Manny's SS1 1800 Ti
manny
Has thanked: 37 times
Been thanked: 22 times
Re: Manny's SS1 1800 Ti
Post by manny » Sat May 28, 2016 7:33 pm
Corky wrote:Don't chop it :lol: . Remove it gently and put it in your spares box.
oh..okay will do....and how? - two nuts and then unwind? or best to leave it to a garage..
Has thanked: 78 times
Been thanked: 707 times
Post by philhoward » Sat May 28, 2016 7:46 pm
If it's only just been fitted, try a good pair of grips - but the 2 nut method is a little kinder ;)
manny
Post by manny » Sat May 28, 2016 7:55 pm
philhoward wrote:If it's only just been fitted, try a good pair of grips - but the 2 nut method is a little kinder ;)
thank you sir, i think i will need to use the two nut method as the stud is a complete thread - no non-thread bit\shank\what ever you call it :?
Will have a go tomorrow :)
Ta
Manny
manny
Post by manny » Sun May 29, 2016 9:07 am
Lovely day all,
before I head back out to the garage to tackle my two nuts...could some one point out where on the block the oil feed pipe connects...i saw numerous threaded holes but could not seat it in any of them...a picture would be nice if possible
Ta
Manny
Has thanked: 102 times
Been thanked: 153 times
Post by reliant-reviver » Sun May 29, 2016 12:01 pm
Can't help on the exact location. But have you remembered the 90 degree brass adaptor between block and pipe ?
manny
Post by manny » Sun May 29, 2016 1:46 pm
reliant-reviver wrote:Can't help on the exact location. But have you remembered the 90 degree brass adaptor between block and pipe ?
humm... i don't remember seeing such an item when i last went through the car\turbo bits...but that will explain why i struggled...looking through the red manual ..i think i know what i am looking for- cant recall it being on the engine block ...so it must be in one of the box bits...
I thank you sir
Ta
Manny
Has thanked: 428 times
Been thanked: 370 times
Post by CNHSS1 » Sun May 29, 2016 2:11 pm
The reliant oem 90deg widget (not used by nissan)
If its an earlier engine, itll have the oil fees from inlet side around the oil filter assembly
manny
Post by manny » Fri Jun 03, 2016 3:58 pm
good day all,
after a frantic search...
yeaaaahh found it :D :D buried in the boot beneath the carpet!
test fitting can resume today!!
Ta
Mamny
Post by CNHSS1 » Fri Jun 03, 2016 5:40 pm
don't lose it, its a weird size, NPT from block to some odd size that reliant found down the back of a cupboard for the hose end
manny
Post by manny » Fri Jun 03, 2016 8:59 pm
CNHSS1 wrote:don't lose it, its a weird size, NPT from block to some odd size that reliant found down the back of a cupboard for the hose end
i have screwed it into the block , so it should stay put- i was trying to screw in it and orientate it as you have shown - but it screws tight pointing upwards- I guess i can use some plumbers PTFE tape to help it tighten ( is it suitable?)
I managed to remove the offending turbo stud without too much trouble
I also need to remove two exhaust studs from the head- so will tackle that tomorrow :)
and about to order a set of these
studs have been reassured by the seller they fit they CA18ET
i can now see how difficult reinstalling all the turbo bits are!- i did try to bolt up the ( existing)water banjos as an excerise...-- but then gave up after about an hour-
ta
Manny
Has thanked: 295 times
Been thanked: 229 times
Post by Corky » Sun Jun 05, 2016 9:03 am
Yes S13 studs do fit the S12. You may find that the threads have corroded or been stripped inside the alloy of the head, so be very careful when reinstalling and tightening. If any are stripped, you can easily helicoil them. Length can also be an issue. If the lower ones are too long you'll struggle to get the nuts onto them in the tight space.
Upgrading to flexible water hoses will make fitting an awful lot easier.
My Sabre Ti thread has quite a few photos of the helicoil process and fitting of the manifold, turbo and flexi pipes. As has my SS1ti thread.
manny
Post by manny » Sun Jun 05, 2016 11:52 am
Good day all,
thank you Steve...I've a lot of learning material to go through!...I have been reading your ( and others) threads repeatedly...but even so having an experienced enthusiasts reply to questions I kind of know the answers to...just gives that extra ' it will be alright.. pat on the back' . So thanks to all in advance to whom take the time to respond to us mechanical newbies..with our trivial questions...just proves how fantastic value for money the membership is :D :D :D
Ta
Manny
Post by philhoward » Sun Jun 05, 2016 3:04 pm
Generally speaking there's no such thing as a daft question and at the end of the day that's what the Club community is all about :D
manny
Post by manny » Sat Aug 13, 2016 4:25 pm
Good day all
I thought i should stop enjoying the 1600 ...there's always tomorrow ( Warwick Retro car show :D..anyone? )...
even though i have the braided cooling hoses and new banjo water attachments..I still wanted to see if i could re-attach the original hard pipes..
one nearest the engine block went (loose) on within five mins!! :shock: :D
the other is still giving a fight - but i cant align it due to the proximity of the waste gate bracket bolt..
there is no clearance at all!..the banjo housing is in contact as i try to align the banjo bolt-hole
Next week the fight will continue...
Ta
Manny
td99
Has thanked: 17 times
Been thanked: 33 times
Post by td99 » Sat Aug 13, 2016 5:10 pm
You may find that you can rotate the inlet housing a little to gain clearance (with quite some leverage of course!) . It's only fixed to the central bearing housing (the bit with the water cooling) by a circlip on these turbos.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
