Manny's SS1 1600
Has thanked: 77 times
Been thanked: 706 times
Manny's SS1 1600
Post by philhoward » Mon Nov 25, 2019 1:40 pm
Your testing theory is correct - you should get a reading in the region of 100-2000 Ohm area depending if it’s hot or cold between the spade and earth. Exact figures isn’t critical but around 100 ohms for hot, 2-3000 for cold, plus or minus 20%. It’s not a calibrated instrument :lol:
manny
Has thanked: 37 times
Been thanked: 22 times
Manny's SS1 1600
Post by manny » Mon Nov 25, 2019 1:43 pm
Ah ...thank you Mr Howard and Mr King..
manny
Manny's SS1 1600
Post by manny » Fri Dec 06, 2019 4:09 pm
Good day all,
well, before setting of to work on Ti, about three miles from work and as i finish at 11:30, thought i would check the temp gauge sender wire.
All was attached and looking okay, i disconnected and gave it a quick rub with some p100 sand paper and reconnected...no difference , my gauge swept to hot straight away....
Proceeded about 2miles..and the car died, i coasted to the side and noted no activity on the tacho whist it tried to start...humm popped the bonnet.
Checked\wiggled the wires on the coil and loom nearby.....car started and the temp gauge worked.. :?
I wish wiggling wires not part of a temp fix, will check the loom\wires at the weekend...
Ta
Manny
Manny's SS1 1600
Post by philhoward » Fri Dec 06, 2019 4:48 pm
Sounds like the standard issue 1800TI fried loom syndrome...
manny
Manny's SS1 1600
Post by manny » Fri Dec 06, 2019 4:55 pm
this was the 1600..apologies i could have been clearer...i was setting of to work on the Ti garaged three miles away....not sure that's any better. :)
Has thanked: 191 times
Been thanked: 102 times
Manny's SS1 1600
Post by efi_sprintgte » Fri Dec 06, 2019 4:59 pm
I had to read it twice :lol:
Sounds like you have some wiring to do...
Manny's SS1 1600
Post by philhoward » Fri Dec 06, 2019 5:00 pm
Still fried wiring syndrome..
Has thanked: 101 times
Been thanked: 153 times
Manny's SS1 1600
Post by reliant-reviver » Sat Dec 07, 2019 8:19 am
Check the back of the clock set for damaged sections on any parts of the laminated circuit. Rev counter INOP is usually because there's a crack in the section running around the corner to the back of the dial.
Could well explain your coolant temp gauge issue also.
