Ben's SS1 - Ti Sprint Car
Has thanked: 327 times
Been thanked: 157 times
Post by MikeyBikey » Sun Sep 29, 2019 7:35 pm
Yes, well done. I must admit I had those yellow mounts on my essex but managed to break them....
Has thanked: 78 times
Been thanked: 707 times
Post by philhoward » Sun Sep 29, 2019 8:12 pm
Nice work, Ben! Good to confirm your suspicions that the clutch might have been on borrowed time?
Benc
Has thanked: 94 times
Been thanked: 52 times
Post by Benc » Sun Sep 29, 2019 9:28 pm
Yes Phil, tbh with the front of the car completely removed it makes the job easy. My garage door is one of those sectional inward opening jobbies so I haven’t got loads of head room with it open, I wouldn’t of been able to raise the crane high enough to get the dangle angle to get the engine out over the nose etc
Benc
Post by Benc » Sat Oct 05, 2019 12:56 pm
Rebuilding started run into a few problems new poly engine mounts mean engine is a bit higher than when on the original mounts...
Front crossmember fowls on treble front pulley and exhaust down pipe which was already rubbing on the chassis now too short.
New down pipe being made next week.
Wanted add on forum for a front Auxiliary belt pulley
Dcrosby13
Has thanked: 30 times
Been thanked: 89 times
Post by Dcrosby13 » Sat Oct 05, 2019 12:58 pm
those mounts look much thicker than the ones I bought, if your making a new downpipe you might aswell chuck a T25 on it :twisted:
I break stuff...... :w
Benc
Post by Benc » Sat Oct 05, 2019 3:26 pm
Yes the mounts are 44mm tall and looking at the old mounts they are 35mm ffs
Dcrosby13
Post by Dcrosby13 » Sat Oct 05, 2019 4:12 pm
The ones I bought are almost stock height and are dirt cheap
Benc
Post by Benc » Sat Oct 12, 2019 12:41 pm
Normal engine height resumed
Anyone want these cheap?
Has thanked: 428 times
Been thanked: 370 times
Post by CNHSS1 » Sat Oct 12, 2019 1:09 pm
BC Flatchat might want them Ben, he was looking for his.coupe rebuild
Dcrosby13
Post by Dcrosby13 » Sat Oct 12, 2019 4:03 pm
which ones did you buy in the end Ben?
Post by CNHSS1 » Sat Oct 12, 2019 6:18 pm
Regarding the mounts, i ran ford ones with 8mm fibre spacer plate to get engine to oem position,
Benc
Post by Benc » Sat Oct 12, 2019 7:50 pm
35mm tall heavy duty escort mounts
Front treble pulley is about 5mm clear
https://www.rallydesign.co.uk/product_i ... 2pgjvrn686
Benc
Post by Benc » Sun Oct 13, 2019 5:09 pm
Bit more progress today
Got to finish plumbing in the new radiator
Fit intercooler
New shocks
Finish wiring
battery install
Body work
Etc
Has thanked: 295 times
Been thanked: 229 times
Post by Corky » Sun Oct 13, 2019 6:53 pm
Looking good matey. Have you done the lift motor delete?
Benc
Post by Benc » Sun Oct 13, 2019 7:50 pm
Not yet but I have the broken one stripped to trial.
I was thinking to turn 2x bar threaded at one end fit to the front armature and the bit that goes on the motor crank would fit on the other end of the bar.
Just need to think of a quick release etc
Other option could be to strip the guts of the motor...
