1982 GTC project gumtree
Has thanked: 112 times
Been thanked: 756 times
Re: 1982 GTC project gumtree
Post by scimjim » Mon Jul 10, 2017 9:37 am
I thought that all of the brake system on a GTC were metric apart from the rear wheel cylinders?
Post by greeny » Mon Jul 10, 2017 10:43 am
scimjim wrote:I thought that all of the brake system on a GTC were metric apart from the rear wheel cylinders?
Same as a 6a so its a bit of a mut.
Been thanked: 435 times
Post by Roger Pennington » Mon Jul 10, 2017 11:27 am
Yes, as I mentioned earlier, that was my understanding too.
ronnie
Banned User
Has thanked: 49 times
Been thanked: 37 times
Post by ronnie » Mon Jul 10, 2017 11:58 am
I can confirm Metric threads on Lockhead master cylinder and brake bias valve.
Just made new pipes up yesterday for my older S-reg SE6 and only found this out AFTER having fitted Imperial nuts for the brake bias valve !
Metric - Metric between the master cyl and brake bias
Metric - Imperial between brake bias and flexi pipes
ard126k
Post by ard126k » Mon Jul 10, 2017 12:38 pm
The changeover point on mine seems to be the flexi to the rear axle which is imperial.
1971 SE5 1977 SE6 1982 GTC
Post by scimjim » Mon Jul 10, 2017 12:50 pm
That's where I understood the change to be (on a GTC) - from Steve Cork's 404 thread. Metric threads were introduced as a rolling program according to a Reliant service bulletin.
Has thanked: 100 times
Been thanked: 116 times
Post by Corky » Tue Jul 11, 2017 3:32 am
Here are the only imperial connections on the system :-
And this is how the copper pipes look :-
Post by scimjim » Tue Jul 11, 2017 6:57 am
So basically the tee piece on the back axle is metric in and imperial out. Everything forward is metric, everything aft/outboard is imperial.
scimmy_man
Been thanked: 30 times
Post by scimmy_man » Tue Jul 11, 2017 9:05 am
scimjim wrote:That's where I understood the change to be (on a GTC) - from Steve Cork's 404 thread. Metric threads were introduced as a rolling program according to a Reliant service bulletin.
that means whichever bin we took the bits out of?
Post by scimjim » Tue Jul 11, 2017 9:18 am
Been thanked: 483 times
Post by philhoward » Tue Jul 11, 2017 11:37 am
My Dad had. 77 6a with a full Girling braked rear axle..
ard126k
Post by ard126k » Wed Jul 19, 2017 12:43 am
Small milestone reached today when I took the car down off its stands and moved it from the garage under its own power. A bit reluctant to go at first, but after I poured two pints of ATF into the box all was well and I seem to have at least one forward and one reverse gear. So that's a relief. I'll have a look at the rear brakes next I think, handbrake is useless and I'd better investigate the brake unions (!)
While I was getting ready to put the seat in place I noticed that only the driver's has a pressure sensor in it. Peter Freeman's wiring diagram shows both seats should have them, and the car has wiring for two, but the passenger one isn't there. I can't see any point in having a driver's one (there's generally a driver present, eh?) so I think I'll see if it's possible to move the sensor from one side to t'other. How hard can it be?
ard126k
Post by ard126k » Wed Jul 19, 2017 8:34 pm
Decided to have a look inside driver's door today to see why the inside latch lever was stiff. Think I found the reason -
Why would anyone route the linkage out through a slot in the door then back in through a hole next the lock? Answers please on the back of a blank cheque to me.
ard126k
Post by ard126k » Sat Jul 22, 2017 10:36 am
Wondering if the door mirrors are supposed to move smoothly? This one does a little jerk when I move the switch then stops. It gets there eventually but it's hardly elegant!
Post by Corky » Sat Jul 22, 2017 10:42 am
Depends which mirrors it's got. Some are smooth, some are jerky.
I think it's the type with the electromagnets that are jerky. The SS1 style move smoothly (ish).
