Manny's SS1 1800 Ti
Has thanked: 155 times
Been thanked: 1051 times
Manny's SS1 1800 Ti
Post by scimjim » Sun Sep 30, 2018 11:35 pm
You need the nose cone off, so you’re going to have to take the headlight panel off to release it.
Has thanked: 32 times
Been thanked: 51 times
Manny's SS1 1800 Ti
Post by Alan SS1 » Mon Oct 01, 2018 12:40 pm
Manny
do you photos of my 'agricultural' repair? it wasn't that difficult, but the nose section was removed for access, which you'll need to do any way!!
only reason for the angle (well actually three) 1 no folding machine 2 folding machine (if purchased) would 'usually' be 600mm wide max, and thirdly I had 1" section !!!
manny
Has thanked: 37 times
Been thanked: 22 times
Manny's SS1 1800 Ti
Post by manny » Mon Oct 01, 2018 1:19 pm
Manny
ooh yes please...
Manny's SS1 1800 Ti
Post by Alan SS1 » Tue Oct 02, 2018 6:04 pm
Manny
Photos as requested, I'll edit the text later but pub beckons tonight :-)
spare holder
centre strap.JPG (134.3 KiB) Viewed 1280 times
16 SWG welded on and then 'bent to suit'!
fixing to cross bar
centre strap.JPG (97.8 KiB) Viewed 1280 times
folded section hold radiator
radiator mount.JPG (95.24 KiB) Viewed 1280 times
small section of angle welded opposite way up to allow the radiator mount to be bolted on, short section permits 'misalignment' to be catered for :-)
bolts to original frame
fixture to armature.JPG (111.92 KiB) Viewed 1280 times
welded a short section of flat bar to the angle iron to fix to armature, then discovered that sides of chassis isn't 'quite' parallel and so it is not at right angles!! so having made in advance from measuring width at top of chassis had to cut it off and start again (it was too wide the first time :cry: )
end of section
end RHS.JPG (93.54 KiB) Viewed 1280 times
manny
Manny's SS1 1800 Ti
Post by manny » Wed Oct 10, 2018 3:55 pm
Good day
dropped of my rad to the tank guy - he's going to upgrade the core and make it nice and shiny - all for £130 - he did my Tr one for £200 a few years back - but that was half as large again as the Ti one...
He did state it's okay as is - but is getting rotten- so options were a standard re-core at £80 or the upgraded one- i may as well get the tank out too - are the tanks the same spec\construction on all SS1's?
Ta
Manny
Manny's SS1 1800 Ti
Post by scimjim » Wed Oct 10, 2018 6:27 pm
CVH/Nissan/K series all use different tanks - the core is possibly the same though.
Edit - not 100% sure K series isn’t the same as CVH but can’t check atm :D
td99
Has thanked: 17 times
Been thanked: 33 times
Manny's SS1 1800 Ti
Post by td99 » Wed Oct 10, 2018 6:48 pm
surely you mean RAD, tank has no core ... and as far as I know all shared tank of the day.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
manny
Manny's SS1 1800 Ti
Post by manny » Wed Oct 10, 2018 8:30 pm
sorry to clarify i am referring to the fuel tanks on the SS1 1600 and Ti
Manny's SS1 1800 Ti
Post by scimjim » Wed Oct 10, 2018 9:35 pm
Ah - you were talking about rads :)
3 types of tank I can think of - early with vent near the fuel cap, later with vent on LHS, latest with vent on LHS, outlet on the bottom of the tank and a return on the rear face (not on gauge sender).
manny
Manny's SS1 1800 Ti
Post by manny » Mon Nov 25, 2019 1:40 pm
Good day all ,
i did a bit more tidying up of the lower radiator support ...hopefully a but more today before applying some primer....
The upper rad support had two grommets that secured the rads upper pins, are these grommets just that ..standard grommets ..and available if i measure the diameter?
Ta
Manny
Manny's SS1 1800 Ti
Post by scimjim » Mon Nov 25, 2019 5:09 pm
Yep, just some big grommets.
manny
Manny's SS1 1800 Ti
Post by manny » Sun Feb 16, 2020 12:15 pm
Good day all ,
the radiator has been installed along with the grommets , i have the two steel coolant pipes mariating in some vinegar, hopefully get the system back together next weekend.I have given myself a MOT deadline for end of March..i have another EU road trip in April to Huesca at the foot of the Pryenees...it would be cool to take the Ti!...
Getting there...very slowly..
Ta
Manny
Has thanked: 78 times
Been thanked: 706 times
Manny's SS1 1800 Ti
Post by philhoward » Sun Feb 16, 2020 1:13 pm
Forward progress is progress - keep at it!
Rattling
Manny's SS1 1800 Ti
Post by Rattling » Sun Feb 16, 2020 2:37 pm
Good day all ,
Ta
Manny
That sounds like progress, looking forward to hear about the trip,I'm assuming you will break the journey halfway,I'm off to mid France at the end of the summer think I can do it in one go ,keep up the progress! :D
Colin
1800 Ti
manny
Manny's SS1 1800 Ti
Post by manny » Sun Feb 16, 2020 2:58 pm
Good day all ,
Ta
Manny
Hi Colin,
I have a 190e that i purchased just to attend my cousin's wedding in Tuscany last May...we did that two up without stopping!! 27hrs and 2.5 tanks of fuel..1100 miles..
So that will my preference as it's an auto and very relaxed\lazy to drive..
This new trip is just that..no plans etc, but as we have 2 days to get to our destination, our plan is a coastal drive and then head inwards, it will probably double the distance, but while we still can....
If the Ti is ready..you never know...
Ta
Manny
