Has thanked: 136 times
Been thanked: 502 times
Post by Roger Pennington » Wed Oct 11, 2017 11:27 pm
Probably the weakest area of the switches is that the holes left for the panel lights allow dirt to fall in, and they eventually clog up with gunk inside. On the bright side, they are quite easy to take apart and clean, and they all work on very similar principles (hence why some will swap around), so it's not too difficult to repair them. (see window switch overhaul
Datsundrew
Post by Datsundrew » Thu Oct 12, 2017 9:12 pm
Thanks, and yes you're right, there was a lot of crap inside them! I blasted them with contact cleaner for now, but I am not convinced that they won't fail sometime, especially the light switch which although I run relays now, it still struggles and needs a jiggle.
Has thanked: 129 times
Been thanked: 938 times
Post by scimjim » Thu Oct 12, 2017 9:25 pm
Fit new ones? They lasted 40 years :-)
Been thanked: 107 times
Post by gtcse8 » Thu Oct 12, 2017 10:41 pm
Roger and Andrew
I would not be worried about dust and dirt falling into the cleaned out switches as they are quite obviously upside down.
Dennis Nicholas
Has thanked: 37 times
Post by Dennis Nicholas » Fri Oct 13, 2017 9:09 am
Datsundrew
You "blasted with contact cleaner" .......did you read the original how to article which advised greasing the springs and inside the holes and ends of the plastic plungers/V of the rocker copper so that they would slide easier? I have used silicone grease (plumbers supplier) silicone being long lasting, in the past.....another said use lithium grease (but did not explain why) Also have you smeared the contacts and studs with contact grease (special stuff designed for electrical contacts to help prevent the arching that causes the burns that then gives big resistance and causes worse burning)?
Dennis
Dennis Nicholas(RSSOC)
Datsundrew
Post by Datsundrew » Sat Oct 14, 2017 12:53 am
Are new ones available? No doubt I'll have to remortgage if they are!
Post by scimjim » Sat Oct 14, 2017 6:03 am
twin position switches are (headlights, fans, fogs) - look for TR7. Not sure about single position switches such as hazards?
Been thanked: 230 times
Post by AJL Electronics » Sat Oct 14, 2017 7:12 am
Bear in mind that TR7 do not have the illumination window, but you can swap the new innards into the old housings.
Post by gtcse8 » Sat Oct 14, 2017 11:32 am
I got LOTS of NOS BL switches that I pull apart to replace the old worn out components inside standard Scim switches, some TVR wedges used the same ones too.
As a result I got quite a lot of the outer unit to replace the Scim ones that have broken locating fingers and refuse to stay put.
Datsundrew
Post by Datsundrew » Sun Oct 15, 2017 7:53 pm
Thanks Dennis, yes I did, and I may well do, I just wanted to try to get things working quickly as most of the wiring has been disconnected or moved in some way. My stupidity as I assumed that things not working was due to me fiddling, and only after a lot of frustrating hours I realised that it was dodgy switches.
Datsundrew
Post by Datsundrew » Mon Oct 16, 2017 7:58 pm
A bit more sorted this afternoon, I've got all the dash gauges connected up and working! I got the alternator wiring made and connected up, so we now have charging. I ran it up to temperature and can confirm that the heater works very well and although the original fans aren't brilliant, they are quiet and as I've got a big matrixin the dash it doesn't need a lot of air to move the heat through the core. The temperature sender on the engine seems to match the gauge ok and it reads 90 as the thermostat opens and the radiator starts to do its job. I've not got a sensor to operate the cooling fan yet, not sure what I'll use yet, but I ran it until almost boiling and connected the fan who saw the temp drop quickly back to 90.
I'm using a volvo 850 fan, which moves a massive amount of air (and amps!) in the volvo this blows through the air con condensor and the radiator so has to be quite good.
Next job is to neaten up my wiring under the bonnet......it's a mess!
Datsundrew
Post by Datsundrew » Mon Oct 16, 2017 8:15 pm
I forgot to mention the dash warning (triumph based) thingy......
The left indicator warning was dim and the low fuel light didn't work, so I took the unit out and found 3 blackened bulbs, two blown and one working...that was the left indicator. The blown ones were the fuel light (surprise,surprise!) and the hand brake.
I tried to find bulbs, and ended up with a google search that led me search for Lilliput bulbs. Apparently they are used in dolls houses and train sets? Anyway a pack of 10 led ones are ordered, along with other dash bulbs too. I'm going all LED :D
Post by AJL Electronics » Mon Oct 16, 2017 8:45 pm
Not the ignition lamp though, the alternator needs to have sufficient current through it. An LED may well stop it charging.
Last edited by AJL Electronics on Tue Oct 17, 2017 6:35 am, edited 1 time in total.
Post by Roger Pennington » Mon Oct 16, 2017 9:09 pm
Also may be worth noting that there isn't in fact a specific "handbrake warning" as such. The two red lights at the bottom of the cluster are for brake pad wear and hydraulic fluid failure. When the handbrake is operated, it shorts out those two circuits to switch on the lights and prove that the warnings are still working. So they only have a secondary function as handbrake lights. So if one lights up when you're driving down the road, it probably doesn't just mean you've left your handbrake on, but something rather more serious! :wink: (though the brake pad wear light will only work for real, if you have pads with the warning sensor wires).
Datsundrew
Post by Datsundrew » Tue Oct 17, 2017 9:44 pm
Oh good call on the ignition light! That would have got me stumped as it would have lit up but not given the resistance as you said. I had an incident many years back with a datsun........3 alternators later, it was the bulb!
