Has thanked: 23 times
Been thanked: 85 times
Post by swoakes » Fri Nov 10, 2017 4:34 pm
CNHSS1 wrote:
Fri Nov 10, 2017 4:16 pm
Hasn't been scrutineered at Anglesey or Aintree...
Just Aintree to worry about now thankfully :roll:
Has thanked: 147 times
Been thanked: 155 times
Post by Corky » Fri Nov 10, 2017 4:39 pm
If it's on the calendar
True, but I thought that only mattered for Steve O :lol:
Benc
Has thanked: 39 times
Been thanked: 21 times
Post by Benc » Fri Nov 10, 2017 6:13 pm
I was leaving it there on the basis it had passed before but get the feeling I should move it.
If it is going on the floor in front of the seat is ok fixed to the GRP floor perhaps with some spreader plates?
Has thanked: 264 times
Been thanked: 228 times
Post by CNHSS1 » Fri Nov 10, 2017 6:20 pm
How So?
Post by Corky » Fri Nov 10, 2017 6:31 pm
Steve’s mate doesn’t do Anglesey anymore.
Post by Corky » Fri Nov 10, 2017 6:33 pm
It should be OK fixed through the GRP floor. Put some big washers on the underside.
Post by swoakes » Fri Nov 10, 2017 7:30 pm
Yeah I was gutted :)
Post by CNHSS1 » Fri Nov 10, 2017 8:16 pm
Ah I see, won't be the same without your 'Mate Mr Oakes :lol:
Post by swoakes » Fri Nov 10, 2017 8:28 pm
Your right.....it was much better ;)
Benc
Post by Benc » Sun Nov 12, 2017 9:42 am
Thanks for posting the picture / comments on using the front chassis bolt Craig andJim.
I took the nose cone and rear shroud off to reaveal the bolts. If using that bolt then looks like a large hole / slot is required in the nose itself. The metal on the front is a bit thin
I was thinking of making a flat plate which picks up the rear chassis bolt and the 2 from the towing eye plate this then would put a bolt near the original opening in the nose probably need to make the triangle hole square?
Been thanked: 63 times
Post by BigBobPilot » Sun Nov 12, 2017 11:41 am
A couple of spreader plates will be better than washers, as the load is spread across a much larger area of the GRP. You don't want it to be flying around the cabin if it pulls through. A couple of strips of aluminium underneath the floor will do the job without adding much weight and are no more difficult to fit than some washers (once the holes are drilled at least).
It does look high up behind the seat in your photo (not nice to hit you in the back of the head), but getting weight down as low as possible also aids performance and as Steve says, put's it within reach of the drivers seat too.
SS1 CA18DET race car in build
Benc
Post by Benc » Sun Nov 19, 2017 2:34 pm
Chaps quick question does the nose cone fit on top of the top fixing brackets or below them?
Has thanked: 75 times
Been thanked: 118 times
Post by reliant-reviver » Sun Nov 19, 2017 4:33 pm
The corner mountings projecting from the armature tubes?
Over the top. And over the top of the rad shroud.
Benc
Post by Benc » Fri Nov 24, 2017 9:37 pm
First track day in car was really pleased with the performance and handling. Only issue was fuel starvation symptoms hard cornering with the tank 1/2 full, trip to petrol station and £30 in then no issues...😀😀😀
Post by Corky » Fri Nov 24, 2017 9:54 pm
Brilliant !
They go well don’t they :twisted:
