551 A race oddity
Has thanked: 324 times
Been thanked: 156 times
551 A race oddity
Post by MikeyBikey » Wed Aug 21, 2019 9:28 pm
clever stuff
barry_bryan
551 A race oddity
Post by barry_bryan » Thu Aug 22, 2019 8:28 pm
really really clever stuff & pretty crackin job. Baz
Barry Bryan
Been thanked: 129 times
551 A race oddity
Post by BigBobPilot » Sat Aug 24, 2019 11:35 pm
I’ve been working though all the jobs
Fitting pins for boot lid, the rear light panel if flatted for painting
Painting
Re-assembly
The LH rear wing came back off the wall, got patched up & re-used. The cracks were glued with bumper epoxy glue & backed with grp woven tape. I realised I didn’t have time to modify the replacement wing, as I had to prioritise modifications & adjustments to the rear suspension, as well as the re-assembly. The LH inner wheel arch was an easy patch up.
The car is ready to head to Brands Hatch on Sunday. Qually on the Sunday afternoon, then all being well, racing on Monday.
Before
After - deck panel, boot lid, light panel, reat armature, LH rear light & rear section of chassis & one bonnet pin replaced. Deck panel & boot lid wrapped, rear light panel painted. The boot lid had a lot of micro blisters in the primer so I flatted it back & wrapped straight on to the gel-coat, we'll see how well it stays attached. LH rear wing patched, LH semi-trailing arm straightened, rear suspension modifications & adjustments. LH goodridge braided brake hose had the end trimmed (10mm) where it had been kinked & re-assembled with a new olive. Black marks from the tyre barrier removed as much as possible & a general pre-race check.
SS1 CA18DET race car
Has thanked: 154 times
Been thanked: 1051 times
551 A race oddity
Post by scimjim » Sun Aug 25, 2019 7:14 am
Great work :D
Has thanked: 191 times
Been thanked: 102 times
551 A race oddity
Post by efi_sprintgte » Sun Aug 25, 2019 7:57 am
Good luck at Brands 8)
Has thanked: 428 times
Been thanked: 367 times
551 A race oddity
Post by CNHSS1 » Sun Aug 25, 2019 8:22 am
Great turn around Ben, good luck for qually 8)
MadMax
551 A race oddity
Post by MadMax » Sun Aug 25, 2019 9:37 am
Impressive work :)
Max Benton
Reading, Berks
'Zeus' - Yellow SE5a
Has thanked: 36 times
Been thanked: 49 times
551 A race oddity
Post by nickkeyser » Sun Aug 25, 2019 9:49 am
Very impressive, pleased to see it all back together. Good luck at brands!
SSSC Champion 2019
SS1 CVH 1600Ti
Been thanked: 559 times
551 A race oddity
Post by Roger Pennington » Sun Aug 25, 2019 1:35 pm
Well done, that's a great recovery. Good luck! :D
Has thanked: 77 times
Been thanked: 706 times
551 A race oddity
Post by philhoward » Mon Aug 26, 2019 7:36 am
How did qualifying go?
551 A race oddity
Post by CNHSS1 » Mon Aug 26, 2019 9:09 am
Got a message to say qually went ok, but water temps a bit high. Read elsewhere it was 34 deg at Brands! So prob explains it. Some suspension tweaks and car handling even better 8) Fingers crossed for both races today :)
turbster
Has thanked: 65 times
Been thanked: 56 times
551 A race oddity
Post by turbster » Mon Aug 26, 2019 10:05 am
I was wondering why there was no race results on TSL 🤔 Should’ve looked at the timetable!!
LRP 335E SE4a
XRF 976H SE5
www.gtevolution.co.uk
551 A race oddity
Post by CNHSS1 » Mon Aug 26, 2019 10:23 am
2 x races today I believe Paul
551 A race oddity
Post by nickkeyser » Mon Aug 26, 2019 11:04 am
I was watching it on the live timing earlier, looks like Ben pitted early - hope everything’s ok.
SSSC Champion 2019
SS1 CVH 1600Ti
551 A race oddity
Post by BigBobPilot » Mon Aug 26, 2019 1:26 pm
It's hot!
I pulled in on the 1st race as the water temp went high.
I decided to try moving the water expansion tank higher. Richard Carter is here, so he gave me a hand & it was a bit of a rush to get out for the 2nd race.
2nd race was red flagged, on the re-start, it blew a boost pipe off. It was holding temp until then, but I hadn't done much.
The exhaust is getting smokey, I think a turbo seal might have gone. I'm going to check the bearings before deciding whether to give the 3rd race a go.
The handling feels ok, I was keeping with a group of cars in the 2nd race, but there are some mighty quick cars in Mod Sports, so plenty of room for development!
