Benc
Has thanked: 39 times
Been thanked: 21 times
Post by Benc » Sat Nov 25, 2017 8:27 am
Steve they do I was really happy with the grip performance etc.
There were a few casualties....
Has thanked: 264 times
Been thanked: 228 times
Post by CNHSS1 » Sat Nov 25, 2017 10:07 am
Glad you enjoyed it Ben.
club sprint & hillclimb championship starts in April :mrgreen: be ideal motor to have a go in, just saying :mrgreen: :mrgreen:
Benc
Post by Benc » Sat Nov 25, 2017 5:34 pm
Craig I'm definitely in for 2018 can't wait.
I had to run with nearly a full tank or I got fuel starvation issues exit of a couple of corners, 1/2 full tank. Returning the tank to full sorted the problem.
Tank is standard, single pump and filter. Likely I will fit a cage so a new tank needed can fit some baffles etc
What is the correct fuel flow, pressure etc any recommendations on pump(s) / filter(s) for sprint / track running?
barry_bryan
Post by barry_bryan » Sat Nov 25, 2017 6:31 pm
well done top marks for all your effort you put in.Regards Baz
Barry Bryan
Has thanked: 192 times
Been thanked: 99 times
Post by MikeyBikey » Sat Nov 25, 2017 7:37 pm
Great stuff and brilliant way to shake the car down. OOC Where was the track day?
Benc
Post by Benc » Sat Nov 25, 2017 8:05 pm
Oulton Park a few pictures :D
Benc
Post by Benc » Sat Nov 25, 2017 8:08 pm
A few more pictures and should have a few videos Monday
Has thanked: 147 times
Been thanked: 155 times
Post by Corky » Sat Nov 25, 2017 8:28 pm
The standard fuel pump is plenty man enough for over 200bhp, so I wouldn’t worry about that. But you can cure the fuel starvation by adding a swirl pot and LP pump.
td99
Been thanked: 22 times
Post by td99 » Sat Nov 25, 2017 9:46 pm
Nice to see SS1 taking Porsche!
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Post by CNHSS1 » Sun Nov 26, 2017 9:40 am
Std pump was good enough for 282hp on Batmobile 😁
Benc
Post by Benc » Sun Nov 26, 2017 10:00 am
Ok I'm thinking then that it's not the pump but pick up of fuel/ sloshing but happened when half full.
I fitted a filter just after the pump i.e. On the discharge side, should it be on the suction side or doesn't it matter?
Looking at the diagram the fuel comes from a pipe with filter on end through the mid point of tank on sender.
Will use some more fuel on road and investigate.
Post by Corky » Sun Nov 26, 2017 10:14 am
Fuel filter is on the high pressure side of the pump. The tank pickup is a dip tube off the fuel sender, so a low fuel level under hard cornering would explain the issue. You’re unlikely to see this on the hills, but you will at places like Anglesey and Aintree.
A swirl pot will fix the issue. Low pressure pump and pot can be bought quite cheaply. Have a look at my Sabre thread, there should be some photos of the pot and pump I fitted along with the relayed wiring switched from the ECU.
Benc
Post by Benc » Sun Nov 26, 2017 10:47 am
Cheers Steve I'll have a gander.
Benc
Post by Benc » Fri Dec 29, 2017 1:07 pm
Ok so have progressed a few jobs on the ss1 :D
After doing the track day my helmet was often touching the soft top support hoop so a bit of floor lowering in pictures
Removed seat and cut out floor with Aldi air saw
Then cut out the old rails
Old rail mocked up, going to fold some 3mm sheet into channel 45x30 on Tuesday
Fitted harness eyes behind seat
Race license form filled in
Fuel tank ready for removal and roll bar also coming out and will be for sale fresh powder coated and harness bar welded
That's it for now folks best wishes for 2018
Post by Corky » Fri Dec 29, 2017 1:18 pm
Blimey ! You've been busy :D
Well done.
