Manny's SS1 1600
Been thanked: 319 times
Re: Manny's SS1 1600
Post by peter freeman » Mon Apr 24, 2017 8:09 am
Here is a picture of the only one I could get at and I'm not sure which car it came off. The teeth of the wheel have been raised to stop the rotation ( end stop ). If not raised enough the momentum of the motor can drive the raised teeth beneath the plate ( on this photo the raised part is very high ) once under the plate the motor cannot reverse the gear from a standing start. The only answer is to free by hand and bend the teeth higher so they cannot go under the plate. You can see that the teeth have made a dent in the plate through use.
manny
Has thanked: 33 times
Been thanked: 14 times
Post by manny » Mon Apr 24, 2017 5:16 pm
Thank you very much sir - that certainly does help
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Post by manny » Thu Apr 27, 2017 8:02 pm
My err..re-cycled ghettlow blaster !
if anyone needs detailed install instructions..
he he
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Post by peter freeman » Thu Apr 27, 2017 8:28 pm
connect to one end of a 6 mtr rope and the other end of the rope to the rear bumper - you should get the full "experience" from that distance - sounds great above 60 mph
manny
Post by manny » Fri Apr 28, 2017 5:20 pm
peter freeman wrote:connect to one end of a 6 mtr rope and the other end of the rope to the rear bumper - you should get the full "experience" from that distance - sounds great above 60 mph
Peter...i actually have no idea what that means....i did try to picture the scenario...but got tired :D
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Has thanked: 113 times
Been thanked: 819 times
Post by scimjim » Fri Apr 28, 2017 5:42 pm
You can't visualise those speakers 6m behind you on a rope attached to your rear bumper? :mrgreen:
manny
Post by manny » Fri Apr 28, 2017 5:51 pm
scimjim wrote:You can't visualise those speakers 6m behind you on a rope attached to your rear bumper? :mrgreen:
AH!!...i see...my mistake was to assume the speakers were not to be moved ...so i would have a rope loop to the bumper!...i got tired figuring on how to tie the rope to the bumper......
thank you Jim...and sorry Peter :oops:
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Post by manny » Sat May 20, 2017 3:30 pm
Good day all
so between sun and down pours - i managed to ghetto fix a slight blow in the exhaust join at the down pipe and mid section with an empty can of beans, exhaust paste and exhaust clamps....
and installed a LED brake light thus:
a bit wonky - but hey- i still got to hook up to the brake lights
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Has thanked: 127 times
Been thanked: 137 times
Post by Corky » Sat May 20, 2017 3:57 pm
You can feel quite vulnerable in an SS1 next to modern cars, so a high level brake light is a great idea. I had considered fitting one to the roll over bar, but thought it'd annoy me when I looked in the rear view mirror.
manny
Post by manny » Sat May 20, 2017 4:38 pm
I even have sketched one that could be mounted at the soft top header - that's for another day
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Post by manny » Mon Jun 12, 2017 5:24 pm
Good day all,
just been informed I have another year's MOT ...Woo-hooo...
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Post by Corky » Mon Jun 12, 2017 5:29 pm
Well done !
manny
Post by manny » Mon Jun 12, 2017 7:16 pm
Corky wrote:Well done !
well..happy...but i have not yet seen the advisory list....
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Has thanked: 112 times
Been thanked: 450 times
Post by Roger Pennington » Tue Jun 13, 2017 12:08 am
Congratulations on the MOT! :D
manny
Post by manny » Wed Jun 14, 2017 8:47 pm
Good day,
well here's the list
Advisory notice item(s)
Steering column top bearing slightly worn (2.1.2c)--?
Oil leak ()--- suspect the front crank oil seal
Nearside Play in steering rack inner joint(s) ---rebuild?
Offside Play in steering rack inner joint(s) --- as above
Nearside Rear Nail in tyre ()---hum difficult one....
Nearside Rear Inner Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)-- 16mm? Poly or rubber
Offside Rear Inner Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)--as above
Nearside Front tyre cracking-- wife's foundation?
i will need some advice\help on the ?'s
lots to do for the next MOT!
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
