Swoakes SS1 DET Sprint Car Work for 2019 begins
Has thanked: 22 times
Been thanked: 83 times
Post by swoakes » Mon Nov 23, 2015 5:47 pm
Well its arrived; picked it up from Corky this morning :D
Looking forward to having a play :)
Only1cliff
Re: Swoakes SS1 DET Sprint car arrives :)
Post by Only1cliff » Mon Nov 23, 2015 5:59 pm
Looking good as always. Any plans for it?
Cliff Dowle
1971 SE5 Competition Car!
Has thanked: 263 times
Been thanked: 227 times
Post by CNHSS1 » Mon Nov 23, 2015 6:02 pm
whats the adage about power and corruption?... :lol:
one careful owner and a few hooligans :lol:
Post by swoakes » Mon Nov 23, 2015 6:04 pm
Only1cliff wrote:Looking good as always. Any plans for it?
It's pretty sorted Cliff 8) Electronic boost controller to fit which came with the car and I'd like to change some of the external decals/ stickers etc to make the car our own but nothing too radical. May also fit a passenger seat for track/ test days (battery and fire extinguisher to move then though :( )
It needs a new dyno run and weighing at the local weighbridge before next year too.
Has thanked: 145 times
Been thanked: 155 times
Post by Corky » Mon Nov 23, 2015 7:15 pm
I've sorted the decals for you already..... :lol:
Post by Scimher » Mon Nov 23, 2015 8:45 pm
...No need to remove the 'Steve' on the side...
Post by swoakes » Tue Nov 24, 2015 8:01 pm
One of the jobs I do need to do is to increase security.
The car has push button start with no key required. Corky kept it in a locked garage; with me it sits outside on the trailer :( The doors lock but I'd still like to improve security :)
I like the idea of push button start but I could replace it with a key switch or fit a battery isolator with removable key or find another way to imobilise the car :?
thoughts :?:
Post by Corky » Tue Nov 24, 2015 8:15 pm
It'd be a pretty determined thief to try and get it off the trailer ! Not to mention that they'd probably ground it :lol:
I'd be tempted to remove the isolator key and maybe fit some sort of alarm if you're worried.
Post by swoakes » Tue Nov 24, 2015 8:21 pm
Yes I did think of removing the isolator key but its attached by the cable isn't it :?: ...and those keys are readily available anyway :wink: :roll:
Been thanked: 115 times
Post by ScimmyMike » Tue Nov 24, 2015 8:39 pm
Remove the battery then perhaps, easy to do and it's not like you might suddenly fancy a trip down to the shops in it.
Post by scimjim » Tue Nov 24, 2015 9:34 pm
If you can secure the trailer with the ramps against the garage door or a wall, that would help prevent the car being taken?
Been thanked: 539 times
Post by philhoward » Tue Nov 24, 2015 10:46 pm
Remove the ECU? Hidden fuel pump switch?
Post by philhoward » Tue Nov 24, 2015 10:47 pm
scimjim wrote:If you can secure the trailer with the ramps against the garage door or a wall, that would help prevent the car being taken?
Agreed - if it's kept on the trailer, they won't bother to pinch the car - they'll just take the trailer...
Post by swoakes » Tue Nov 24, 2015 11:01 pm
I keep the trailer on the drive with the hitch nearest the garage door; the hitch is fitted with a lock and the wheels have a wheel clamp fitted. I store it that way as I feel the trailer is more secure. I agree that the car would be more secure with the trailer the other way round...unless as Phil suggests they then nick the whole damned lot :roll:
Perhaps a wheel clamp on the car too.......it has no steering lock either so I guess that it could be pushed off the trailer even if they can't start it.
I'm probably worrying about this too much but things can and do go missing so I just want to make the car and trailer as secure as is practically possible :roll:
Been thanked: 26 times
Post by nickkeyser » Tue Nov 24, 2015 11:11 pm
Mine has no door / bonnet / boot locks or steering lock, but does start on a key - not going to stop someone nicking it but its enough to stop an opportunist having a go!
