Manny's SS1 1800 Ti
Has thanked: 295 times
Been thanked: 229 times
Manny's SS1 1800 Ti
Post by Corky » Tue Apr 03, 2018 9:02 am
I’ve used helicoils for this purpose, along with exhaust manifold studs and rocker bolts. A selection here http://www.scimitarweb.co.uk/sgwrs/sear ... sf=msgonly
If you scroll down the photos of the red engine, you can just about make out a helicoil in the turbo to exhaust manifold flange.
manny
Has thanked: 37 times
Been thanked: 22 times
Manny's SS1 1800 Ti
Post by manny » Wed Apr 04, 2018 7:34 am
Good day all
and thanks for the options - i guess Helicoil is the way forward and doing all four would make sense now - for the studs would using M8 SS bolts suffice, cut to a suitable length with spring washers - or are these exhausts studs a different specification ?
Ta
Manny
Manny's SS1 1800 Ti
Post by Corky » Wed Apr 04, 2018 7:46 am
Have a look on eBay. You can buy them in the correct material from quite a few of the specialist sellers (Conceptua are usually very good). Search “turbo studs” or something similar, and buy tri-lock nuts if you can find them as they generally don’t come undone.
Has thanked: 78 times
Been thanked: 707 times
Manny's SS1 1800 Ti
Post by philhoward » Wed Apr 04, 2018 8:04 am
Exhaust/turbo studs generally have a plain shank in the middle - for the mating part to sit (and locate to a degree) onto. Also generally made from better material to boot.
manny
Manny's SS1 1800 Ti
Post by manny » Thu Apr 26, 2018 9:59 pm
Good day all,
well i handed my manifold to my MOT garage friend and did say i would like the studs removed and holes Helicoiled- 'we will sort something out....'
Drilled deeper and re-tapped...oh well!
They dropped it off my my wife's workplace and did not charge me .... - i sometimes do wonder if too friendly with a single garage is not always a good thing!!
Ta
Manny
Manny's SS1 1800 Ti
Post by Corky » Fri Apr 27, 2018 12:18 pm
Should be ok if you can widen the holes in the turbo. You may find it difficult to get a nut onto the back studs though. So a thin wall nut or two may be required.
manny
Manny's SS1 1800 Ti
Post by manny » Fri Apr 27, 2018 8:17 pm
the (replaced) stud is the same size...it was just a tad longer - so all should fit together without widening the holes? ...on Sunday ..hopefully
Ta
Manny
manny
Manny's SS1 1800 Ti
Post by manny » Sun Apr 29, 2018 3:05 pm
Good day all,
one Ti air box..good as old..to my standard anyway!
just got to lightly sand and then spray.
Ta
Manny
manny
Manny's SS1 1800 Ti
Post by manny » Sun Jul 08, 2018 5:04 pm
Good day,
some progress today - been a while- spent three hours putting the turbo\manifold together..
air filter housing in place as well..
i notice the bottom cooling pipes near the radiators looked quite rusty - so the rad and pipes will be coming out next for inspection
Ta
Manny
manny
Manny's SS1 1800 Ti
Post by manny » Sun Sep 30, 2018 2:55 pm
Good day,
thought i would remove the radiator today - as my on my last visit i noticed some leaks...
as i suspected..
during removal..the wheel strap mount sheared..
Water pipe..
i am sure none of this is surprising...but how best to tackle the bottom radiator mounting..i am best to remove the front headlamp panel first ...
Ta
Manny
Has thanked: 32 times
Been thanked: 51 times
Manny's SS1 1800 Ti
Post by Alan SS1 » Sun Sep 30, 2018 3:11 pm
Good day,
as i suspected..
Ta
Manny
I just binned the whole bottom section and made a new one from 1" angle, two short horizontal flat sections for the radiator bottom mount and a wider piece for the spare wheel, a pair of vertical flat bars picked up the existing holes in the vertical sections of front armature assembly; possibly deemed 'agricultural' :shock:
but at least that way there are no water traps!! :lol:
Has thanked: 155 times
Been thanked: 1052 times
Manny's SS1 1800 Ti
Post by scimjim » Sun Sep 30, 2018 3:50 pm
Depends how bad it is and how good your welding is? They’re simple folded section, so easily repairable - but there comes a point where it’s just not worth your time and effort. I have decent s/h replacements but they’re big and heavy and I don’t have time to be sorting and waiting in for couriers.
manny
Manny's SS1 1800 Ti
Post by manny » Sun Sep 30, 2018 4:29 pm
Thanks..
as i had limited space\visibility- is the bottom mount welded to the side metal work or a bolted in?
Ta
Manny
Manny's SS1 1800 Ti
Post by scimjim » Sun Sep 30, 2018 4:54 pm
Welded - the wing mounting bars, spare wheel strap, headlight motor brackets, cooling fan bar, towing eye and GRP rad duct are all then bolted on.
Been thanked: 561 times
Manny's SS1 1800 Ti
Post by Roger Pennington » Sun Sep 30, 2018 11:08 pm
I've found having an easily removable headlight panel makes access for work on the radiator and pipework much easier. See this post (note: this obviously a 1600, but I don't think the principles vary much)
