SE5A Project - Swindon
Rev Light
Been thanked: 30 times
Post by Rev Light » Sun Mar 17, 2019 6:15 pm
It's been a quiet winter on the Scimitar front, but a few jobs were completed today ready for the new season. Today was new track rod ends (MOT) and a new starter motor. All three jobs fought me, but we got there in the end. Thanks to Jim.
And new rear lights. They work, but this might not be permanent, as I would rather have the backing the same colour as the rest of the car. Let's call it, the first iteration.
Rear end.
SE5a 'Fancier'
Rev Light
Post by Rev Light » Sun Mar 17, 2019 7:40 pm
Not much has happened with this Scimitar this winter. I have replaced the rear lights and sorted out the mess that was the wiring in the rear. Old tow hook wiring with lots of 'professional' blue chock blocks, etc. It's certainly simpler back there. This is the first iteration, as when I took the original lights out, it uncovered the original colour of the car. I will eventually remove the lamps and glass up and paint the backing.
Today's task was to change the track rod ends and starter motor. All of which fought me. Thank to Scimjim for giving me a hand. The starter was a massive improvement, but a bu##er to remove with the tubeless manifolds. But a bit of j j jiggling sorted it. Night and Day. Started on the button.
Looking forward to the new season.
Steve.
SE5a 'Fancier'
Rev Light
Post by Rev Light » Mon Mar 18, 2019 10:36 am
Seems to be an echo almost. My Nexus did not seem to want to show first post until I put the second one in... Ho hum.
SE5a 'Fancier'
Has thanked: 189 times
Been thanked: 37 times
Post by willholderogri » Fri Mar 22, 2019 12:05 pm
I see you have one of the rarer SCIMIT models :)
Rev Light
Post by Rev Light » Sat Mar 23, 2019 8:48 pm
The letters are glued back on now. The removal of the old lamps were quite traumatic, so there was the odd bit of collateral damage....
SE5a 'Fancier'
Post by willholderogri » Sat Mar 23, 2019 9:39 pm
Post by willholderogri » Tue Mar 26, 2019 7:58 am
what glue are you using ?
Rev Light
Post by Rev Light » Thu Mar 28, 2019 8:02 am
Just a two part epoxy. Araldite.
Still toying with idea of de-badging it, for the simple look. But filling the holes and painting it is holding me back currently.
Put new black vinyl on the B-Posts as well, used a Evostik contact adhesive for that, but did not remove the rear windows, just pushed the vinyl edges under the rubber seals. The old ones had gone all 'ripply' and were very brittle.
Got some work on the Nose to do this summer to repair some cracks, where it probably had a low speed bump before I bought it. Glad I had some practise glassing the bonnet last year.
SE5a 'Fancier'
Post by willholderogri » Thu Mar 28, 2019 10:09 am
I have decided to only fit the rear scimitar badges and the nose and side badge plus the side GTE .
No scimitar on the front and no gte and automatic on the rear
Post by willholderogri » Thu Mar 28, 2019 12:03 pm
hi steve
do you have a picture of the vinyl on the car
Rev Light
Post by Rev Light » Thu Mar 28, 2019 1:20 pm
Nope, but I can post one up in a day or two.
SE5a 'Fancier'
Rev Light
Post by Rev Light » Sat Jun 29, 2019 6:43 pm
Near side sill bulging, time to investigate....lots of scaley rusty steel and dust. Hoover has just packed up, so still trying to get all the debris out of the sill. Ho hum.
SE5a 'Fancier'
Has thanked: 154 times
Been thanked: 1051 times
Post by scimjim » Sat Jun 29, 2019 7:01 pm
If you’re going to refit a metal plate, you need to cut down the outside of the sill too - it’s an L section originally.
Has thanked: 37 times
Been thanked: 164 times
Post by gtcse8 » Sat Jun 29, 2019 8:00 pm
Just like the ones I make.
Cill reinforcement 001.JPG (68.01 KiB) Viewed 910 times
These are the blanks prior to folding.
EX SST 1800Ti
Rev Light
Post by Rev Light » Sat Jun 29, 2019 8:42 pm
Mark,
I did not realise you were still making them. How much are they now? I was going to just glass it all back in.
SE5a 'Fancier'
