Standard and leaving it that way Coupe
Been thanked: 106 times
Re: Standard and leaving it that way Coupe
Post by greeny » Mon Nov 28, 2016 12:04 pm
ScimmyMike wrote:Nice purchase Paul, bit miffed that the bloody thing has been under our noses at High Peak Noggin all the time, still it's another one the registrar wasn't aware of, hope to see it out and about sometime.
If things like this crop up near us I may need to go back onto face book!!! Or maybe not for the sake of my marriage!!!! :lol:
turbster
Has thanked: 75 times
Been thanked: 72 times
Post by turbster » Mon Nov 28, 2016 12:58 pm
Nigel Clark wrote:Lovely car, well done!
I think if it was mine (if only...), I'd be tempted to recommission, get an MoT and drive it for a bit before getting into major work.
Nigel
I was very tempted and that was the original idea; however yesterdays inspection revealed a small hole near the rear shocker mounting brackets and a few other places which need attention, so it's best to do a quick body off and do it properly. I would say the Coupe's an easy body off, and to be honest when you've removed 80 odd (mostly hidden) bolts from a Marcos and had to lift it to 45 degrees to get the body off, doing it on any Scimitar is a pleasure :roll: :lol:
LRP 335E SE4a
XRF 976H SE5
www.gtevolution.co.uk
turbster
Post by turbster » Mon Nov 28, 2016 1:00 pm
I think it's a one off so I'd stay away :lol:
LRP 335E SE4a
XRF 976H SE5
turbster
stevmale wrote:That Coupe looks good , well done Paul.
Maroon / dark red Scimi's in my opinion look the sharpest.
Cheers Steve, and you would say that!!
LRP 335E SE4a
XRF 976H SE5
Post by greeny » Mon Nov 28, 2016 1:21 pm
:lol:
Nigel Clark
Been thanked: 51 times
Post by Nigel Clark » Mon Nov 28, 2016 4:27 pm
Nigel
I can see where you're coming from with body off straight away. I'm all for doing things properly!
Nigel
fightingtorque
Post by fightingtorque » Tue Nov 29, 2016 2:56 pm
Keeping it standard...... I can imagine it starts this way and then we will see maybe some polybushes and a steel timing gear. Change cam while you are at it, maybe change the exhausts. Minor suspension upgrade. Different carb. Change the wheels. Change the brakes. Modified heads. Change the carb again................
turbster
Post by turbster » Wed Nov 30, 2016 10:48 am
fightingtorque wrote:Keeping it standard...... I can imagine it starts this way and then we will see maybe some polybushes and a steel timing gear. Change cam while you are at it, maybe change the exhausts. Minor suspension upgrade. Different carb. Change the wheels. Change the brakes. Modified heads. Change the carb again................
There will be subtle mods/improvements for reliability etc, absolutely no intention at all to upgrade power, brakes or exhaust, but steel timing gear is a given as are poly bushes. The dampers were new Monroe's with new 2.25" springs when it was parked up, the ride height looks sensible, so if they work as good as they look they will stay.
LRP 335E SE4a
XRF 976H SE5
Has thanked: 287 times
Been thanked: 211 times
Post by b.c.flat hat » Wed Nov 30, 2016 12:28 pm
Don't forget electrics too, two 50amp fuzes seems a poor way to protect the whole car.
turbster
Post by turbster » Wed Nov 30, 2016 12:45 pm
b.c.flat hat wrote:Don't forget electrics too, two 50amp fuzes seems a poor way to protect the whole car.
It's got two 4 way Lucas fuse boxes as per the SE5, sure my other one had that too??
LRP 335E SE4a
XRF 976H SE5
toolmanchris
Been thanked: 29 times
Post by toolmanchris » Wed Nov 30, 2016 12:53 pm
If its anything like my 5a they tend to get a bit "melty" and lose good connection. I replaced mine with a blade fusebox splitting out lower current from high current loads and relays for the headlights and ignition switch.
Chris Barker
http://www.toolmanweb.com
RSSOC: 4125
Seat Leon FR - daily driver
turbster
Post by turbster » Wed Nov 30, 2016 1:10 pm
toolmanchris wrote:If its anything like my 5a they tend to get a bit "melty" and lose good connection. I replaced mine with a blade fusebox splitting out lower current from high current loads and relays for the headlights and ignition switch.
Sensible idea, I just made my own loom and used a modular fuse/relay box on my other Coupe, but I'll use two new replacement Lucas boxes and add a couple of Lucas relays on the bulkhead to keep everything looking as it should on this one..
LRP 335E SE4a
XRF 976H SE5
Has thanked: 189 times
Been thanked: 1281 times
Post by scimjim » Wed Nov 30, 2016 2:23 pm
For some reason the 5 type (two boxes of four fuses) suffer far less from overheating.
Has thanked: 132 times
Been thanked: 877 times
Post by philhoward » Wed Nov 30, 2016 3:24 pm
I think it's because the fuse clip "ears" are one piece rather than the 5a-on type which are two separate pieces of metal per side?
toolmanchris
Post by toolmanchris » Wed Nov 30, 2016 3:48 pm
The 5a fusebox is that nylon type plastic as well which does melt rather easily
Chris Barker
RSSOC: 4125
