Does Run Fast 351 Eventually!
Has thanked: 193 times
Been thanked: 166 times
Post by b.c.flat hat » Thu Sep 12, 2019 11:00 am
It's a Bosch random orbital but I have a 1/4 sheet domestic sander too. I use Abranet 120 and 80 grit abrasives.
Post by b.c.flat hat » Tue Dec 17, 2019 10:33 am
Going through a huge box of old photos, found some from 1994 when we went in the Se5a to Sunderland Airport. This is one of the Coupe, who knew that 25 years later it would be in my garage under major restoration!
Been thanked: 137 times
Post by BigBobPilot » Tue Dec 17, 2019 11:11 am
Fate!
SS1 CA18DET race car
Has thanked: 452 times
Been thanked: 392 times
Post by CNHSS1 » Tue Dec 17, 2019 9:00 pm
Nice one BC 8)
Post by b.c.flat hat » Sat Jan 04, 2020 2:59 pm
I took advantage of a dry day to do a mahoosive shunt to re-arrange stuff on the ramp, so the palleted "treasure" and repaired chassis was taken out, body lifted off the transport trolley and left up on beams while the trolley was exchanged for the repaired chassis.
I've looked at the factory exhaust mounts and decided that the long,heavy single silencer could do with more support. A couple of angles welded to the bottom of the outer chassis rails either end of the silencer become mounts for bobbins in compression. Small angle brackets bolt to the pipe clamps and bobbins providing the support. An extra angle is welded to the chassis rails where they angle upwards, angled pipe sockets are clamped to the tailpipe and the original mounts complete the setup.
I've tweeted the tail pipes to positively clear the rear axle suspension mounts and centralise the exhausts in the outrigger holes.
Crouchie_b
Has thanked: 47 times
Post by Crouchie_b » Sat Jan 04, 2020 4:05 pm
Someone’s been busy!😎
You left anything for me to do tomorrow?😁
Crouchie_b
Has thanked: 158 times
Been thanked: 1092 times
Post by scimjim » Sat Jan 04, 2020 7:10 pm
Good to see you back on it Brian 👍
Post by CNHSS1 » Sun Jan 05, 2020 12:25 am
Youre relegated to Tea Boy Crouchie :lol:
Crouchie_b
Post by Crouchie_b » Sun Jan 05, 2020 10:17 am
That’s a promotion from sweeper upper!🤣
Crouchie_b
Post by b.c.flat hat » Sun Jan 05, 2020 4:56 pm
Drivers side tail pipe and silencer brackets fitted, both sides front and rear silencer pipes are now central in the outrigger holes, proper job!
Scrap tubular exhaust headers have donated the manifold flanges to enable the fitter to use them as a pattern.
Has thanked: 216 times
Been thanked: 116 times
Post by efi_sprintgte » Sun Jan 05, 2020 5:09 pm
Nice on BC 8)
Been thanked: 176 times
Post by gtcse8 » Sun Jan 05, 2020 5:38 pm
I can see METRIC threads and Nylocs :cloud:
Post by CNHSS1 » Sun Jan 05, 2020 7:12 pm
Civilisation dawns... :mrgreen:
Post by b.c.flat hat » Sun Jan 05, 2020 8:44 pm
Yerse, it were right painful t' even pick the foreign sockets out o' box but I only did two, son did others. I were feelin' ill.
Post by gtcse8 » Sun Jan 05, 2020 10:17 pm
IIRC Mr Pither introduced you to Metrication on steering racks :wink:
And this has caused complications ever since :doh:
