SE5A Project - Swindon
Rev Light
Been thanked: 30 times
Post by Rev Light » Mon Jun 18, 2018 7:53 am
Quite pleased this week to have finally identified the colour of my Scimitar SE5a. A non-original Russet Red (3515).
Might be a BL colour from back in the day, but not really sure.
However a good match for touch-ups.
And now, at least I can start repairing all the stone chips and collateral damage received whilst carrying out recent works. No to mention a tidy up the engine bay.
Not that there is that much life left in the current paint job, but at least I can extend its life a little before taking the plunge with a re-spray down the line..
SE5a 'Fancier'
Has thanked: 154 times
Been thanked: 1051 times
Post by scimjim » Mon Jun 18, 2018 8:50 am
Russet red is a standard SE6 colour.
Rev Light
Post by Rev Light » Mon Jun 18, 2018 10:13 am
Thanks Jim, that makes a lot of sense. As you know it was that dark brown originally. As one of the last SE5a's, it sat around in the showroom and did not sell for a while, not being registered till well into 1976. I understand that the SE6s were being sold by that time, so it was probably difficult to shift considering its unfortunate colour and the newer model being out.
You never know, it might have been repainted to sell? Fanciful thinking, I know. Still, although brown seems to be an unfortunate colour now, perhaps it was all the rage then.
I had a Morris Ital that colour. I could fit 6 airmen in it on the way to the pub, plus me, the driver. We were all a bit skinnier in those days.
SE5a 'Fancier'
Rev Light
Post by Rev Light » Tue Jul 03, 2018 10:35 pm
Ah well,
My turn to break down tonight. On the way home I lost the ignition. When I turned the ignition on there was no red light in the speedo. The engine will crank and try to start. But the moment you release the key to disengage the starter, the engine stops. So it looks like the ignition switch/barrel has failed at position II. AA man turned up and we put 12v onto the coil, which got me going again, but there was no charging. So I just made it home.
So is it the ignition switch, and can I get another? I assume it's an arse of a job to do?
SE5a 'Fancier'
Has thanked: 37 times
Been thanked: 164 times
Post by gtcse8 » Tue Jul 03, 2018 10:47 pm
Steve I keep NEW ignition switches in stock which consists of the lock itself and the switching unit.
The switching units are held into the lock unit with a small self tapper.
The switch is only £25 inc post if that is what you need.
ignition switches.JPG (158.16 KiB) Viewed 2521 times
EX SST 1800Ti
Rev Light
Post by Rev Light » Tue Jul 03, 2018 10:59 pm
Sounds like just what I need. Be in touch tomorrow to sort out details, assuming that that is indeed my issue, which I have not yet confirmed with a multimeter. Although it seems highly likely.
SE5a 'Fancier'
Has thanked: 189 times
Been thanked: 37 times
Post by willholderogri » Wed Jul 04, 2018 8:01 am
hi steve yes if its not charging with a by pass its the supply to the dash/alternator light that is the problem (most likely the switch)
Mine split a pipe this morning now on the bike for three days
Rev Light
Post by Rev Light » Fri Jul 06, 2018 6:59 pm
I needed to get the old girl running again, so for the time being I removed my switch and have attempted to rebuild it, by cleaning it , and putting a bit of solder on the pitted contacts to build them up a bit. I put it back together with a bit of petroleum jelly to smooth it's operation. It seems to work. I could not find any screws to locate the switch unit, just key/slot for alignment. So I have secured with some tiewraps.
Normal service resumed, at least on the drive way. Take it for a run shortly.
The switches pictured have only 4 wires leading from them, whereas mine has 6. And I could not find the plug on my car?
Wiltshire Noggin on Monday
SE5a 'Fancier'
Post by gtcse8 » Fri Jul 06, 2018 8:05 pm
Steve I posted one of the new switches out to you to try.
Sounds like a wasted trip to the Postoffice.
I`m confused that yours has 6 wires and no plug or self tapper.
Sounds like its been modified somewhat.
EX SST 1800Ti
Rev Light
Post by Rev Light » Fri Jul 06, 2018 9:45 pm
I would not be surprised, quite frankly. The are plenty of 'modifications' - blue chock blocks and terminated wires, some just cut. Extra wires that bypass original circuit, etc. I am going to pull the dash soon and sort it all out. With this in mind, I might just keep the new switch and use it when I get to grips with this project.
SE5a 'Fancier'
Rev Light
Post by Rev Light » Mon Sep 10, 2018 10:46 am
Another little project, after seeing Mikey Bikeys Scimitar at Curborough.
The paint is a textured paint from Halfords, but the sand colour is a bit too bright.
Time to start making the panel up to hold the clocks.
I can see a bit of CAD coming up....Of the cardboard variety.
SE5a 'Fancier'
Post by willholderogri » Thu Sep 13, 2018 12:10 pm
I would like to see the result steve
Rev Light
Post by Rev Light » Mon Sep 24, 2018 10:54 am
Might be making this panel out of metal and once bent into shape, gluing on some veneer.
But I am also thinking of trying 4mm marine ply and scoring the back to allow me to bend it. Then securing and strengthening using some glass fibre matting.
Need to look at the console area first, as I need to decide where to mount the lamps and toggle switches.
Ho hum.
SE5a 'Fancier'
Rev Light
Post by Rev Light » Mon Oct 29, 2018 9:02 am
So back in the real world.
The back axle has been pulled apart and new seals to stop it leaking down the outside of the brake back plates and a new pinion seal.
And a new clutch slave cylinder....With new helicoils in the gearbox bell housing....After it finally let go and fired it internals across the workshop.
And then the MOT failure. Oh dear. The 'No MOT holiday', after 7 months without, is over.
New trunnions required, both sides, but the driver's side was especially bad. And, to be honest, I should not have been surprised. I had started to feel it, as what was a high speed vibration (i.e. above legal speeds) was now becoming a much lower speed issue. I.e. it was now being felt legal speeds. But you drive around these issues and/or ignore them against your better judgement. And since I have never driven anyone else's SE5A, I have nothing to compare, other than a 'modern'
Not that I did any of these jobs, Andy (AJL Electronics) pushed it all through for me. A bit more work than he was expecting, and he did pare the bill down a little to stop me blubbing.....
The car does drive much better now, though.
And I also have a list of 'advisories' from Andy, that either the MOT man did not spot, or that were not quite bad enough for making a fuss over....Yet.
Steve.
SE5a 'Fancier'
Post by willholderogri » Mon Oct 29, 2018 9:23 am
The joy of scimitar ownership mines off the road for a month or two (tarting it up somewhat)
