Early SE5a
IanC
Early SE5a
Post by IanC » Thu Feb 25, 2016 12:20 pm
Hi,
I 've just bought a SE5a, SEN 41K. It's in very good cosmetic condition, with enough quirks to keep me entertained for some time to come I suspect.
It's got a 4 speed box (reverse on the right) and no overdrive, but unlike the 4spd I had years ago, it's got a hydraulic clutch. The axle appears to be 3.31/1 (i.e. two turns of a rear wheel give 3 and a third turns of the propshaft. So, I'm not sure if this is a conversion of an overdrive model. One clue might be in the speedo, which under-reads by a long way . I've attached a photo below, the code reads SNT-6141/06 1000.
Does this code correspond with anyone's speedo as fitted on a SE5a?
I'll post some photos of the car later.
Regards,
Ian
Current : SE5a 4spd auto project
Been thanked: 578 times
Re: New arrival/speedo query
Post by philhoward » Thu Feb 25, 2016 12:40 pm
Sounds like an overdrive car that's had its box replaced with the non-overdrive version of the 2 rod box. Funnily enough, that's exactly how my first 5a was..
It could explain why your speedo is out - all
GTE speedos are 1000 turns per mile but the speedo gear in the box probably suits the Zodiac donor instead.
IanC
Post by IanC » Thu Feb 25, 2016 4:33 pm
Hi Phil,
That's sort of my line of thinking too. I would have retained the 4 speed box but it's noisy (and recalcitrant) so will need replacing at some stage. I'm currently thinking of sourcing an o/d box and fitting that and keeping the low ratio axle. There's bad 'clonk' on the back axle, but I may have a go at fixing it - I know the theory, but never had the practice!
Ian
Post by philhoward » Thu Feb 25, 2016 5:57 pm
That's probably the best option - 2 rod overdrive boxes crop up from time to time.
IanC
Post by IanC » Sun Mar 13, 2016 8:29 pm
Photo of new arrival as promised. Cosmetics great, mechanicals, well, plenty to keep me on my toes!
Ian
02012011865 (800x600).jpg (368.68 KiB) Viewed 2838 times
Has thanked: 134 times
Been thanked: 496 times
Post by Roger Pennington » Sun Mar 13, 2016 8:48 pm
Smart-looking car Ian, well done! :D
MikeT
Has thanked: 21 times
Been thanked: 23 times
Post by MikeT » Sun Mar 13, 2016 9:23 pm
Yep - very nice, that looks lovely.
More pics needed when you can, please ;)
Mike.
IanC
Post by IanC » Mon Mar 14, 2016 9:24 am
Thanks for the kind comments guys, here's some more photos. It's off the road currently (shock absorbers, upholstery repairs, fuel gauge) but I hope to be back on the road soon.
Ian
SE5a3 (800x800).jpg (397.35 KiB) Viewed 2777 times
02012011866 (800x600).jpg (370.2 KiB) Viewed 2777 times
02012011864 (800x600).jpg (340.2 KiB) Viewed 2777 times
Lukeyboy46
Has thanked: 90 times
Been thanked: 37 times
Post by Lukeyboy46 » Mon Mar 14, 2016 9:38 am
Beautiful car! Look forward to seeing this tonight at the noggin!
Luke Garratt
RSSOC Forum Moderator
74' Se5a - Daily driver!
FrazzleTC
Post by FrazzleTC » Mon Mar 14, 2016 10:10 am
That's a really gorgeous example! Love the colour coordinated webasto, and the paint looks amazing. At least the mechanical side is a lot more fun to deal with than anything cosmetic, so I'm sure you'll have a lot of enjoyment from it.
IanC
Post by IanC » Mon Mar 14, 2016 12:08 pm
FrazzleTC wrote:That's a really gorgeous example! Love the colour coordinated webasto, and the paint looks amazing. At least the mechanical side is a lot more fun to deal with than anything cosmetic, so I'm sure you'll have a lot of enjoyment from it.
Thanks,
The webasto is a nice touch, and the headlining is just excellent. The car has done practically no miles for about seven years (sometimes only a trip to the MoT station by the looks of things). And its first decent run in years to my place certainly shook things up like brakes and shockers so there's more to do than I had anticpated. But as you say the mechanical side is more fun, so I expect it''ll keep me happy on that front for a while to come. And it goes great!
Ian
Post by Roger Pennington » Mon Mar 14, 2016 12:55 pm
Very nice!
This reads like a good introduction to a project thread, if you like I could move it for you? (you can change the title at any time by editing the first post) :)
IanC
Post by IanC » Mon Mar 14, 2016 1:54 pm
Roger Pennington wrote:Very nice!
Hi Roger,
Thanks, that sounds a good idea
Regards,
Ian
Post by Roger Pennington » Mon Mar 14, 2016 1:59 pm
Done! :D
Rev Light
Been thanked: 25 times
Re: Early SE5a
Post by Rev Light » Tue Mar 15, 2016 7:16 am
Mine is the same colour but with no sunroof. Yours definately gives me something to aspire two.
SE5a 'Fancier'
