A New Project. The Pale Green 'Womble' SS1
Has thanked: 102 times
Been thanked: 153 times
Re: A New Project. The Pale Green 'Womble' SS1
Post by reliant-reviver » Wed Jun 15, 2016 10:24 pm
I've found a few over the years! We could compare serial numbers
Saber One
Post by Saber One » Fri Jun 28, 2019 1:25 pm
Afternoon, looking at changing the front engine mounts, what's the best way to remove then , can I use a trolley jack under the sump, or do I use a engine hoist ,
thanks
Has thanked: 428 times
Been thanked: 370 times
Post by CNHSS1 » Fri Jun 28, 2019 1:52 pm
Not sump! Slings and hoist
Saber One
Post by Saber One » Fri Jun 28, 2019 3:10 pm
Okay thanks for hosting info , is there a captive nut in chassis for bottom of rubber engine mount as I can't see any thing as it all inclosed :?:
Has thanked: 78 times
Been thanked: 707 times
Post by philhoward » Fri Jun 28, 2019 3:25 pm
Yep - captive nut.
Saber One
Post by Saber One » Fri Jun 28, 2019 5:59 pm
Thank you both for answers :D
Saber One
Post by Saber One » Fri Oct 25, 2019 1:41 pm
Hi , advice needed, did try a search, didn't find answer , when car has around half a tank of fuel or more , the smell of petrol is really bad around the back of the car, when fuel has dropped and amber light starts to come on smell goes, no leaking found on or around car, any ideas what i should be looking for, thanks
Has thanked: 155 times
Been thanked: 1052 times
Post by scimjim » Fri Oct 25, 2019 2:13 pm
I’d remove the boot liner and check the vent pipes first. Then take the filler pipe off the tank and check for corrosion.
