Irish Se6 restoration.
FlanFlinger
Re: Irish Se6 restoration.
Post by FlanFlinger » Fri Sep 30, 2016 2:07 pm
I see from the soot on the back wall you're still tinkering with the carbs on the Jensen :lol:
I'm the fella with the MK1 Cavalier soft top that was at the Limerick meet up a few months ago, I've bought the red SE5a that was on DoneDeal a few weeks back :wink:
justfur
Post by justfur » Sun Oct 02, 2016 4:57 pm
The two closer black spots are the Scimitar, a lot blacker than the CV8 outer ones, as it hadn't run in three years and I'd lashed diesel into the cylinders to lubricate the pistons/rings!
Did you buy from the same man I did in Milltown Malbay?
Justin.
1976 SE6 no.49 See more here: https://www.flickr.com/photos/147918531 ... 463353942/
1963 CV8 Mk1 no.10
1967 TR4A
FlanFlinger
Post by FlanFlinger » Wed Oct 12, 2016 12:56 pm
justfur wrote:Did you buy from the same man I did in Milltown Malbay?
I did indeed, just waiting for lots of parts to turn up to get it sorted :D
justfur
Post by justfur » Fri Oct 28, 2016 10:14 pm
I am now close to reassembling the suspension and in some doubt as to the orientation of the chassis W/B brackets. I have looked at photos of other cars and there does not seem to be a definitive answer!
As they came off the car, RH side:
But I don't trust that this is correct, mainly due to the TR vertical link which I found fitted, can someone please confirm? On some cars the bolts are forward of the centre line of the bracket.
I'm now also in need of a lower wishbone because of excess wear on the O/S, why only one? Not sure which one but the numbers on the casting are XAW5186 if anyone has one lying around.....
Justin.
1963 CV8 Mk1 no.10
1967 TR4A
Been thanked: 653 times
Post by scimjim » Fri Oct 28, 2016 10:18 pm
There is a definitive answer but it's different between PAS and manual steering :-)
PAS studs are offset to the rear, manual steering the studs are offset to the front. Along with the top wishbones being reversed and a different trunnion, this gives the bigger castor angle that the PAS cars need.
justfur
Post by justfur » Fri Oct 28, 2016 10:52 pm
Thanks Jim, I have PAS so the brackets are correct.
Justin.
1963 CV8 Mk1 no.10
1967 TR4A
justfur
Post by justfur » Sat Jan 28, 2017 8:01 pm
Time for an update.
Chassis blasted and dipped:
Turned upside down for ease of fitment:
Axle blasted and painted:
Justin.
1963 CV8 Mk1 no.10
1967 TR4A
justfur
Post by justfur » Sat Jan 28, 2017 8:05 pm
Time to bolt on a few things, great fun tapping out the holes after dipping:
Justin.
1963 CV8 Mk1 no.10
1967 TR4A
justfur
Post by justfur » Sat Jan 28, 2017 8:12 pm
And now for a bit of sanding, I'm getting attached to the pink :)
Justin.
1963 CV8 Mk1 no.10
1967 TR4A
ronnie
Banned User
Has thanked: 49 times
Been thanked: 37 times
Post by ronnie » Sat Jan 28, 2017 8:16 pm
Chassis and bits looking good
justfur you - much better looking than mine !
Keep up the good work
DarrylWebb
Has thanked: 70 times
Been thanked: 38 times
Post by DarrylWebb » Sun Jan 29, 2017 6:23 pm
Looking very tidy, Justin.
justfur
Post by justfur » Tue May 16, 2017 11:29 pm
Body is hopefully heading off for a lick of paint after the local show where I've been asked to display it in it's two halves, here's hoping for good weather.
What other options are there when it comes to rear lights, other than the now dubious Romainian ones, as now is the time to make any changes to accomadate an upgade?
I am also missing the four front panels that fit inside the wheels to cover/hide the suspension, does anyone have a set?
And with it's coat of Rustbusters epoxy paint https://millersoilsireland.ie/epoxy-mas ... sis-paint/
Justin.
1963 CV8 Mk1 no.10
1967 TR4A
ronnie
Banned User
Post by ronnie » Tue May 16, 2017 11:49 pm
That is a lot of rubbing down there....
Rear Lights - there's 2 types of trailer lights or you could try the Mercedes truck lights (Middlebridge) which require a bit of grp work to fit.
I bought a set for that next project.
Datsundrew
Post by Datsundrew » Tue May 16, 2017 11:55 pm
That's looking fantastic! The galvanised chassis is the way to go.
justfur
Post by justfur » Wed May 17, 2017 6:53 pm
ronnie wrote:That is a lot of rubbing down there....
Any chance you can give me more details of which Merc truck lights please.
Justin.
1963 CV8 Mk1 no.10
1967 TR4A
