SS1-C686CCR
Has thanked: 86 times
Been thanked: 733 times
SS1-C686CCR
Post by philhoward » Sat Mar 07, 2020 6:58 pm
The tunnel is part of the chassis - think Lotus Elan..
I’ll try slotting but I made them out of 60x60 box section and about 25mm out..
stevecrosby63
Been thanked: 23 times
SS1-C686CCR
Post by stevecrosby63 » Sat Mar 07, 2020 6:59 pm
Bugger...feeling your pain mate ...it will get there though 8)
SS1-C686CCR
Post by philhoward » Sat Mar 07, 2020 7:00 pm
They also too close together - think I measured to the wrong place..
stevecrosby63
SS1-C686CCR
Post by stevecrosby63 » Sat Mar 07, 2020 7:03 pm
those elastic tape measures should be banned ..
SS1-C686CCR
Post by philhoward » Sat Mar 07, 2020 8:03 pm
Using bob lines when it’s swinging from an engine crane is probably the main cause.
Either that or I didn’t put my glasses on 8)
Has thanked: 216 times
Been thanked: 116 times
SS1-C686CCR
Post by efi_sprintgte » Sat Mar 07, 2020 8:32 pm
We’ve all been there. The RB25 was made to fit the original 5a chassis mounts, somehow I didn’t factor in the crank pulley... So now my chassis has another set of mounting points welded on anyways :roll:
Has thanked: 339 times
Been thanked: 162 times
SS1-C686CCR
Post by MikeyBikey » Sat Mar 07, 2020 9:21 pm
Phil, keep at it with engine mounts, I did several attempts and used lasers but eventually got there and it’s been fine.
The clutch cable conversion is great, never thought of that , converts pull into push.
What did you use for the fuel line, I’ve got 8mm copper pipe as a supply, and 6mm for the return, but it’s a phaff getting the 8mm layed up as it’s stiff.
SS1-C686CCR
Post by philhoward » Sat Mar 07, 2020 9:28 pm
I just use nylon line for fuel - always have done.
SS1-C686CCR
Post by philhoward » Sun Mar 08, 2020 6:11 pm
Today’s report is brought to you courtesy of Warsteiner (660ml) and a good nights sleep.
Just out of interest I decided to change my point of reference. Start with the propshaft, leave a bit of movement in the yoke (there shouldn’t be any movement to be fair) and see where the engine and box fits fore and aft. Sat on a jack (rather than the crane), the engine mounts don’t actually look too bad.. so if I bolted them to the chassis, how far out are they on the engine?
Actually very close..close enough to open out a couple of holes and it’s almost there..
Has thanked: 309 times
Been thanked: 233 times
SS1-C686CCR
Post by Corky » Sun Mar 08, 2020 6:16 pm
Things always look better after a few drinks...... :lol:
Has thanked: 158 times
Been thanked: 1093 times
SS1-C686CCR
Post by scimjim » Sun Mar 08, 2020 6:19 pm
Excellent.
SS1-C686CCR
Post by efi_sprintgte » Sun Mar 08, 2020 6:32 pm
This is why large penny washers feature in nearly all my fabribodging...
Has thanked: 104 times
Been thanked: 154 times
SS1-C686CCR
Post by reliant-reviver » Sun Mar 08, 2020 6:35 pm
So is it just the shocks that are causing clearance issues now?
Why not just adjust the mountings forward a la the Sabre k series.
SS1-C686CCR
Post by philhoward » Sun Mar 08, 2020 8:11 pm
Now that’s the bit that’s confusing me - I get the same clearance between the front pulley and the damper mounting points on both a CVH and K Series crossmember.
Someone (CNH?) raises this on the crossmember. This however raises 2 questions:
1) will the dampers be worried about a few more degrees closer to horizontal?
2) is that classed as a change to suspension mountings and possibly incur the wrath of a particularly astute scrutineer?
SS1-C686CCR
Post by philhoward » Sun Mar 08, 2020 8:13 pm
Now to weld them to the other bits so they become structural instead of just packers :mrgreen:
