New purchase Se5
Been thanked: 561 times
New purchase Se5
Post by philhoward » Wed May 02, 2018 8:35 am
OK - that's the sender I suspected it was (fits all GTEs), so one of the terminals in the tubular sections will be the "variable" for the gauge, and one the on/off switch for low fuel level. There might not be a separate spade terminal on the body of the sender unit (or has been painted over :w ), so you might need to make a fresh one - a ring terminal under one of the 6 screws holding the sender unit in will suffice.
For reference, I'd say that was a Scimpart tank based on the octagonal securing ring as I fitted one myself many years ago.
Been thanked: 98 times
New purchase Se5
Post by gtcse8 » Wed May 02, 2018 10:01 am
I would get the correct length of Top bolts for the dampers or you will struggle to remove them, if needed, when the body is back on.
Cant remember proper length but the threads should only just show at the nuts.
Stupopt1
New purchase Se5
Post by Stupopt1 » Wed May 02, 2018 3:53 pm
:shock: the body is already on now
Scimitar Se5
Spitfire Mk4
Stupopt1
New purchase Se5
Post by Stupopt1 » Wed May 02, 2018 4:47 pm
would I be able to exchange this for a newer voltage regulator ? I already had to re-solder the capacitor back on and it doesn't look too good.
something like this
Scimitar Se5
Spitfire Mk4
New purchase Se5
Post by gtcse8 » Thu May 03, 2018 2:48 pm
Oooopps
Before the threads go rusty and make it difficult to remove I would just try remove one of the top bolts to check there is enough room to remove them, as it WILL be apita later.
Stupopt1
New purchase Se5
Post by Stupopt1 » Thu May 10, 2018 10:14 am
it looks o.k there is plenty of room to get these bolts out, I have a 5 so maybe the body moulding is different.
An update on the car, I ran the engine up nice and hot , the fan came on as it should , heater blowing hot and no leaks , so good news there.
fitted the new seat belts, all bolted through the chassis properly
put some sound deadening in the foot wells, haven't got any carpet yet.
and started fitting the door hinges, so I can get the doors on
hopefully be ready for a drive soon :D
Scimitar Se5
Spitfire Mk4
Stupopt1
New purchase Se5
Post by Stupopt1 » Mon May 14, 2018 5:20 pm
fitted the ally timing gear on the weekend, didn't want to risk driving to LeMans with the old fibre one, even though it looks to be in excellent condition.
also spent 3 hrs getting the rear lights to work re making earths etc. Now all good although side and brake lights are typical 70's and not very bright.
Scimitar Se5
Spitfire Mk4
New purchase Se5
Post by gtcse8 » Mon May 14, 2018 6:54 pm
I do a bulb holder conversion that earths all the bulbs separately.
Fix and forget, until a bulb actually fails
Stupopt1
New purchase Se5
Post by Stupopt1 » Tue May 15, 2018 7:24 am
ok thanks , but I soldered earth wires onto each holder, they are all working now , so fingers crossed it lasts
Scimitar Se5
Spitfire Mk4
Stupopt1
New purchase Se5
Post by Stupopt1 » Sat May 19, 2018 7:50 am
re fitted the roll bar end , which was badly corroded , I had cut a section of body out to get to it before I took the body off the chassis.
I've added another bolt, just took this pic before I had done it.
held the panel in place with clips
got it all fibre glassed in
Scimitar Se5
Spitfire Mk4
Has thanked: 86 times
Been thanked: 59 times
New purchase Se5
Post by efi_sprintgte » Sat May 19, 2018 8:20 am
Good effort!
Stupopt1
New purchase Se5
Post by Stupopt1 » Sat May 19, 2018 10:05 am
thanks, I seriously just want to get driving it now, almost there :D
Scimitar Se5
Spitfire Mk4
Stupopt1
New purchase Se5
Post by Stupopt1 » Tue May 22, 2018 6:57 am
first drive after being 'taxed & MOTed', first to go an fill up
then for a quick stop to make sure nothing was falling off on the way home
brakes were a little spongy so I re bled them, I managed to test the overdrive which is working fine. The tick over stays at 1000rpm and the engine is still a bit tappety so will have to do them again. Other than that a very successful first run in 8 years off the road.
Scimitar Se5
Spitfire Mk4
New purchase Se5
Post by philhoward » Tue May 22, 2018 7:33 am
Well done! :D
Has thanked: 120 times
Been thanked: 888 times
New purchase Se5
Post by scimjim » Tue May 22, 2018 8:51 am
Excellent :D
