SS1-C686CCR
Has thanked: 191 times
Been thanked: 104 times
SS1-C686CCR
Post by efi_sprintgte » Sat Feb 16, 2019 8:15 pm
Cool 8)
Has thanked: 155 times
Been thanked: 1051 times
SS1-C686CCR
Post by scimjim » Sun Feb 17, 2019 7:37 pm
Filled diff and gearbox and fitted rear ARB (still needs drop links).
Converted LH door to manual windows and fitted - then realised that the outer handle was broken :twisted:
door still opens, so it’s staying for now :D
sorted LH seat and got the sheared bolt out of the floor, just need new bolts to secure the seat.
So as of today, the list to make test day looks like this:
Finish off RH steel floor
Fit RH seat and harness
Remove Spax adjustable rear dampers from Megan3 and fit to C686
Fit steering rack bellows
Fit track rod ends
Fit calipers
Bleed brakes
Fit wheels
Secure battery tray
Convert RH door to manual windows
Fit RH door
Repair or replace indicator stalk
Fit stalk, shroud and steering wheel
Fit fuel pressure regulator and plumb in fuel pump
Fit rear ARB droplinks
Fit bootliner
Fit bootlid
Fit headlight panel
Fit nose cone
Fit bonnet
Fit hardtop (swap glass sunroof in blue hardtop for Perspex or use red hardtop)
Check geometry
MOT (optional)
SS1-C686CCR
Post by scimjim » Sat Feb 23, 2019 5:44 pm
Phil came down to assist today, so we got the calipers fitted and bled the brakes :D
Floor is done and both seats are in, battery tray is secured and RH door is converted to manual (twice, the first winder I fitted wa U/S :evil: )
Relpaced the indicator stalk (I now have 2 or 3 that need repairs to the clamp) and refitted the shroud and steering wheel.
So, jobs for tomorrow include:
Fit track rod ends
Fit wheels
Fit RH door
Fit bootliner
Fit bootlid
Fit headlight panel
Fit nose cone
Fit bonnet
Check geometry
MOT (optional)
SS1-C686CCR
Post by scimjim » Sun Feb 24, 2019 7:24 pm
Spent most of today chasing electrical problems with the headlights. Eventually sorted enough for an MOT (no headlamp motor function) after taking the steering wheel off and the cowl apart for the third time :twisted:
Fitted the RH door though, as well as the nose cone and headlight panel.
Has thanked: 32 times
Been thanked: 51 times
SS1-C686CCR
Post by Alan SS1 » Tue Feb 26, 2019 12:59 pm
looking good but Oz mode for photos????
Has thanked: 24 times
Been thanked: 105 times
SS1-C686CCR
Post by Coupe Racing » Wed Feb 27, 2019 4:54 pm
Testing the roll hoop :D :D :D :D
SS1-C686CCR
Post by scimjim » Wed Feb 27, 2019 6:20 pm
Are they the right way round now?
SS1-C686CCR
Post by efi_sprintgte » Wed Feb 27, 2019 6:54 pm
They are for me
SS1-C686CCR
Post by Coupe Racing » Fri Mar 01, 2019 8:13 am
Yes ok now
SS1-C686CCR
Post by Alan SS1 » Fri Mar 01, 2019 12:52 pm
aye all is good :wink:
I do like Reliant's method of build/ stock control, large felt pen written on the panels, beats any fancy 'JiT' system . .. . :shock:
SS1-C686CCR
Post by scimjim » Sat Mar 02, 2019 5:48 pm
Had the dash back out again - firstly to get an ignition feed to the rear heated screen wire, to power the fuel pump. After putting it all back together, the Rev counter didn’t work :evil: swapped it and it still didn’t work, so I ended up swapping out the complete flexible circuit board.
Fitted the Spax adjustable but the rear is far too high, so more work needed there.
Fitted the bonnet (had to adjust the hinges and the locks!) and wiper blade.
Fitted the fuel pump and plumbing.
Fitted the the boot liner and bootlid.
Made a Perspex sunroof - just need to seal it down
Jobs left now:
Fit track rod ends
Seal sunroof down
Check geometry
MOT (optional)
Has thanked: 295 times
Been thanked: 228 times
SS1-C686CCR
Post by Corky » Sat Mar 02, 2019 6:02 pm
If you open that blue door, is there a room beyond?
Rattling
SS1-C686CCR
Post by Rattling » Sat Mar 02, 2019 6:19 pm
2qs photo of plumbing from sender going the opposite way to standard ? And is that a standard pump ? :D
Colin
1800 Ti
SS1-C686CCR
Post by scimjim » Sat Mar 02, 2019 7:05 pm
The radiator is from a VW Polo - I have one fitted to G97 and similar fitted to Megan3 and snotty (with inlet/outlet on the RHS for the K series/Ti).
CVH has a mechanical pump as standard.
SS1-C686CCR
Post by scimjim » Sat Mar 02, 2019 7:09 pm
thats the “lucky” door - last time you saw it was here
