SS1-C686CCR
Has thanked: 155 times
Been thanked: 1052 times
SS1-C686CCR
Post by scimjim » Thu Apr 13, 2017 8:49 pm
I bought this car last September but didn't have room in the workshop because I was doing an engine change on DJs TD4 Freelander, then I gave the space to Rev Light to change his 5a timing gear and fettle for MOT over winter.
Luckily Phil Howard had a space on his driveway :D
Although we didn't expect it to be there for 7 months :mrgreen:
So last weekend I dragged it home and today I took the seats out to dry everything out and properly assess it
The soft top is toast :D
And the engine bay has seen better days
SS1-C686CCR
Post by scimjim » Thu Apr 13, 2017 9:03 pm
The observant will notice the lack of a cambelt - apparently it failed several years ago leading to the long layup. A quick check showed that the water pump had siezed, stripping some of the cambelt teeth.
The more observant may notice the drain plug in the head - this engine was apparently a replacement but under one of the seats was a form from Ford Power Products!
Re: SS1-C686CCR
Post by scimjim » Thu Apr 13, 2017 9:07 pm
So, the plan is to get it back on the road and sell on. Hopefully a replacement head will get it up and running, then some seats, a hood and a set of decent wheels and tyres. I don't plan on doing too much with the paint at this stage, concentrating more on mechanicals first. Bushes, brakes, suspension and steering, then dash out to go through the electrics properly.
This won't be a quick turnaround, I have too many other projects on the go, so expect to see this advertised in 12 months or so.
Has thanked: 78 times
Been thanked: 707 times
Re: SS1-C686CCR
Post by philhoward » Thu Apr 13, 2017 9:33 pm
You may have spotted the tide mark on the carpets - and also the 3mm hole in the drivers footwell?..
Re: SS1-C686CCR
Post by scimjim » Thu Apr 13, 2017 10:05 pm
Carpets will come out and get vaxed - they don't look too bad apart from the tide marks :-)
Been thanked: 129 times
Re: SS1-C686CCR
Post by BigBobPilot » Thu Apr 13, 2017 11:04 pm
Looks a peach Jim!
You obviously can't have too many SS1's?
SS1 CA18DET race car
Re: SS1-C686CCR
Post by scimjim » Fri Apr 14, 2017 9:52 am
And it's just 3 cars before Megan :-)
Re: SS1-C686CCR
Post by scimjim » Mon Apr 17, 2017 11:41 am
Guess which one has had regular oil changes :-)
Re: SS1-C686CCR
Post by philhoward » Mon Apr 17, 2017 12:00 pm
The one that had a cam belt change?
SS1-C686CCR
Post by scimjim » Mon Apr 17, 2017 12:30 pm
And water pump/tensioner :-)
So I have knackered my back this weekend so I'm just cleaning bits up today.
Found the engine number stamp and they've used the chassis number on the replacement engine (16 818) :-)
Edit - just checked and the database has it as 819 (they were actually nearly in sync with chassis numbers at that point) - I wonder what's on the V5C?
edit - 819 on the V5.
Re: SS1-C686CCR
Post by scimjim » Mon Apr 17, 2017 5:29 pm
Confirmed the chassis number - took me a while to realise that despite being galvanised, it doesn't have Ti engine mounts, so the chassis number is on the near side :-)
Re: SS1-C686CCR
Post by scimjim » Mon Apr 17, 2017 5:33 pm
Swapped the dizzy, tidied up the wiring
and fitted a new stat and fan switch as a matter of course
Re: SS1-C686CCR
Post by scimjim » Mon Apr 17, 2017 5:36 pm
NOS head gasket
Hoovered the carpets
And I'm £1.72 up :-)
Painted a few ancilliaries and left the engine bay looking like this
Re: SS1-C686CCR
Post by scimjim » Sat Apr 22, 2017 6:25 pm
Soggy engine mounts?
No more :-)
New exhaust studs
And nuts/washers
And slapped some paint around
Has thanked: 102 times
Been thanked: 153 times
Re: SS1-C686CCR
Post by reliant-reviver » Sat Apr 22, 2017 6:37 pm
I really feel those landy mounts need spacing. You can slice / burn the rubber off one old mount and knock the coach bolts out, leaves a good thick disc of steel the prefect size to space the mount out.
Or space the steel mounts away from the engine block.
