overall width will be similar to the essex, but it depends on which inlet we use and where we run the downpipe, but space really doesnt seem to be an issue at the moment. height is ok as we have plans to modify the sump and gain a little more headroom and lower the block in the chassis, hence the unusual drivers side engine mount. all in all its a comfortable fit so far
Dcrosby13
Has thanked: 30 times
Been thanked: 89 times
Post by Dcrosby13 » Sat Apr 28, 2018 9:30 am
The gearbox mount having received some more bracing:
ImageIMG_20180426_175134 by Darryl Crosby, on Flickr
I break stuff...... :w
fightingtorque
Post by fightingtorque » Tue May 01, 2018 2:56 pm
This is great - been following the antics on FB for a while of course.
Gav
Dcrosby13
Post by Dcrosby13 » Tue May 01, 2018 9:30 pm
Cheers Gav, It should be back on its wheels in the coming weeks.
Dcrosby13
Post by Dcrosby13 » Wed May 02, 2018 10:04 pm
Another quick update, mostly we have spent every day working on fibreglass repairs, some progress made on pulling the LSD out of the Jaguar casing and dismantling the 4HA. We have even found the colour we want to use.
ImageIMG_20180502_173331 by Darryl Crosby, on Flickr
ImageIMG_20180502_163111 by Darryl Crosby, on Flickr
ImageIMG_20180502_161744 by Darryl Crosby, on Flickr
ImageIMG_20180501_165944 by Darryl Crosby, on Flickr
ImageIMG_20180429_194958 by Darryl Crosby, on Flickr
ImageIMG_20180429_135956 by Darryl Crosby, on Flickr
stevecrosby63
Post by stevecrosby63 » Thu May 03, 2018 8:28 am
i was a little peturbed yesterday. I made a lovely case spreader some months ago and it was 1/2" thick flat bar with the turnbuckles you can see in the pic...it wilted before it even moved the case!...so i had no choice but to get all agricultural on it, i just used what we had to hand which happened to be..........the cills from the 5 chassis !! :shock:
stevecrosby63
Post by stevecrosby63 » Thu May 03, 2018 8:32 am
to put it in perspective, the turnbuckle closest to me is m16
Has thanked: 24 times
Been thanked: 105 times
Post by Coupe Racing » Thu May 03, 2018 10:11 am
Luckily I didn’t need a spreader but it was tight
Dcrosby13
Post by Dcrosby13 » Sun May 06, 2018 10:47 pm
Turns out the Dana limited slip differential doesnt fit a 4HA so its back to the drawing board and I am looking to buy a Quaife differential.
Dcrosby13
Post by Dcrosby13 » Sun May 06, 2018 10:51 pm
However the rest of the build has moved on a little........
ImageIMG_20180506_201117 by Darryl Crosby, on Flickr
ImageIMG_20180506_201233 by Darryl Crosby, on Flickr
ImageIMG_20180506_201310 by Darryl Crosby, on Flickr
Been thanked: 129 times
Post by BigBobPilot » Sun May 06, 2018 11:17 pm
The Dana LSD does go in the 4HA, that's what most Scims out there use. Have you got the right Jag one?
SS1 CA18DET race car
Dcrosby13
Post by Dcrosby13 » Sun May 06, 2018 11:19 pm
Probably not then
stevecrosby63
Post by stevecrosby63 » Mon May 07, 2018 10:35 am
are you thinking of a power lok diff maybe ?
Dcrosby13
Post by Dcrosby13 » Mon May 07, 2018 6:27 pm
Now fully rolling
ImageIMG_20180507_150615 by Darryl Crosby, on Flickr
