Manny's SS1 1600
manny
Has thanked: 33 times
Manny's SS1 1600
Post by manny » Sat Jun 16, 2018 9:20 am
Good day all,
well my three amplifiers arrived this morning ....but i may be of to a bad start...LUCAS stamped on them.. :)
Will try and start the car as is first -and then swap the amplifier...will update soon
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sat Jun 16, 2018 3:44 pm
well....its not the amp! :( as i am bound for sunnier climbs - i will have to diagnose next weekend.
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sat Jun 23, 2018 10:42 am
Good day -
I think i found the issue with the starting problem :)
how best to repair it?? break off the brown clip, solder and heat shrink?
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Has thanked: 25 times
Been thanked: 34 times
Manny's SS1 1600
Post by Alan SS1 » Mon Jun 25, 2018 12:46 pm
no image :-(
Been thanked: 550 times
Manny's SS1 1600
Post by philhoward » Mon Jun 25, 2018 12:59 pm
no image :-(
Was for me? It's hosted externally, so here's a screenshot for your delectation:
manny
Manny's SS1 1600
Post by manny » Mon Jun 25, 2018 8:19 pm
i got excited when i saw my post had some replies... :( any objections if i made a 'clip' out of wood? :w to hold the two wires steady in the dizzy or is there a proven route here?
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1600
Post by philhoward » Mon Jun 25, 2018 8:54 pm
Sikaflex and make your own “grommet”?
Manny's SS1 1600
Post by philhoward » Mon Jun 25, 2018 8:55 pm
Wrapping it in self-amalgamating tape might do as well but it might keep on melting..
Manny's SS1 1600
Post by Alan SS1 » Tue Jun 26, 2018 12:49 pm
I have connected my cables directly onto the wires 'within' then came out through a 'grommet' ( I think, as my amp is also on the bulk-head)
I probably have the brown bits of plastic kicking around on some of the old dizzy if you really wanted? but from memory the cable insulation looked 'open' on them, ie suffered from heat?
manny
Manny's SS1 1600
Post by manny » Tue Jun 26, 2018 3:30 pm
my pseudo amp on the dizzy is feeding cables to the live amp on the bulkhead - i think i may go the 'wood' route to ease the shaping and wire route for the dizzy brown grommet ...should be okay ..
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sat Jun 30, 2018 3:43 pm
Good day all,
well i managed to repair the green and black wires and heat shrunk wrapped...i did not use the wood route yet for the grommet -
Installed the dizzy back in - used a new amp .
Car turns over but no go.... i used the no1 cylinder spark lead to confirm i do get a spark - but not a blue on - a yellow one ( ..spare plug was quite carboned)
I have put the battery on charge for now and have some neat fuel ready to pour down the carb...will retry in a few hours... :(
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sun Jul 01, 2018 11:03 am
Good day all,
so...neat fuel down the carb- the car does start and keep running - so spark side is all okay.
Next i detached the fuel hose between the pump and carb inlet - and ran a hose into a glass bottle.....
the top layer of petrol is the neat that i added!!...so those whom suspected water.... lots of it- the tank gauge is near the first mark - so lots of fluid to remove!!
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sun Jul 01, 2018 11:22 am
i guess it will be best to remove the plugs to ease compression- and use the starter to pump it all out- i have a large 25l tank
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sun Jul 01, 2018 4:30 pm
decided - i will take the electric one off the GTE and use that - will run for longer than the starter motor method.
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Has thanked: 77 times
Been thanked: 119 times
Manny's SS1 1600
Post by reliant-reviver » Sun Jul 01, 2018 5:50 pm
Or, just whip the boot liner and tank out?
