New purchase Se5
Stupopt1
New purchase Se5
Post by Stupopt1 » Mon Nov 13, 2017 1:34 pm
well I have been mad at it recently , much to the annoyance of my wife and neighbours probably .
new brackets and hand brake cable mount all tacked in place, my welder is not man enough to cope with this so going to get it welding up properly.
also got one side front suspension all rebuilt , poly bushes , new trunnion bushes, new bolts. I think look s great shame no one will see it all.
Scimitar Se5
Spitfire Mk4
Been thanked: 117 times
New purchase Se5
Post by DARK STAR » Mon Nov 13, 2017 5:45 pm
Looking very good!
MikeT
Has thanked: 21 times
Been thanked: 26 times
New purchase Se5
Post by MikeT » Mon Nov 13, 2017 9:48 pm
Yes, looks great. You can't beat a freshly painted and assembled suspension imo.
Mike.
toolmanchris
Been thanked: 29 times
New purchase Se5
Post by toolmanchris » Tue Nov 14, 2017 7:22 am
Front spring looks like it wont cope when the body is back on the chassis though :D
Chris Barker
http://www.toolmanweb.com
RSSOC: 4125
Seat Leon FR - daily driver
Has thanked: 283 times
Been thanked: 155 times
New purchase Se5
Post by efi_sprintgte » Tue Nov 14, 2017 7:50 am
Yep good effort!! :)
Stupopt1
New purchase Se5
Post by Stupopt1 » Tue Nov 14, 2017 8:31 am
Oh ! I thought the tie wrap was the answer to everything in the universe ever , tut that's another £500 i'll have to spend on shocks then :shock:
Scimitar Se5
Spitfire Mk4
toolmanchris
New purchase Se5
Post by toolmanchris » Tue Nov 14, 2017 9:12 am
lol :lol:
Chris Barker
RSSOC: 4125
Stupopt1
New purchase Se5
Post by Stupopt1 » Sat Jan 06, 2018 10:56 am
things have been moving on very slowly, so I have moved the Spitfire outside for a while so the Scimitar chassis is in the garage where I can work on it in relative comfort.
sorting out my rear axle has been a pain, and am currently having the half shafts machined to sort the threads out . The new brackets are now all welded on and painted up ready for new bearings and the halfshafts
I have managed to refurbish the heater matrix indoors whilst we have had the bad weather, so that ready to go back in
but now the chassis is in the warm and dry I have spotted a leak from the overdrive unit, see arrow below, can I unbolt the 4 nuts and slide this bit off so I can re seal it ?
Scimitar Se5
Spitfire Mk4
Stupopt1
New purchase Se5
Post by Stupopt1 » Mon Jan 08, 2018 8:40 am
well I decided to have a go at sealing the leak from the overdrive unit, undoing the 5 nuts and carefully tapping the casting off worked, I had removed the speedo drive first.
I wet and dried the end casting face on a flat board to take out any damage, it looked like someone had removed this previously but used a screwdriver to lever it off and put some very small dinks in the surface, but as this is a metal to metal fitting , it doesn't take much to make it leak.
I cleaned up the other surface as best I could around the bolts and put it back together with the smallest amount of gasket sealer , just to make a good seal.
re-fitted all the re-furbished rods to the gear change with replaced bushes too. Can't wait to get this thing back on the road and drive it.
Scimitar Se5
Spitfire Mk4
Has thanked: 369 times
Been thanked: 181 times
New purchase Se5
Post by MikeyBikey » Thu Jan 18, 2018 7:27 pm
impressive stuff....
Stupopt1
New purchase Se5
Post by Stupopt1 » Mon Feb 05, 2018 7:34 am
Finally got rear bearings shimmed properly and fitted the axle back on the chassis
tided up the original shocks , they will have to do for now, until funds allow
started fitting the front brakes and all new lines, had the calipers re-furbed at BIGRED
lovely Goodridge hoses
Scimitar Se5
Spitfire Mk4
New purchase Se5
Post by efi_sprintgte » Mon Feb 05, 2018 7:39 am
Looking good :)
Stupopt1
New purchase Se5
Post by Stupopt1 » Mon Feb 05, 2018 8:25 am
yes , it's just taking hours and hours, I have a deadline of July as I want to take it to Classic Lemans, so I am really up against it.
Scimitar Se5
Spitfire Mk4
Stupopt1
New purchase Se5
Post by Stupopt1 » Sat Feb 17, 2018 7:51 am
finally got the rear axle all buttoned up with new brakes and brake lines
and got the watts links all back together
prop shaft and fuel tank back in next, getting really close to getting the body back on , just got to replace the dreaded sill reinforcements, having them made in stainless, but not looking forward to fibre glassing them back in
Scimitar Se5
Spitfire Mk4
1969SE5
New purchase Se5
Post by 1969SE5 » Sat Feb 17, 2018 9:41 am
sill replacements are not as bad as you think, once you have committed and started cutting :)
